Serviio rocks!
Bran
Post Tue Apr 30, 2013 12:01 pm
Serviio rocks!
This is by far the best media server I've ever found ;-)
Super quick, reliable and so easy to use.
I love that it's java based and highly customisable.
I use it for my iPad, Samsung tv, Galaxy S2 and a Roku Soundbridge M1001 ^_^
The server runs on a core2duo 2,66 with 4gb's of memory, win7 x64 Ultimate and 3 tB of mediadrives ;-)
Everything works super smooth, every applet I've tried to play files with connect with any issues or even needing to set them up. The one I Currently use is 8Player and ServiiDroid for managing.
Only when I skip the Soundbridge to a different track in the last 15/20 seconds it appears to have frozen. Which I take it is because of the pre-buffering ;-) no worries tho: this is the ONLY media server I've found that plays tracks so seamlessly one after another :-)
I can't find where I need the post these questions, so I'll be 'rude' and post them here :-P
- Is there a way to change how the media library gets presented?
Now it shows the library on the Soundbridg from the first character to the last. But I want the numbers to be grouped together ( 0-9 ) instead of 0, 1, 2, and so on ;-)
One of the other things is that on the Soundbridge artistnames like A&A get stored under & instead of A ;-) just like A State Of Trance goes under S ;-)
- The Roku Soundbridge has the possibility too show the letters on the right, instead as main folders. Is there a way to have it shown this way again? :-) This way I can browse past all the artists name instead of needing to select the letter first ;-)
- Is there a way to change the 'folders' category?
Now I've got two categories: one Folders for movies and one Folders for Pictures ;-)
These are added separate on purpose because the pictures folder has over 100 Gb's of high res photo's ;-)
Thanks for you help peepz!
Again: the MOST AWESOME dlna server EVER!
Thanks to the man behind this terrific piece of essential software :-)
Post Tue Apr 30, 2013 2:09 pm
Re: Serviio rocks!
HI, thanks. CHanging the presentation is no possible, only with a code change. I'll look at the A&A problem.
Post Tue Apr 30, 2013 10:30 pm
Re: Serviio rocks!
Actually, can you describe how to reproduce this? What categories do you browse?
Bran
Post Wed May 01, 2013 8:54 am
Re: Serviio rocks!
I've got an artist name "A & Z" that gets sorted under &. I tried it withouth the spaces as well, but still gets stored under & ;-)
Return to User experiences
