Unsuported Codec PS51D550
woland1985
Post Tue Jan 01, 2013 2:21 pm
first of all sorry for my English - It isn't my native.
I have problem with playing rmvb files on my PS51D550. It says - Unsuported Codec while using Samsung's AllShare everything is OK. Can some1 help me?
Detailed info about the file:
c:\Program Files\Serviio\lib>ffmpeg.exe -i "D:\filmy\białe kołnierzyki 1\Biały k
ołnierzyk White Collar S01E01 lektor pl.rmvb"
g-config
[rm @ 0036BA80] Unsupported stream type 00000214
Input #0, rm, from 'D:\filmy\białe kołnierzyki 1\Biały kołnierzyk White Coll
ar S01E01 lektor pl.rmvb':
    title           :
    author          :
    copyright       :
    comment         :
  Duration: 00:39:40.58, start: 0.000000, bitrate: 615 kb/s
    Stream #0:0: Audio: cook (cook / 0x6B6F6F63), 44100 Hz, stereo, flt, 64 kb/s
    Stream #0:1: Video: rv40 (RV40 / 0x30345652), yuv420p, 880x480, 530 kb/s, 25
 fps, 25 tbr, 1k tbn, 1k tbc
    Stream #0:2: Data: none
Another question is about fast forward - reading this forum I have seen info that for some type of files its imposible - will it be posible for this file? (Allshare can do this to).
I like Serviio because it is light and can stream video to my other TV (Le32C550) and thats why i want to use it.
Thank you in advance for any answers
log.txt
Log
(106.39 KiB) Downloaded 518 times
Post Wed Jan 02, 2013 1:53 pm
Re: Unsuported Codec PS51D550
try to get newest FFmpeg (see wiki for link). It looks like the TV can play it natively, but Serviio will be only able to do this in the next version.
onizuka
Post Sun Mar 03, 2013 12:33 am
Hi there,
I just installed 1.2, and it looks like rmvb files still has the same "codec not supported" problem for this TV?
Is there some profile config that I need to change?
cheers,
Post Sun Mar 03, 2013 12:30 pm
Post detailed log of playing the file.
onizuka
Post Wed Mar 06, 2013 10:26 am
Hi there,
I tried to filter out as much noise as I can..
The file I m trying to play is : Tiger Cubs-01-2012-6-24.rmvb (Its inside a directory with chinese characters on a NAS .. not sure if thats the problem)
2013-03-03 11:21:47,049 INFO  [MediaServer] Serviio DLNA media streaming server v 1.2 (rev. 7f0f253cf67d+)
2013-03-03 11:21:47,049 INFO  [MediaServer] Petr Nejedly 2009-2013
2013-03-03 11:21:47,049 INFO  [MediaServer] http://www.serviio.org
2013-03-03 11:21:47,049 INFO  [MediaServer] Java 1.7.0_01-Oracle Corporation
2013-03-03 11:21:47,049 INFO  [MediaServer] OS Windows 7 amd64 6.1
2013-03-03 11:21:47,049 INFO  [MediaServer] File encoding: windows-1252
2013-03-03 11:21:47,049 INFO  [MediaServer] Headless mode enabled: true
2013-03-03 11:21:47,049 INFO  [MediaServer] User: JEFF-PC$
2013-03-03 11:21:47,049 INFO  [MediaServer] User home dir: C:\
2013-03-03 11:21:47,049 INFO  [MediaServer] Temp dir: C:\Windows\TEMP\
2013-03-03 11:21:47,049 INFO  [MediaServer] ------------------------------------------------------------------------
2013-03-03 11:21:47,455 INFO  [WebServer] Socket buffer set to 65535 bytes
2013-03-03 11:21:47,470 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-03-03 11:21:47,657 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-03-03 11:21:47,657 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-03-03 11:21:47,704 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-03-03 11:22:16,611 INFO  [MediaServer] ------------------------------------------------------------------------
2013-03-03 11:22:16,612 INFO  [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2013-03-03 11:22:16,612 INFO  [MediaServer] ------------------------------------------------------------------------
2013-03-06 19:45:55,406 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 26676 and profile Samsung TV / player (C/D/E-series)
2013-03-06 19:45:55,407 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_EU_ISO
2013-03-06 19:45:55,407 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_NA_ISO
2013-03-06 19:45:55,407 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_KO_ISO
2013-03-06 19:45:55,458 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 26676 and profile Samsung TV / player (C/D/E-series)
