Files not showing in certain folders.
ALLEyezOnMe
Post Sun May 05, 2013 12:07 am
Hello, I am trying to stream movies from my PC to my Samsung EH6030 TV. I have shared 3 folders - Movies, TV Shows and Music Videos. Weird thing is both the TV Shows and Music Videos folders are properly shared and they contain all the right files, but for some reason the Movies folder is empty. I have removed/added it several times, forced refreshes and whatnot, it just doesn't want to show the folder's contents, it comes empty. All the shared folders are with the same permissions and on the same hard disk drive. This is quite annoying. Furthermore, when I copy/move a file from Movies to TV Shows/Music Videos, the file shows up just fine. Any suggestions? Thanks for your time.
Here is the .log entry:
2013-05-06 01:35:29,779 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Movies
2013-05-06 01:35:29,779 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Movies\Cloud Atlas (2012) 1080p BluRay x264 DTS-LTRG
2013-05-06 01:35:29,779 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Movies\Dark Skies 2013 WEBRiP V2 FIX XviD READNFO-THC
2013-05-06 01:35:29,779 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Movies\Deadfall.2012.BluRay.1080p.DTS.x264-CHD
2013-05-06 01:35:29,779 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Movies\House.At.The.End.Of.The.Street.2012.1080p.BluRay.x264-SPARKS
2013-05-06 01:35:29,779 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Movies\Intruders.2011.LIMITED.1080p.BluRay.x264-SPARKS
2013-05-06 01:35:29,779 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Movies\Kecove.2011.DVDRip.XviD-AsA
2013-05-06 01:35:29,779 DEBUG [LibraryAdditionsCheckerThread] Found file 'asa-kecove-dvdrip.avi', checking if it's already in the Library
2013-05-06 01:35:29,779 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item asa-kecove-dvdrip.avi
2013-05-06 01:35:29,779 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Movies\Kecove.2011.DVDRip.XviD-AsA\asa-kecove-dvdrip.avi, ignore case: true
2013-05-06 01:35:29,779 DEBUG [MediaItemDAOImpl] Media item asa-kecove-dvdrip.avi doesn't exist in DB yet
2013-05-06 01:35:29,794 DEBUG [LibraryAdditionsCheckerThread] File not in Library, will add it
2013-05-06 01:35:29,794 DEBUG [VideoExtractionStrategy] Extracting metadata of video file: D:\Movies\Kecove.2011.DVDRip.XviD-AsA\asa-kecove-dvdrip.avi
2013-05-06 01:35:29,794 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: D:\Movies\Kecove.2011.DVDRip.XviD-AsA\asa-kecove-dvdrip.avi
2013-05-06 01:35:29,794 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i D:\Movies\Kecove.2011.DVDRip.XviD-AsA\asa-kecove-dvdrip.avi
2013-05-06 01:35:29,748 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 122) and extractor COVER_IMAGE_IN_FOLDER
2013-05-06 01:35:29,794 DEBUG [MediaItemDAOImpl] Getting file of media item 123
2013-05-06 01:35:29,794 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 123) and extractor EMBEDDED
2013-05-06 01:35:29,794 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 123) and extractor COVER_IMAGE_IN_FOLDER
2013-05-06 01:35:29,794 DEBUG [MediaItemDAOImpl] Getting file of media item 124
2013-05-06 01:35:29,794 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 124) and extractor EMBEDDED
2013-05-06 01:35:29,794 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 124) and extractor COVER_IMAGE_IN_FOLDER
2013-05-06 01:35:29,810 DEBUG [LibraryUpdatesCheckerThread] Looking for removed playlist files in repository: D:\Movies
2013-05-06 01:35:29,810 DEBUG [PlaylistDAOImpl] Reading Playlists for Repository (id = 13)
2013-05-06 01:35:29,810 DEBUG [LibraryUpdatesCheckerThread] Looking for removed/updated files in repository: D:\Movies
2013-05-06 01:35:29,810 DEBUG [MediaItemDAOImpl] Reading MediaItems for Repository (id = 13)
2013-05-06 01:35:29,810 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 3)
2013-05-06 01:35:29,810 DEBUG [RepositoryDAOImpl] Marking Repository 3 as scanned with current timestamp
2013-05-06 01:35:29,810 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 6)
2013-05-06 01:35:29,810 DEBUG [RepositoryDAOImpl] Marking Repository 6 as scanned with current timestamp
2013-05-06 01:35:29,810 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 13)
2013-05-06 01:35:29,826 DEBUG [RepositoryDAOImpl] Marking Repository 13 as scanned with current timestamp
2013-05-06 01:35:29,873 WARN  [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video file type.
