Xbox 360 5.1 channel transcoding problem
deviruchi
Post Mon Apr 29, 2013 8:36 pm
I'm having the exact same issue as this post here: viewtopic.php?f=5&t=7487&p=53101
However, either the ticket didn't come to fruition or the fix didn't work as I'm on the latest version of serviio. Windows 8 x64
The file I'm having issues with has the following ffmpeg -i output
ffmpeg version 1.1.1 Copyright (c) 2000-2013 the FFmpeg developers
  built on Feb  5 2013 21:59:54 with gcc 4.7.2 (GCC)
p --enable-fontconfig --enable-libfreetype --enable-zlib --extra-libs='-lrtmp -l
polarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-
runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-
mingw32- --pkg-config=pkg-config
  libavutil      52. 13.100 / 52. 13.100
  libavcodec     54. 86.100 / 54. 86.100
  libavformat    54. 59.106 / 54. 59.106
  libavdevice    54.  3.102 / 54.  3.102
  libavfilter     3. 32.100 /  3. 32.100
  libswscale      2.  1.103 /  2.  1.103
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'N:\file.mp4':
    major_brand     : isom
    minor_version   : 1
    compatible_brands: isomavc1
    creation_time   : 2011-06-30 13:31:47
    composer        : nothing
  Duration: 02:07:29.83, start: 0.000000, bitrate: 3179 kb/s
    Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1280x528, 2738 kb/s, 23.98 fps, 23.98 tbr, 24k tbn, 47.95 tbc
      handler_name    : Video
    Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, 5.1, fltp, 438 kb/s
      creation_time   : 2011-06-30 13:32:51
      handler_name    : GPAC ISO Audio Handler
Since the error I'm getting from my xbox 360 is that the audio is the problem, and this is backed up by the above forum post, I manually transcoded with ffmpeg and the following command:
ffmpeg -i "N:\file.mp4" -ac 2 -strict -2 "N:\file2.mp4"
The -strict -2 params are required because of an apparent experimental aac support in ffmepg.
Once I'd completed the transcoding (the default q=31 is horrible, but it proved the theory) the video played from my xbox.
Post Wed May 01, 2013 1:03 pm
Re: Xbox 360 5.1 channel transcoding problem
deviruchi
Post Wed May 01, 2013 8:15 pm
Thanks zip, I had a feeling it was something you knew about :)
It's literally the only problem I've had with Serviio, so if you can crack it I'll be a happy camper (and I might even go pro even if I don't need those extra features! :) )
Cracking software, though. Much more stable than tversity...
Users browsing this forum: No registered users and 227 guests