2013-03-06 19:45:55,458 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_EU_ISO
2013-03-06 19:45:55,458 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_NA_ISO
2013-03-06 19:45:55,458 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_KO_ISO
2013-03-06 19:45:55,458 DEBUG [MediaItemDAOImpl] Getting file of media item 26676
2013-03-06 19:45:55,476 DEBUG [MediaItemDAOImpl] Getting file of media item 26677
2013-03-06 19:45:55,489 DEBUG [GenreDAOImpl] Reading a Genre (id = 82)
2013-03-06 19:45:55,489 DEBUG [VideoDAOImpl] Reading a Video (id = 26677)
2013-03-06 19:45:55,490 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 26677 and profile Samsung TV / player (C/D/E-series)
2013-03-06 19:45:55,490 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-02-2012-7-1.rmvb: MPEG_TS_SD_EU_ISO
2013-03-06 19:45:55,490 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-02-2012-7-1.rmvb: MPEG_TS_SD_NA_ISO
2013-03-06 19:45:55,490 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-02-2012-7-1.rmvb: MPEG_TS_SD_KO_ISO
2013-03-06 19:45:55,490 DEBUG [MediaItemDAOImpl] Getting file of media item 26677
2013-03-06 19:45:55,503 DEBUG [MediaItemDAOImpl] Getting file of media item 26678
2013-03-06 19:45:55,516 DEBUG [GenreDAOImpl] Reading a Genre (id = 82)
2013-03-06 19:45:55,516 DEBUG [VideoDAOImpl] Reading a Video (id = 26678)
2013-03-06 19:45:55,517 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 26678 and profile Samsung TV / player (C/D/E-series)
2013-03-06 19:45:55,517 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-03-2012-7-8.rmvb: MPEG_TS_SD_EU_ISO
2013-03-06 19:45:55,517 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-03-2012-7-8.rmvb: MPEG_TS_SD_NA_ISO
2013-03-06 19:45:55,517 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-03-2012-7-8.rmvb: MPEG_TS_SD_KO_ISO
2013-03-06 19:45:55,517 DEBUG [MediaItemDAOImpl] Getting file of media item 26678
2013-03-06 19:45:55,530 DEBUG [MediaItemDAOImpl] Getting file of media item 26679
2013-03-06 19:45:55,543 DEBUG [GenreDAOImpl] Reading a Genre (id = 82)
2013-03-06 19:45:55,544 DEBUG [VideoDAOImpl] Reading a Video (id = 26679)
2013-03-06 19:45:55,544 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 26679 and profile Samsung TV / player (C/D/E-series)
2013-03-06 19:45:55,544 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-04-2012-7-14.rmvb: MPEG_TS_SD_EU_ISO
2013-03-06 19:45:55,544 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-04-2012-7-14.rmvb: MPEG_TS_SD_NA_ISO
2013-03-06 19:45:55,544 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-04-2012-7-14.rmvb: MPEG_TS_SD_KO_ISO
2013-03-06 19:45:55,544 DEBUG [MediaItemDAOImpl] Getting file of media item 26679
2013-03-06 19:45:55,558 DEBUG [MediaItemDAOImpl] Getting file of media item 26680
2013-03-06 19:45:55,571 DEBUG [GenreDAOImpl] Reading a Genre (id = 82)
2013-03-06 19:45:55,571 DEBUG [VideoDAOImpl] Reading a Video (id = 26680)
2013-03-06 19:45:55,572 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 26680 and profile Samsung TV / player (C/D/E-series)
2013-03-06 19:45:55,572 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-05-2012-7-15.rmvb: MPEG_TS_SD_EU_ISO
2013-03-06 19:45:55,572 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-05-2012-7-15.rmvb: MPEG_TS_SD_NA_ISO
2013-03-06 19:45:55,572 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-05-2012-7-15.rmvb: MPEG_TS_SD_KO_ISO
2013-03-06 19:45:55,572 DEBUG [MediaItemDAOImpl] Getting file of media item 26680
2013-03-06 19:45:55,585 DEBUG [MediaItemDAOImpl] Getting file of media item 26681
2013-03-06 19:45:55,605 DEBUG [GenreDAOImpl] Reading a Genre (id = 82)
2013-03-06 19:45:55,606 DEBUG [VideoDAOImpl] Reading a Video (id = 26681)
2013-03-06 19:45:55,606 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 26681 and profile Samsung TV / player (C/D/E-series)
2013-03-06 19:45:55,606 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-06-2012-7-21.rmvb: MPEG_TS_SD_EU_ISO
2013-03-06 19:45:55,606 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-06-2012-7-21.rmvb: MPEG_TS_SD_NA_ISO
