Volatile Serviio directory location
Post Mon May 06, 2013 2:35 pm
Currently the library, config and plugin subdirectories are located within the C drive Serviio directory, but are subject to change as Serviio is used. That means that when I restore my Windows C drive System Image all my subsequent changes are lost. How do I get Serviio to use my D drive for those volatile subs?
Post Tue May 07, 2013 8:34 am
Re: Volatile Serviio directory location
Currently you can change the library location, see the system properties or serviio.bat
Post Tue May 07, 2013 7:50 pm
Great. Seems I can also change the plugin location as per http://www.serviio.org/index.php?option ... icle&id=42
Post Wed May 08, 2013 8:41 am
Yes.
Return to Feature requests
