Unable to run serviio console
chunu
Post Fri May 03, 2013 7:05 pm
Serviio was working fine on my laptop (windows 7 64bit)
yesterday i restore system on early date after restoration serviio stop working i uninstall and then re-install again no error during installation but when try to run serviio console it doesn't start.
any solution ????
Post Fri May 03, 2013 11:55 pm
Re: Unable to run serviio console
Check that Java is installed correctly (may pay to reinstall it). Otherwise post your Serviio log file - it may shed some light on the problem.
chunu
Post Fri May 31, 2013 12:52 pm
DenyAll wrote:Check that Java is installed correctly (may pay to reinstall it). Otherwise post your Serviio log file - it may shed some light on the problem.
Thank Denyall
I reinstall java ...problem solved
Return to General discussion
Users browsing this forum: Google [Bot] and 27 guests
