Audio via toslink
Any idea?
slyguy42o wrote:it sounds like more of a TV \ audio system setup issue rather than a serviio problem. have you tried changing the audio encoding format to see if it affects the issue?
probedb wrote:MP4 is not an audio format, it's a container. You need to find out what audio codec is being used. You can use various progs to do this, VLC will tell you what codecs are in the current video.
If it's AAC I wouldn't expect the Panny to pass it over S/P-DIF as I don't think anything supports it. It's likely ps3mediaserver was transcoding to MP3 or something else and your TV was decoding and able to pass on.
It's definitely the TV as there are certain formats it will playback but not pass on.
