Samsung C/D/E, No Subtitles.
• Page 1 of 1
Im using serviio 1.2.1 on Mac. On the tools menu on my samsung smart tv i cant take subtitles off. Wondering if theres anyway to fix this?
Re: Samsung C/D/E, No Subtitles.
if you don't want subs, you can disable the subtitle option in the serviio console.
rcc848 wrote:Im using serviio 1.2.1 on Mac. On the tools menu on my samsung smart tv i cant take subtitles off. Wondering if theres anyway to fix this?
Do you mean there is no such option? Or even is you deselect that you still have subs? DO you have burned-in subs enabled?
Petr
Help translate Serviio
Hello
I have 40D6500, using serviio, the settings are ok, but subtitles don't appeare on the screen.I have enable all options in the subtitle menu, but nothing.
Is possible to see an .mkv file with subtitle with serviio?
Thank you
Thank you
yes, but depends what subtitles. post your files details
Petr
• Page 1 of 1
