Transcoding .AVI from Canon camera to Samsung blu-ray
Lax
Post Sun Apr 28, 2013 6:58 am
I cannot get to Serviio to play .AVI video files recorded on my Canon camera. Serviio is running on my iMac OS X ver. 10.8.3, and the receiving device is a Samsung BD-E5700 blu-ray player with display being a Sharp Aquos HDTV. I don't know what to change/add/edit in the profiles.xml file to fix this and I am not conversant with XML. This is my only peeve; otherwise Serviio is fantastic! I have attached below the result of running ffmpeg on a sample .AVI file. Thanks.
Lax
ffmpeg version 1.1.1 Copyright (c) 2000-2013 the FFmpeg developers
built on Jan 29 2013 00:10:12 with gcc 4.0.1 (GCC) (Apple Inc. build 5493)
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-libmp3lame --enable-librtmp --enable-libfreetype --enable-fontconfig --enable-libass --enable-pthreads --disable-mmx --extra-ldflags=-L/Users/MacAdmin/Desktop/build/target/lib --extra-cflags=-I/Users/MacAdmin/Desktop/build/target/include --extra-libs='-lpolarssl -lfreetype -lexpat -liconv'
libavutil 52. 13.100 / 52. 13.100
libavcodec 54. 86.100 / 54. 86.100
libavformat 54. 59.106 / 54. 59.106
libavdevice 54. 3.102 / 54. 3.102
libavfilter 3. 32.100 / 3. 32.100
libswscale 2. 1.103 / 2. 1.103
Guessed Channel Layout for Input Stream #0.1 : mono
Input #0, avi, from '/Volumes/PRASADBOOK/Videos/BalloonFiesta_2012/MVI_4494.AVI':
creation_time : 2012-10-08 07:10:06
encoder : CanonMVI06
Duration: 00:01:50.68, start: 0.000000, bitrate: 14974 kb/s
Stream #0:0: Video: mjpeg (MJPG / 0x47504A4D), yuvj422p, 640x480, 29.97 tbr, 29.97 tbn, 29.97 tbc
Stream #0:1: Audio: pcm_u8 ([1][0][0][0] / 0x0001), 12000 Hz, mono, u8, 96 kb/s
Post Sun Apr 28, 2013 5:13 pm
Re: Transcoding .AVI from Canon camera to Samsung blu-ray
It should be already transcoded when using the c/d/e profile.
Lax
Post Sun Apr 28, 2013 9:21 pm
Hmm... then why does Serviio bring up the dialog 'Not Supported Video Codec" ? It plays other formats (.mov, .mp4, .vob) just fine.
Lax
Post Sun Apr 28, 2013 9:54 pm
I think the FFmpeg in 1.2.x has a bug regarding mjpeg sources. Try the latest FFmpeg from zeranoe.
Lax
Post Mon Apr 29, 2013 4:58 am
Zeranoe seems to have Windows builds. My computer is an iMac running Mountain Lion. Since I didn't install FFMPEG on my Mac (and I seem to have it) is this something that comes built in and is updated by Apple or is it third party that was just factory installed?
Lax
Post Mon Apr 29, 2013 11:15 am
Serviio bundles FFmpeg with it. You will have to either build one yourself or find a repository of the latest OSX builds, and replace the binary inside Serviio.app.
Lax
Post Mon Apr 29, 2013 6:44 pm
Tried it: Went to this location (http://www.evermeet.cx/ffmpeg/) and got latest Mac binary build and replaced old file with this in Serviio.app. No luck...
Post Mon Apr 29, 2013 8:45 pm
Not much I can do then.
Users browsing this forum: Baidu [Spider] and 22 guests
