MKV video seeking issues
sMaxi
Post Mon Apr 29, 2013 8:13 am
I have a bunch of MKV files, which all share a similar problem.
They stream from my Mac to my Samsung UE40ES6307 tv and play for full duration. I am using a Samsung C/D/E profile.
The problems are as follows
- these files always display a "this file may not be playable properly" warning
- seeking is always disabled
- they always have the wrong total duration displayed on TV. For example, the file detailed below has total video time of 24 minutes (which runs for full duration), but TV video progress bar only shows 31 seconds, fills up to full in 31 seconds time and stays full until the end of the video.
I have applied the steps detailed in header.com section of the wiki, to no avail :(
An example of problematic file (post-remux) is below
Unique ID                                : 89803069263481187437495471342377247130 (0x438F71282C4C5728C9DBDAE5045C219A)
Complete name                            : /Users/maxibook/Desktop/tt/qq.mkv
Format version                           : Version 4 / Version 2
File size                                : 47.5 MiB
Duration                                 : 24mn 3s
Overall bit rate                         : 276 Kbps
Encoded date                             : UTC 2013-04-29 07:21:16
Writing application                      : mkvmerge v6.1.0 ('Old Devil') built on Mar  2 2013 22:22:31
Writing library                          : libebml v1.3.0 + libmatroska v1.4.0
Format profile                           : High 10@L3.1
Format settings, ReFrames                : 16 frames
Duration                                 : 24mn 3s
Bit rate                                 : 271 Kbps
Width                                    : 512 pixels
Height                                   : 384 pixels
Display aspect ratio                     : 4:3
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.057
Stream size                              : 46.6 MiB (98%)
Writing library                          : x264 core 124 r2197 69a0443
Encoding settings                        : cabac=1 / ref=16 / deblock=1:1:2 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=26.0 / qcomp=0.60 / qpmin=0 / qpmax=81 / qpstep=4 / ip_ratio=1.40 / aq=1:0.60
below is an example of MKV file which doesn't have this issue and handles seeking properly:
Unique ID                                : 179186935327423683258391989972526584270 (0x86CE2600194613B088711B3A629E51CE)
Complete name                            : /Users/maxibook/Desktop/tt/qq2.mkv
Format version                           : Version 1
File size                                : 230 MiB
Duration                                 : 29mn 13s
Overall bit rate                         : 1 099 Kbps
Encoded date                             : UTC 2007-08-13 23:45:25
Writing application                      : mkvmerge v2.0.2 ('You're My Flame') built on Feb 21 2007 23:40:55
Writing library                          : libebml v0.7.7 + libmatroska v0.8.1
Format profile                           : High@L5.1
Format settings, ReFrames                : 13 frames
Duration                                 : 29mn 13s
Bit rate                                 : 903 Kbps
Width                                    : 704 pixels
Height                                   : 396 pixels
Frame rate                               : 29.970 fps
Bits/(Pixel*Frame)                       : 0.108
Stream size                              : 185 MiB (81%)
Writing library                          : x264 core 56 svn-667C
Encoding settings                        : cabac=1 / ref=10 / deblock=1:-2:-1 / analyse=0x3:0x133 / me=umh / subme=6 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=0 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=903 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
Language                                 : Japanese
Format                                   : MPEG Audio
Format profile                           : Layer 3
Mode                                     : Joint stereo
Mode extension                           : MS Stereo
Codec ID                                 : A_MPEG/L3
Codec ID/Hint                            : MP3
Duration                                 : 29mn 13s
Bit rate                                 : 192 Kbps
Stream size                              : 40.1 MiB (17%)
Language                                 : Japanese
Any help with zeroing in on the problem would be much appreciated.
Post Mon Apr 29, 2013 10:02 am
Re: MKV video seeking issues
On first : Format profile : High 10@L3.1, should be transcode to mpeg2video (High10 not supported).
One second, video track should be only remuxed (not transcoded).
So seeking / total duration, difference are probably due to a different way to provide stream to your device.
sMaxi
Post Mon Apr 29, 2013 12:59 pm
Thanks for the reply :D
The second file plays without issues. Even with no additional remuxing, seeking works alright. I provided it mostly as a point of reference.
