My files (on local USB Disk) are not scanned
matmx5
Post Tue Jul 24, 2012 3:03 pm
I have an external USB hard drive that contains video and music, directly connected to an USB port of my PC.
I added these folders on the Serviio console, but they are not scanned.
What can I do to diagnose the problem?
(The local folders on inside SATA hard disk are scanned correctly)
Thank you for your help.
Mat
Post Wed Jul 25, 2012 4:39 pm
Re: My files (on local USB Disk) are not scanned
read the FAQ
aartimus
Post Tue Apr 30, 2013 5:18 am
I have the same problem. Maybe I'm dense, I looked at the FAQs and didn't see anything that seemed to answer the question. The closest thing seems to be "My files (on remote drive) are not scanned", but other than "Make sure the user that runs Serviio server/service has got access to the shared folders" nothing there applies to a local USB drive.
What am I missing?
Post Tue Apr 30, 2013 2:22 pm
Yes, that is it.
jlcooke
Post Tue Apr 30, 2013 2:54 pm
This may be related... serviio-1.2.1
## ls -l /var/ftp/pub
Movies -> sdc1/Movies
Music -> sdb1/Music
Pictures -> sdc1/Pictures
These are symbolic links to sdc1 and sdb1 in /var/ftp/pub directory. These directories are mount points for some HDs (non-USB but that doesn't matter). Permissions on all folders and mount points are 0755.
Using serviioweb-1.4beta (most current release) I cannot see these symlinks under /var/ftp/pub, nor can I see sub-folders under /var/ftp/pub/sdb1. Almost like serviio (or serviioweb) is deliberately not looking at symlinks or items outside the filesystem of the serviio process.
Post Fri May 03, 2013 8:54 am
check the log to see if the folders are scanned and if there is an access rights issue
jlcooke
Post Fri May 03, 2013 1:16 pm
zip wrote:check the log to see if the folders are scanned and if there is an access rights issue
I do see some, but they're in the sub-directories that I've purposfully blocked.
I'm running Serviio Liunx - the only way to add a library path is with serviio-web UI which may be the source of my problems. If there another way to add a library path (eg. /var/ftp/pub/Music)?
Post Tue May 07, 2013 8:42 am
the ui should work afaik. You should see it being scanned in the log.
jlcooke
Post Tue May 07, 2013 12:37 pm
zip wrote:the ui should work afaik. You should see it being scanned in the log.
I'll ask the UI dev team. Seems to have issues crossing partition bounderies.
eg.
/var/ftp/pub is on Device A
/var/ftp/pub/Music is on Device B
/var/ftp/pub/Movies is on Device C
Users browsing this forum: Baidu [Spider] and 33 guests
