.mkv does not appear in file List
amasingh
Post Wed Apr 24, 2013 2:51 pm
Hi all,
I use Serviio now for about a half year. Until now everything works well. I stream most time HD SBS Movies.
Now I have a new movie file. Its a 18GB HD SBS Movie. File Format is .mkv with MPEG4/ISO/AVC in it. But it does not appear in file list. Not in last added also not in Folders/movies. It seems Serviio does not like the Movies.
Until now all mopvies with this format worked for me. The current one works fine on my computer using VLC Player. Any Idea what could be the problem?
Kind Regards
Post Wed Apr 24, 2013 4:22 pm
Re: .mkv does not appear in file List
amasingh
Post Wed Apr 24, 2013 8:11 pm
Thanks for the reply :)
I followed all tips on the site. Nothing worked for me. Also the Programm listed there does not show up the movie.
But I will also try to update now all programms like x264 and so on
Here is the output of ffmpeg -f <file>
ffmpeg version git-2012-09-11-ec79468 Copyright (c) 2000-2012 the FFmpeg developers
  built on Sep 11 2012 17:06:17 with gcc 4.4.3 (Ubuntu 4.4.3-4ubuntu5.1)
  configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libx264 --enable-nonfree --enable-version3 --enable-x11grab
  libavutil      51. 72.100 / 51. 72.100
  libavcodec     54. 55.100 / 54. 55.100
  libavformat    54. 26.101 / 54. 26.101
  libavdevice    54.  2.100 / 54.  2.100
  libavfilter     3. 16.103 /  3. 16.103
  libswscale      2.  1.101 /  2.  1.101
Input #0, matroska,webm, from 'DH3DbyAME.mkv':
    title : movie
    creation_time   : 2013-04-11 13:38:10
  Duration: 02:49:36.00, start: 0.000000, bitrate: 15451 kb/s
    Chapter #0.0: start 0.000000, end 531.364000
      title           : (01)00:00:00:000
    Chapter #0.1: start 531.364000, end 778.861000
      title           : (02)00:08:51:364
    Chapter #0.2: start 778.861000, end 994.576000
      title           : (03)00:12:58:861
    Chapter #0.3: start 994.576000, end 1250.624000
      title           : (04)00:16:34:576
    Chapter #0.4: start 1250.624000, end 1508.965000
      title           : (05)00:20:50:624
    Chapter #0.5: start 1508.965000, end 1994.367000
      title           : (06)00:25:08:965
    Chapter #0.6: start 1994.367000, end 2306.762000
      title           : (07)00:33:14:367
    Chapter #0.7: start 2306.762000, end 2620.326000
      title           : (08)00:38:26:762
    Chapter #0.8: start 2620.326000, end 3012.259000
      title           : (09)00:43:40:326
    Chapter #0.9: start 3012.259000, end 3316.062000
      title           : (10)00:50:12:259
    Chapter #0.10: start 3316.062000, end 3424.796000
      title           : (11)00:55:16:062
    Chapter #0.11: start 3424.796000, end 4071.901000
      title           : (12)00:57:04:796
    Chapter #0.12: start 4071.901000, end 4330.451000
      title           : (13)01:07:51:901
    Chapter #0.13: start 4330.451000, end 4563.308000
      title           : (14)01:12:10:451
    Chapter #0.14: start 4563.308000, end 4926.421000
      title           : (15)01:16:03:308
    Chapter #0.15: start 4926.421000, end 5329.949000
      title           : (16)01:22:06:421
    Chapter #0.16: start 5329.949000, end 5523.476000
      title           : (17)01:28:49:949
    Chapter #0.17: start 5523.476000, end 5621.657000
      title           : (18)01:32:03:476
    Chapter #0.18: start 5621.657000, end 6029.023000
      title           : (19)01:33:41:657
    Chapter #0.19: start 6029.023000, end 6186.305000
      title           : (20)01:40:29:023
    Chapter #0.20: start 6186.305000, end 6552.462000
      title           : (21)01:43:06:305
    Chapter #0.21: start 6552.462000, end 6844.003000
      title           : (22)01:49:12:462
    Chapter #0.22: start 6844.003000, end 7017.510000
      title           : (23)01:54:04:003
    Chapter #0.23: start 7017.510000, end 7827.402000
      title           : (24)01:56:57:510
    Chapter #0.24: start 7827.402000, end 7945.938000
      title           : (25)02:10:27:402
    Chapter #0.25: start 7945.938000, end 8017.175000
      title           : (26)02:12:25:938
    Chapter #0.26: start 8017.175000, end 8279.062000
      title           : (27)02:13:37:175
    Chapter #0.27: start 8279.062000, end 8408.817000
      title           : (28)02:17:59:062
    Chapter #0.28: start 8408.817000, end 8578.570000
      title           : (29)02:20:08:817
    Chapter #0.29: start 8578.570000, end 9238.187000
      title           : (30)02:22:58:570
    Chapter #0.30: start 9238.187000, end 9566.807000
      title           : (31)02:33:58:187
    Chapter #0.31: start 9566.807000, end 10176.000006
      title           : (32)02:39:26:807
    Stream #0:0: Video: h264 (High), yuv420p, 1920x800, SAR 1:1 DAR 12:5, 23.98 fps, 23.98 tbr, 48003.07 tbn, 47.95 tbc (default)
    Stream #0:1: Audio: ac3, 48000 Hz, 5.1(side), s16, 448 kb/s (default)
amasingh
Post Wed Apr 24, 2013 9:08 pm
ffmpeg is now also complete new. Used this Tutorial to update it:
https://ffmpeg.org/trac/ffmpeg/wiki/Ubu ... cid#ffmpeg
But still no Movie :( Perhaps its too big?
slyguy42o
Post Wed Apr 24, 2013 9:49 pm
you may want to check your logs for the file in question and post the details here.
amasingh
Post Wed Apr 24, 2013 9:56 pm
Please give me more information about the logs. Im a noob - dont know how to creeate the log and where to find it ;)
amasingh
Post Wed Apr 24, 2013 9:59 pm
OK I think this is what the problem. But how to fix it?
2013-04-24 23:06:32,359 WARN  [FFMPEGWrapper] FFmpeg is not compiled with librtmp support, RTMP streaming will not work.
2013-04-24 23:06:32,359 WARN  [FFMPEGWrapper] FFmpeg is not compiled with libass support, rendering subtitles (hardsubs) will not work.
2013-04-24 23:06:32,762 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "dcraw": java.io.IOException: error=2, No such file or directory
java.io.IOException: Cannot run program "dcraw": java.io.IOException: error=2, No such file or directory
        at java.lang.ProcessBuilder.start(ProcessBuilder.java:475)
        at org.serviio.external.ProcessExecutor.run(ProcessExecutor.java:135)
Caused by: java.io.IOException: java.io.IOException: error=2, No such file or directory
        at java.lang.UNIXProcess.<init>(UNIXProcess.java:164)
        at java.lang.ProcessImpl.start(ProcessImpl.java:81)
        at java.lang.ProcessBuilder.start(ProcessBuilder.java:468)
        ... 1 more
amasingh
Post Wed Apr 24, 2013 10:54 pm
I found the problem... Cant believe it.. German problem.. ;) The Folders name had a special caharacter ü
Post Thu Apr 25, 2013 8:51 am
Are you on Linux? If yes, read the FAQ.
Users browsing this forum: Baidu [Spider] and 52 guests