2013-03-06 19:45:55,606 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-06-2012-7-21.rmvb: MPEG_TS_SD_KO_ISO
2013-03-06 19:45:55,607 DEBUG [MediaItemDAOImpl] Getting file of media item 26681
2013-03-06 19:45:55,622 DEBUG [MediaItemDAOImpl] Getting file of media item 26682
2013-03-06 19:45:55,647 DEBUG [GenreDAOImpl] Reading a Genre (id = 82)
2013-03-06 19:45:55,647 DEBUG [VideoDAOImpl] Reading a Video (id = 26682)
2013-03-06 19:45:55,647 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 26682 and profile Samsung TV / player (C/D/E-series)
2013-03-06 19:45:55,648 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-07-2012-7-22.rmvb: MPEG_TS_SD_EU_ISO
2013-03-06 19:45:55,648 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-07-2012-7-22.rmvb: MPEG_TS_SD_NA_ISO
2013-03-06 19:45:55,648 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-07-2012-7-22.rmvb: MPEG_TS_SD_KO_ISO
2013-03-06 19:45:55,648 DEBUG [MediaItemDAOImpl] Getting file of media item 26682
2013-03-06 19:45:55,661 DEBUG [MediaItemDAOImpl] Getting file of media item 26683
2013-03-06 19:45:55,674 DEBUG [GenreDAOImpl] Reading a Genre (id = 82)
2013-03-06 19:45:55,674 DEBUG [VideoDAOImpl] Reading a Video (id = 26683)
2013-03-06 19:45:55,674 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 26683 and profile Samsung TV / player (C/D/E-series)
2013-03-06 19:45:55,675 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-08-2012-7-28.rmvb: MPEG_TS_SD_EU_ISO
2013-03-06 19:45:55,675 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-08-2012-7-28.rmvb: MPEG_TS_SD_NA_ISO
2013-03-06 19:45:55,675 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-08-2012-7-28.rmvb: MPEG_TS_SD_KO_ISO
2013-03-06 19:45:55,675 DEBUG [MediaItemDAOImpl] Getting file of media item 26683
2013-03-06 19:45:55,688 DEBUG [MediaItemDAOImpl] Getting file of media item 26684
2013-03-06 19:45:55,701 DEBUG [GenreDAOImpl] Reading a Genre (id = 82)
2013-03-06 19:45:55,701 DEBUG [VideoDAOImpl] Reading a Video (id = 26684)
2013-03-06 19:45:55,701 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 26684 and profile Samsung TV / player (C/D/E-series)
2013-03-06 19:45:55,701 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-09-2012-7-29.rmvb: MPEG_TS_SD_EU_ISO
2013-03-06 19:45:55,701 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-09-2012-7-29.rmvb: MPEG_TS_SD_NA_ISO
2013-03-06 19:45:55,701 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-09-2012-7-29.rmvb: MPEG_TS_SD_KO_ISO
2013-03-06 19:45:55,702 DEBUG [MediaItemDAOImpl] Getting file of media item 26684
2013-03-06 19:45:55,715 DEBUG [MediaItemDAOImpl] Getting file of media item 26685
2013-03-06 19:45:55,728 DEBUG [GenreDAOImpl] Reading a Genre (id = 82)
2013-03-06 19:45:55,728 DEBUG [VideoDAOImpl] Reading a Video (id = 26685)
2013-03-06 19:45:55,728 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 26685 and profile Samsung TV / player (C/D/E-series)
2013-03-06 19:45:55,729 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-10-2012-8-4.rmvb: MPEG_TS_SD_EU_ISO
2013-03-06 19:45:55,729 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-10-2012-8-4.rmvb: MPEG_TS_SD_NA_ISO
2013-03-06 19:45:55,729 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-10-2012-8-4.rmvb: MPEG_TS_SD_KO_ISO
2013-03-06 19:45:55,729 DEBUG [MediaItemDAOImpl] Getting file of media item 26685
2013-03-06 19:45:55,742 DEBUG [MediaItemDAOImpl] Getting file of media item 26686
2013-03-06 19:45:55,755 DEBUG [GenreDAOImpl] Reading a Genre (id = 82)
2013-03-06 19:45:55,755 DEBUG [VideoDAOImpl] Reading a Video (id = 26686)
2013-03-06 19:45:55,755 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 26686 and profile Samsung TV / player (C/D/E-series)
2013-03-06 19:45:55,756 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-11-2012-8-5.rmvb: MPEG_TS_SD_EU_ISO
2013-03-06 19:45:55,756 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-11-2012-8-5.rmvb: MPEG_TS_SD_NA_ISO
2013-03-06 19:45:55,756 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-11-2012-8-5.rmvb: MPEG_TS_SD_KO_ISO
