Previously Working Files no Longer working in 1.2.1
Lithosphere83
Post Tue Apr 30, 2013 1:33 pm
Hi Guys,
I opted to upgrade to 1.2.1 a few weeks ago and I saw that some of my HD videos are no longer working. They were previously working in the older version (the main reason I switched to serviio) but now it no longer works. I am using a samsung series 5 TV connected via the ethernet. I checked the profile and it was still set to Samsung CDE TV series. I read around the forums and tried changing it to Direct TV, it worked but it now transcodes every video that I play with the TV. I haven't switched back to the older version because i love the update in which it can now play embedded subtitles in mkv/mp4 files which saves me a lot of time in ripping subs. One thing I have noticed that has changed is that in the device name it no longer detects it as a samsung tv(LAC3something) it now says unrecognized device in the ip address of the TV. Hope to get your inputs on how to resolve this issue. thanks!
Post Tue Apr 30, 2013 2:21 pm
Re: Previously Working Files no Longer working in 1.2.1
post detailed log of playing the file
Lithosphere83
Post Wed May 01, 2013 10:35 am
Hi Zip,
Thanks for the reply.
I have attached the detailed log of the the file playing while on the Direct TV HDTV profile (works properly) and on the Samsung CDE Series TV (Gives Error of "Video Codec Not Supported")
I'm not sure if this is useful but I used mediaInfo to check the video type. Below is the result:
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 1h 33mn
Bit rate : 801 Kbps
Maximum bit rate : 6 090 Kbps
Width : 1 280 pixels
Height : 536 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.049
Stream size : 536 MiB (89%)
Writing library : x264 core 125 r2200 999b753
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=2 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=801 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Encoded date : UTC 2012-11-02 14:41:00
Tagged date : UTC 2012-11-02 14:41:08
Samsung CDE Series Profile.txt
(10.4 KiB) Downloaded 444 times
Playing File under DirectTV HD Profile.txt
(10.39 KiB) Downloaded 479 times
Post Wed May 01, 2013 1:06 pm
both of the logs use DirecTV profile
Lithosphere83
Post Wed May 01, 2013 1:28 pm
Hi Zip,
Don't know what happened there but attached is the correct file.
Using Samsung CDE Profile in Serviio.txt
(35.12 KiB) Downloaded 549 times
Post Wed May 01, 2013 4:24 pm
OK, there should be some more above in the log. Basically, you probably have Burning subtitles in turned on (which you don't need for Samsung TVs). Then FFmpeg is failing to burn the subtitles in, but the error is further up in the log.
AndyMe
Post Wed May 01, 2013 4:56 pm
After my experience of 1.2.1 not doing stuff that 1.2 would do, perhaps upgrading your ffmpeg would fix this.
I'm new(ish) to all this, but it's just a thought and sorry if it's complete rubbish.
Lithosphere83
Post Thu May 02, 2013 3:27 am
Hi Zip,
It totally worked! I just unchecked "Enable Burned-in Subtitles" and it played beautifully but upon checking another file is not working. I have attached the log, the ffmpeg -i and the result from media info.
Media Info
Unique ID                                : 180824034471708538063800175885838209788 (0x880971384E19A9198ADA1D93331452FC)
Complete name                            : B:\My Movies\[Tsuki]_Hunter_X_Hunter_-_65_[10bit][1280x720][5C7069E1].mkv
File size                                : 325 MiB
Duration                                 : 23mn 37s
Overall bit rate                         : 1 921 Kbps
Encoded date                             : UTC 2013-02-05 11:52:37
Writing application                      : mkvmerge v3.0.0 ('Hang up your Hang-Ups') built on Dec 12 2009 15:20:35
Writing library                          : libebml v0.7.9 + libmatroska v0.8.1
Attachment                               : Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes
Format profile                           : High 10@L4.1
Format settings, ReFrames                : 9 frames
Duration                                 : 23mn 37s
Bit depth                                : 10 bits
Writing library                          : x264 core 125 r2208 d9d2288
Encoding settings                        : cabac=1 / ref=9 / deblock=1:-2:-2 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=0.60:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=crf / mbtree=0 / crf=18.0 / qcomp=0.60 / qpmin=10 / qpmax=38 / qpstep=4 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:0.60
Codec ID                                 : A_AAC
Duration                                 : 23mn 37s
Sampling rate                            : 44.1 KHz
Language                                 : Japanese
Forced                                   : Yes
Text
Format                                   : ASS
Codec ID                                 : S_TEXT/ASS
Codec ID/Info                            : Advanced Sub Station Alpha
Compression mode                         : Lossless
ffmpeg -i
C:\Program Files\Serviio\lib>ffmpeg.exe -i "b:\my movies\[Tsuki]_Hunter_X_Hu
ffmpeg version 1.1.1 Copyright (c) 2000-2013 the FFmpeg developers
  built on Feb  5 2013 21:59:54 with gcc 4.7.2 (GCC)
  configuration: --enable-static --disable-shared --disable-ffplay --disable
erver --enable-memalign-hack --enable-libmp3lame --enable-libass --enable-li
p --enable-fontconfig --enable-libfreetype --enable-zlib --extra-libs='-lrtm
polarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --ena
runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-
mingw32- --pkg-config=pkg-config
  libavutil      52. 13.100 / 52. 13.100
  libavcodec     54. 86.100 / 54. 86.100
  libavformat    54. 59.106 / 54. 59.106
  libavdevice    54.  3.102 / 54.  3.102
  libavfilter     3. 32.100 /  3. 32.100
  libswscale      2.  1.103 /  2.  1.103
Input #0, matroska,webm, from 'b:\my movies\[Tsuki]_Hunter_X_Hunter_-_65_[10
[1280x720][5C7069E1].mkv':
    creation_time   : 2013-02-05 11:52:37
  Duration: 00:23:37.39, start: 0.000000, bitrate: 1921 kb/s
    Stream #0:0(eng): Video: h264 (High 10), yuv420p10le, 1280x720, SAR 1:1
16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
    Stream #0:1(jpn): Audio: aac, 44100 Hz, stereo, fltp (forced)
    Stream #0:2: Subtitle: ssa (default)
Codec 0x18000 is not in the full list.
    Stream #0:3: Attachment: unknown_codec
      filename        : DCKgmc.ttc
      mimetype        : application/x-truetype-font
    Stream #0:4: Attachment: unknown_codec
      filename        : DFLis6.ttc
    Stream #0:5: Attachment: unknown_codec
      filename        : leelawad.ttf
    Stream #0:6: Attachment: unknown_codec
      filename        : leelawdb.ttf
    Stream #0:7: Attachment: unknown_codec
      filename        : ltromatic.ttf
    Stream #0:8: Attachment: unknown_codec
      filename        : Montara-Gothic.otf
    Stream #0:9: Attachment: unknown_codec
      filename        : PIE4MAP.TTF
    Stream #0:10: Attachment: unknown_codec
      filename        : timesbd.ttf
    Stream #0:11: Attachment: unknown_codec
      filename        : BAARS___.TTF
Hi10p h.264 file not playing.log
(49.45 KiB) Downloaded 411 times
Lithosphere83
Post Thu May 02, 2013 3:29 am
Hi Andyme,
I was about to do that but upon checking the serviio logs it actually tries to check and update the ffmpeg file. BTW im using Windows 7 64-bit.
slyguy42o
Post Thu May 02, 2013 2:43 pm
take a look at this guide
http://wiki.serviio.org/doku.php?id=win_ffmpeg
ffmpeg doesn't update through serviio, it only uses the copy that is included.
Users browsing this forum: No registered users and 226 guests