The first file does actually play when streamed to my tv through Serviio. I just don't get any seeking.
sMaxi
Post Mon Apr 29, 2013 1:24 pm
Went over the profile xml.
I'm using this profile for my TV:
<Profile id="7" name="Samsung TV / player (C/D/E-series)" extendsProfileId="1">
This profile has, among others, these transcoding options:
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="192">
   <Matches container="*" vCodec="h264" profile="high_10" />
   <Matches container="*" vCodec="h264" profile="high" levelGreaterThan="4.2" />
   <Matches container="*" vCodec="h264" profile="main" levelGreaterThan="4.2" />
So it seems the file is getting transcoded and played on my tv, but it doesn't help the seeking issue.
EDIT: I went and disabled transcoding entirely for High10 (commented as below). It worked! Fixed both the seeking issue and time duration issue.
Thanks for the tip about taking a look into profiles.xml :D
Below are changes i made in profiles.xml (basically commented out 1 string).
   <!-- <Matches container="*" vCodec="h264" profile="high_10" /> -->
sMaxi
Post Tue Apr 30, 2013 11:45 am
Well, it looks like we are not quite done here yet :(
My TV is able to accept H.264 High_10 3.1 without transcoding. However, it needs transcoding for H.264 High_10 5.0 and higher.
So i modified the h.264 section of my profiles.xml in this way:
<!-- Transcode all h264 video with HIGH/MAIN > Level 4.1 on MPEG-TS stream with MPEG2VIDEO and ac3 audio transcoding -->
   <Matches container="*" vCodec="h264" profile="high_10" levelGreaterThan="3.2" />
This made my TV play h264 high_10 3.1 files without issues, and allowed it to play high_10 5.0 files, but with the same seeking issues as before (can't seek and wrong total duration).
It seems that transcoding h264 to mpeg2video screws up seeking, and it is somehow related to total duration being shown wrong.
MediaInfo of one of problematic files:
Unique ID                                : 236544712356093608936023456933193595784 (0xB1F4DABEA1AD3EE2AECC9F49B9263B88)
Complete name                            : /Users/maksimpreobrazenskij/Downloads/_Video ToWatch/Anime/[Hi10]_One_Piece_-_First_Half_Collection/[Ep_207-325]_CP9_Saga/(Hi10)_One_Piece_207_(720p)_(K-F).mkv
File size                                : 125 MiB
Duration                                 : 23mn 5s
Overall bit rate                         : 756 Kbps
Encoded date                             : UTC 2012-07-07 17:27:28
Writing application                      : mkvmerge v4.9.1 ('Ich will') built on Jul 11 2011 23:53:15
Writing library                          : libebml v1.2.1 + libmatroska v1.1.1
Format profile                           : High 10@L5.0
Muxing mode                              : Header stripping
Duration                                 : 23mn 5s
Bit depth                                : 10 bits
Writing library                          : x264 core 125 r2200 999b753
Encoding settings                        : cabac=1 / ref=16 / deblock=1:1:2 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=25.0 / qcomp=0.60 / qpmin=0 / qpmax=81 / qpstep=4 / ip_ratio=1.40 / aq=1:0.60
Codec ID                                 : A_AAC
Duration                                 : 23mn 5s
Mediainfo of the same file after remuxing it with no header compression (still doesn't work, same issues):
Unique ID                                : 134873593640291855854642242969748484213 (0x6577B592B63CC14CB841ED393A51B075)
Complete name                            : /Users/maksimpreobrazenskij/Downloads/qq.mkv
File size                                : 125 MiB
Duration                                 : 23mn 5s
Encoded date                             : UTC 2013-04-30 11:37:42
Duration                                 : 23mn 5s
Bit depth                                : 10 bits
Codec ID                                 : A_AAC
Duration                                 : 23mn 5s
Please tell me if there are any other infos / logs worth taking a look at in terms of figuring out what's going wrong.
Post Fri May 03, 2013 8:53 am
Yes, the Samsungs (c and above) don't deal with the durtion of transcoded files, and I assume that's the reason you cannot seeks then
Users browsing this forum: No registered users and 274 guests