2013-03-06 19:45:55,756 DEBUG [MediaItemDAOImpl] Getting file of media item 26686
2013-03-06 19:45:55,769 DEBUG [MediaItemDAOImpl] Getting file of media item 26687
2013-03-06 19:45:55,782 DEBUG [GenreDAOImpl] Reading a Genre (id = 82)
2013-03-06 19:45:55,782 DEBUG [VideoDAOImpl] Reading a Video (id = 26687)
2013-03-06 19:45:55,782 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 26687 and profile Samsung TV / player (C/D/E-series)
2013-03-06 19:45:55,783 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-12-2012-8-11.rmvb: MPEG_TS_SD_EU_ISO
2013-03-06 19:45:55,783 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-12-2012-8-11.rmvb: MPEG_TS_SD_NA_ISO
2013-03-06 19:45:55,783 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-12-2012-8-11.rmvb: MPEG_TS_SD_KO_ISO
2013-03-06 19:45:55,783 DEBUG [MediaItemDAOImpl] Getting file of media item 26687
2013-03-06 19:45:55,796 DEBUG [MediaItemDAOImpl] Getting file of media item 26688
2013-03-06 19:45:55,809 DEBUG [GenreDAOImpl] Reading a Genre (id = 82)
2013-03-06 19:45:55,809 DEBUG [VideoDAOImpl] Reading a Video (id = 26688)
2013-03-06 19:45:55,809 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 26688 and profile Samsung TV / player (C/D/E-series)
2013-03-06 19:45:55,809 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-13end-2012-8-12.rmvb: MPEG_TS_SD_EU_ISO
2013-03-06 19:45:55,809 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-13end-2012-8-12.rmvb: MPEG_TS_SD_NA_ISO
2013-03-06 19:45:55,809 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-13end-2012-8-12.rmvb: MPEG_TS_SD_KO_ISO
2013-03-06 19:45:55,810 DEBUG [MediaItemDAOImpl] Getting file of media item 26688
2013-03-06 19:45:55,824 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 6544 (filter: ALL) [No_Restriction]
2013-03-06 19:45:55,825 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2013-03-06 19:45:55,837 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-03-06 19:46:06,768 DEBUG [WebServer] Incoming connection from /192.168.0.251:52076
2013-03-06 19:46:06,768 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.251
2013-03-06 19:46:06,769 DEBUG [ResourceTransportRequestHandler] HEAD /resource/26676/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 192.168.0.1:8895]]
2013-03-06 19:46:06,769 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.251
2013-03-06 19:46:06,773 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.251, Profile=Samsung TV / player (C/D/E-series)'
2013-03-06 19:46:06,774 DEBUG [ResourceDeliveryProcessor] Request for resource 26676 and type 'MEDIA_ITEM' received
2013-03-06 19:46:06,774 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 26676 (local)
2013-03-06 19:46:06,774 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 26676)
2013-03-06 19:46:06,780 DEBUG [VideoDAOImpl] Reading a Video (id = 26676)
2013-03-06 19:46:06,781 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 26676, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D/E-series)
2013-03-06 19:46:06,781 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Tiger Cubs-01-2012-6-24.rmvb
2013-03-06 19:46:06,781 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_EU_ISO
2013-03-06 19:46:06,781 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_NA_ISO
2013-03-06 19:46:06,781 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_KO_ISO
2013-03-06 19:46:06,784 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Wed, 06 Mar 2013 08:46:06 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-03-06 19:46:06,796 DEBUG [WebServer] Incoming connection from /192.168.0.251:41533
2013-03-06 19:46:06,797 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.251
2013-03-06 19:46:06,798 DEBUG [ResourceTransportRequestHandler] GET /resource/26676/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,TimeSeekRange.dlna.org: npt=0-,Host: 192.168.0.1:8895]]
2013-03-06 19:46:06,798 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.251
2013-03-06 19:46:06,799 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.251, Profile=Samsung TV / player (C/D/E-series)'
