don't recognize my es6100 anymore
pmartynas
Post Sun May 05, 2013 4:03 pm
Hi, serviio can't recognize my es6100 anymore, in console it just shows it as "unrecognized device". I'm using 1.2.1 on OSX. Though my TV finds serviio server, i can browse files, even play some of them. Restarting/reinstalling doesn't help. Downgrading to 1.1 neither helps.
I'm not 100% sure but I think it started happening after I've upgraded my TV to the newest firmware version 001033
slyguy42o
Post Mon May 06, 2013 5:26 pm
Re: don't recognize my es6100 anymore
try manually selecting one of the Samsung profiles in the console to see if that helps.. the firmware update prolly screwed up the auto detect for this device.
Post Tue May 07, 2013 9:49 am
It doesn't matter. The TV name probably changed. Just make sure you still use the C/D/E profile.
allmac
Post Tue May 21, 2013 3:35 pm
Same problem... did your suggestion. Not solved.