2013-05-06 01:35:29,873 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Movies\Kecove.2011.DVDRip.XviD-AsA\Sample
2013-05-06 01:35:29,873 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Movies\Mama.2013.720p.BRRiP.XViD.AC3-LEGi0N
2013-05-06 01:35:29,873 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Movies\Operacia.Shmenti.kapeli.2011.PDTV.x264.AAC-SiSO
2013-05-06 01:35:29,873 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Movies\Recreator.2012.BDRip.XVID.AC3.HQ.Hive-CM8
2013-05-06 01:35:29,873 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Movies\The.Box.720p.Bluray.x264-CBGB
2013-05-06 01:35:29,873 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Movies\The.Duel.2011.DVDRip.XviD-VoMiT
2013-05-06 01:35:29,873 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Movies\The.Duel.2011.DVDRip.XviD-VoMiT\Sample
2013-05-06 01:35:29,873 DEBUG [LibraryAdditionsCheckerThread] Found file 'The.Duel.2011.DVDRip.XviD-VoMiT.avi', checking if it's already in the Library
2013-05-06 01:35:29,873 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The.Duel.2011.DVDRip.XviD-VoMiT.avi
2013-05-06 01:35:29,873 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Movies\The.Duel.2011.DVDRip.XviD-VoMiT\The.Duel.2011.DVDRip.XviD-VoMiT.avi, ignore case: true
2013-05-06 01:35:29,873 DEBUG [MediaItemDAOImpl] Media item The.Duel.2011.DVDRip.XviD-VoMiT.avi doesn't exist in DB yet
2013-05-06 01:35:29,873 DEBUG [LibraryAdditionsCheckerThread] File not in Library, will add it
2013-05-06 01:35:29,873 DEBUG [VideoExtractionStrategy] Extracting metadata of video file: D:\Movies\The.Duel.2011.DVDRip.XviD-VoMiT\The.Duel.2011.DVDRip.XviD-VoMiT.avi
2013-05-06 01:35:29,873 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: D:\Movies\The.Duel.2011.DVDRip.XviD-VoMiT\The.Duel.2011.DVDRip.XviD-VoMiT.avi
2013-05-06 01:35:29,888 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i D:\Movies\The.Duel.2011.DVDRip.XviD-VoMiT\The.Duel.2011.DVDRip.XviD-VoMiT.avi
2013-05-06 01:35:29,951 WARN  [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video file type.
2013-05-06 01:35:29,951 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Movies\The.Tall.Man.2012.1080p.BluRay.x264.DTS-HDChina
2013-05-06 01:35:29,951 DEBUG [RepositoryDAOImpl] Marking Repository 13 as scanned with current timestamp
ALLEyezOnMe
Post Mon May 06, 2013 12:12 pm
Re: Files not showing in certain folders.
Up :)
slyguy42o
Post Mon May 06, 2013 4:44 pm
might be a profile issue. Can you try connecting to your serviio server via VLC and see if you can see the movies?
ALLEyezOnMe
Post Mon May 06, 2013 7:14 pm
slyguy42o wrote:might be a profile issue. Can you try connecting to your serviio server via VLC and see if you can see the movies?
No, I can not see the contents of the "Movies" folder under VLC as well. Here is a screenshot:
Post Tue May 07, 2013 12:39 am
Firstly, to check the obvious - have you checked the sharing in Serviio Console to ensure you have videos selected.
A suggestion. Try
  • create a new folder "Movies1" under TV Shows (to inherit all permissions etc). Then move the folder where you want it
  • share this folder in Serviio console, ensuring you tick Videos
  • move a couple of videos to the new folder and refresh the Serviio library. See if you can see the files
  • if you can see the files then move all the files, delete the old Movies folder and rename the new folder to Movies. Adjust the shared folders in Serviio Console and refresh library. Test again
Realise this is bypassing rather than solving the problem but if this works it must have been a permissions issue with the folder.
Post Tue May 07, 2013 9:14 am
from the log it looks like the file has been added. Can you see the folder in Mediabrowser (if you still have the evaluation version)?
ALLEyezOnMe
Post Tue May 07, 2013 12:57 pm
DenyAll wrote:Firstly, to check the obvious - have you checked the sharing in Serviio Console to ensure you have videos selected.
A suggestion. Try
Your suggestion actually worked, mate :) Thanks a million, good call!
zip wrote:from the log it looks like the file has been added. Can you see the folder in Mediabrowser (if you still have the evaluation version)?
What do you mean by that? Are you referring to the Media Browser software? If so, I downloaded it and added the "Movies" folder. What should I be looking for?
Post Wed May 08, 2013 9:58 am
No problems - happy to help.
MediaBrowser isn't external software (ie. you didn't need to download anything). It comes with Serviio Pro (yours free to try for the first 15 days with Serviio). To access it, go to the "Remote Tab" on serviio Console, enter a password in the area provided if you haven't already done so, and select the "Open MediaBrowser" link at the bottom of the tab. You will then go to your favorite web browse which will prompt you for a password... if you are still in your 15 day trial period or have upgraded to Pro, then MediaBrowser will open (if not, it will tell you your password is incorrect).
Read all about MediaBrowser here. Cheers.
Users browsing this forum: Baidu [Spider], Google [Bot] and 26 guests