2013-03-06 19:46:06,799 DEBUG [ResourceDeliveryProcessor] Request for resource 26676 and type 'MEDIA_ITEM' received
2013-03-06 19:46:06,799 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 26676 (local)
2013-03-06 19:46:06,799 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 26676)
2013-03-06 19:46:06,800 DEBUG [VideoDAOImpl] Reading a Video (id = 26676)
2013-03-06 19:46:06,800 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 26676, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D/E-series)
2013-03-06 19:46:06,800 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Tiger Cubs-01-2012-6-24.rmvb
2013-03-06 19:46:06,800 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_EU_ISO
2013-03-06 19:46:06,800 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_NA_ISO
2013-03-06 19:46:06,800 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_KO_ISO
2013-03-06 19:46:06,800 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 26676 (local)
2013-03-06 19:46:06,800 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 26676)
2013-03-06 19:46:06,801 DEBUG [VideoDAOImpl] Reading a Video (id = 26676)
2013-03-06 19:46:06,801 DEBUG [VideoDeliveryEngine] Delivering item '26676' for client 'Identifier=192.168.0.251, Profile=Samsung TV / player (C/D/E-series)'
2013-03-06 19:46:06,801 DEBUG [VideoDeliveryEngine] Delivering file 'Tiger Cubs-01-2012-6-24.rmvb' using transcoding
2013-03-06 19:46:06,801 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.168.0.251, Profile=Samsung TV / player (C/D/E-series)'
2013-03-06 19:46:06,802 DEBUG [MediaItemDAOImpl] Getting file of media item 26676
2013-03-06 19:46:06,803 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: \\192.168.0.253\Volume_1\TV Series\Chinese\TVB飛虎\Tiger Cubs-01-2012-6-24.rmvb
2013-03-06 19:46:06,803 DEBUG [ProcessExecutor] Starting D:\Multimedia\Serviio\bin\\..\lib/ffmpeg.exe -threads 2 -i \\192.168.0.253\Volume_1\TV Series\Chinese\TVB飛虎\Tiger Cubs-01-2012-6-24.rmvb -y -c:v mpeg2video -qscale:v 1 -r 25 -g 15 -c:a ac3 -b:a 64k -ac 2 -map 0:1 -map 0:0 -sn -f mpegts L:\Transcode\Serviio\transcoding-temp-26676-7-ORIGINAL.stf
2013-03-06 19:46:09,804 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_EU_ISO
2013-03-06 19:46:09,804 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_NA_ISO
2013-03-06 19:46:09,804 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_KO_ISO
2013-03-06 19:46:09,804 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 26676) as read
2013-03-06 19:46:09,823 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-03-06 19:46:09,823 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-03-06 19:46:09,823 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Wed, 06 Mar 2013 08:46:09 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.2,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=0-4240/4240,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,MediaInfo.sec: SEC_Duration=4240000;]]
2013-03-06 19:46:11,677 DEBUG [WebServer] Incoming connection from /192.168.0.251:47128
2013-03-06 19:46:11,678 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.251
2013-03-06 19:46:11,679 DEBUG [ResourceTransportRequestHandler] HEAD /resource/26676/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2013-03-06 19:46:11,679 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.251
2013-03-06 19:46:11,679 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.251, Profile=Samsung TV / player (C/D/E-series)'
2013-03-06 19:46:11,680 DEBUG [ResourceDeliveryProcessor] Request for resource 26676 and type 'MEDIA_ITEM' received
2013-03-06 19:46:11,680 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 26676 (local)
2013-03-06 19:46:11,680 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 26676)
2013-03-06 19:46:11,680 DEBUG [VideoDAOImpl] Reading a Video (id = 26676)
2013-03-06 19:46:11,681 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 26676, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D/E-series)
2013-03-06 19:46:11,681 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Tiger Cubs-01-2012-6-24.rmvb
