Viera ET5 and DLNA streaming issues
new2dlna
Post Sat Apr 27, 2013 9:18 pm
I've recently tried to install Serviio and use it to stream some channels. Unfortunately for me, it has been quite hit-or-miss; I sometimes may get a channel or two but other than that, I usually get an error that reads "Cannot Read File" after the "Please wait a moment" prompt upon picking a stream
I've posted a log about this - thanks a lot for the help in advance
I hope to enjoy these channels and the hard work you guys have put into this!!
serviio2.txt
(283.65 KiB) Downloaded 685 times
slyguy42o
Post Mon Apr 29, 2013 4:03 pm
Re: Viera ET5 and DLNA streaming issues
I think this might be a profile issue. Can you test the streams in VLC just to make sure they are working properly?
I would go ahead and try upgrading ffmpeg to see if it makes a difference.
Post Tue May 07, 2013 9:56 am
Did you try to play many streams in sequence? It looks from the log that it tries to play one stream, then moves onto another after a while. It's possible the chanel is either down or takes a long time to initiate connection.
new2dlna
Post Sat May 11, 2013 2:53 am
Hi guys,
I've tried all profiles - none helped
Zip, I did try to play different streams in sequence. But, I was doing this because basically it tries to connect to the stream for a while, and then gives me a "Cannot read file" error. This happens almost every time
Return to Panasonic
