Different Libray Update Times
mmarauder
Post Tue May 07, 2013 4:41 am
I have a lot of files managed through serviio so when update runs it can take a while to go through all the folders on my sync list. Some of these folders do not need to be updated as often as other though. For example, my music only needs to be updated daily at most, whereas, my TV Shows I want updated as soon as possible. My suggestion is to be able to set the refresh time for each folder individually or at least be able to group the folders into different upload groups.
slyguy42o
Post Tue May 07, 2013 7:05 pm
Re: Different Libray Update Times
allows you to fine tune resource usage.. I like it.
Return to Feature requests