2013-03-06 19:46:11,681 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_EU_ISO
2013-03-06 19:46:11,681 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_NA_ISO
2013-03-06 19:46:11,681 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_KO_ISO
2013-03-06 19:46:11,681 DEBUG [VideoDAOImpl] Reading a Video (id = 26676)
2013-03-06 19:46:11,682 DEBUG [MediaItemDAOImpl] Getting file of media item 26676
2013-03-06 19:46:11,699 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Wed, 06 Mar 2013 08:46:11 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.2,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
2013-03-06 19:46:12,376 DEBUG [WebServer] Incoming connection from /192.168.0.251:38912
2013-03-06 19:46:12,376 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.251
2013-03-06 19:46:12,376 DEBUG [ResourceTransportRequestHandler] HEAD /resource/26676/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2013-03-06 19:46:12,377 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.251, Profile=Samsung TV / player (C/D/E-series)'
2013-03-06 19:46:12,377 DEBUG [ResourceDeliveryProcessor] Request for resource 26676 and type 'MEDIA_ITEM' received
2013-03-06 19:46:12,377 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 26676 (local)
2013-03-06 19:46:12,377 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 26676)
2013-03-06 19:46:12,377 DEBUG [VideoDAOImpl] Reading a Video (id = 26676)
2013-03-06 19:46:12,378 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 26676, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D/E-series)
2013-03-06 19:46:12,378 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Tiger Cubs-01-2012-6-24.rmvb
2013-03-06 19:46:12,378 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_EU_ISO
2013-03-06 19:46:12,378 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_NA_ISO
2013-03-06 19:46:12,378 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_KO_ISO
2013-03-06 19:46:12,378 DEBUG [VideoDAOImpl] Reading a Video (id = 26676)
2013-03-06 19:46:12,379 DEBUG [MediaItemDAOImpl] Getting file of media item 26676
2013-03-06 19:46:12,398 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Wed, 06 Mar 2013 08:46:12 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.2,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
2013-03-06 19:46:12,536 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-03-06 19:46:15,007 DEBUG [WebServer] Incoming connection from /192.168.0.251:46638
2013-03-06 19:46:15,007 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.251
2013-03-06 19:46:15,008 DEBUG [ResourceTransportRequestHandler] HEAD /resource/26676/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2013-03-06 19:46:15,009 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.251
2013-03-06 19:46:15,010 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.251, Profile=Samsung TV / player (C/D/E-series)'
2013-03-06 19:46:15,010 DEBUG [ResourceDeliveryProcessor] Request for resource 26676 and type 'MEDIA_ITEM' received
2013-03-06 19:46:15,010 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 26676 (local)
2013-03-06 19:46:15,010 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 26676)
2013-03-06 19:46:15,010 DEBUG [VideoDAOImpl] Reading a Video (id = 26676)
2013-03-06 19:46:15,011 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 26676, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D/E-series)
2013-03-06 19:46:15,011 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Tiger Cubs-01-2012-6-24.rmvb
2013-03-06 19:46:15,011 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_EU_ISO
2013-03-06 19:46:15,011 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_NA_ISO
2013-03-06 19:46:15,011 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_KO_ISO
2013-03-06 19:46:15,011 DEBUG [VideoDAOImpl] Reading a Video (id = 26676)
2013-03-06 19:46:15,012 DEBUG [MediaItemDAOImpl] Getting file of media item 26676
2013-03-06 19:46:15,035 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Wed, 06 Mar 2013 08:46:15 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.2,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
2013-03-06 19:46:15,043 DEBUG [WebServer] Incoming connection from /192.168.0.251:52851
2013-03-06 19:46:15,043 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.251
2013-03-06 19:46:15,044 DEBUG [ResourceTransportRequestHandler] HEAD /resource/26676/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2013-03-06 19:46:15,044 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.251
2013-03-06 19:46:15,044 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.251, Profile=Samsung TV / player (C/D/E-series)'
2013-03-06 19:46:15,044 DEBUG [ResourceDeliveryProcessor] Request for resource 26676 and type 'MEDIA_ITEM' received
2013-03-06 19:46:15,044 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 26676 (local)
2013-03-06 19:46:15,044 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 26676)
2013-03-06 19:46:15,045 DEBUG [VideoDAOImpl] Reading a Video (id = 26676)
2013-03-06 19:46:15,045 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 26676, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D/E-series)
2013-03-06 19:46:15,045 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Tiger Cubs-01-2012-6-24.rmvb
2013-03-06 19:46:15,045 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_EU_ISO
2013-03-06 19:46:15,045 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_NA_ISO
2013-03-06 19:46:15,045 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_KO_ISO
2013-03-06 19:46:15,046 DEBUG [MediaItemDAOImpl] Getting file of media item 26676
2013-03-06 19:46:15,066 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Wed, 06 Mar 2013 08:46:15 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.2,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
2013-03-06 19:46:15,075 DEBUG [WebServer] Incoming connection from /192.168.0.251:56695
2013-03-06 19:46:15,075 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.251
2013-03-06 19:46:15,076 DEBUG [ResourceTransportRequestHandler] HEAD /resource/26676/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2013-03-06 19:46:15,076 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.251
2013-03-06 19:46:15,076 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.251, Profile=Samsung TV / player (C/D/E-series)'
2013-03-06 19:46:15,076 DEBUG [ResourceDeliveryProcessor] Request for resource 26676 and type 'MEDIA_ITEM' received
2013-03-06 19:46:15,076 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 26676 (local)
2013-03-06 19:46:15,076 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 26676)
2013-03-06 19:46:15,077 DEBUG [VideoDAOImpl] Reading a Video (id = 26676)
2013-03-06 19:46:15,077 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 26676, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D/E-series)
2013-03-06 19:46:15,077 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Tiger Cubs-01-2012-6-24.rmvb
2013-03-06 19:46:15,077 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_EU_ISO
2013-03-06 19:46:15,077 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_NA_ISO
2013-03-06 19:46:15,077 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Tiger Cubs-01-2012-6-24.rmvb: MPEG_TS_SD_KO_ISO
Post Wed Mar 06, 2013 1:48 pm
Can you try to move it to a folder without chinese characters? It might be the problem.
onizuka
Post Sat Mar 09, 2013 11:45 am
Yep, just tried it... no luck :-(
onizuka
Post Sat Apr 27, 2013 9:14 am
Just to add to this, I tried the Sony Bravia TV 2011 and 2012 profiles and they both seemed to allow the RMVB file to be played on my Samsung P51D550.
However, it seems to take a toll on my PC.. with the FFMPeg process maxing out my CPU.
Not sure if this helps you figure out the problem..
onizuka
Post Sat Apr 27, 2013 10:32 am
I added the following the samsung d series profile (this was copied form the Sony 2012 profile)
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="384" DAR="16:9" forceInheritance="true">
            <Matches container="rm" />
Users browsing this forum: Google [Bot] and 19 guests
