[Resolved] Serviio Console won't start Win7x64
fazelanvari
Post Tue May 07, 2013 6:59 am
Hello. I just installed Serviio and the console will not start. I've used it before on my other system, but it's dead right now :(
I've confirmed the service is running, but the console just won't start. I've also tried installing the WebUI, but it also won't start. That leads me to believe something is wrong with the Serviio service, but who knows.
I uninstalled and reinstalled Serviio, and I still had the same problems.
logs:
i4j_nlog_2:
Started executable c:\Program Files\Serviio\bin\ServiioConsole.exe at Tue May 07 01:47:09 2013
number of sections: 6
size of optional headers: 240
resSectionTableStart: 688
rawDataSize: 2048, rawDataOffset: 566784
sun.locale.formatasdefault is true
language/country is en_US
change working directory to c:\Program Files\Serviio\bin
calling C:\windows\explorer.exe /select,C:\Users\afazel\AppData\Local\Temp\I4J_NL~1
semaphore name Local\c:_program_files_pc5dczc_bin_serviioconsole.exe0, code 0, value 00000000000000E8
extracting files
Included files: 2
GetTempPath returned 35 (last error 183)
make dir returned -1
tempPath is C:\Users\afazel\AppData\Local\Temp\
tempFile is C:\Users\afazel\AppData\Local\Temp\e4j4D84.tmp
Temp dir: C:\Users\afazel\AppData\Local\Temp\e4j4D84.tmp_dir1367909234
extracting C:\Users\afazel\AppData\Local\Temp\e4j4D84.tmp_dir1367909234\exe4jlib.jar (size: 29885)
extracting C:\Users\afazel\AppData\Local\Temp\e4j4D84.tmp_dir1367909234\i4jdel.exe (size: 35224)
extracting files done
native lib dir is
Setting PATH (native libs) C:\Program Files (x86)\OSSBuild\GStreamer\v0.10.6\bin;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Common Files\Teleca Shared;C:\AndroidSDK;C:\AndroidSDK\platform-tools;C:\Program Files (x86)\QT Lite\QTSystem;C:\Program Files\WIDCOMM\Bluetooth Software\;C:\Program Files\WIDCOMM\Bluetooth Software\syswow64;C:\Program Files (x86)\QT Lite\QTSystem\
LoadDLL (1, (null), 0)
Searching for a JVM
GetTempPath returned 35 (last error 3)
Testing location  (type Y)
checkJavaExe (C:\Program Files\Java\jre6\bin\java.exe, [out], 1.6, , 0)
file exists
got version from registry 1.6.0_19
checkJavaExe returning 1
found sun c:\program files\java\jre6\bin\javaw.exe 1.6.0_19
Trying to load JVM-DLL from c:\program files\java\jre6\bin\javaw.exe
Setting PATH C:\Program Files (x86)\OSSBuild\GStreamer\v0.10.6\bin;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Common Files\Teleca Shared;C:\AndroidSDK;C:\AndroidSDK\platform-tools;C:\Program Files (x86)\QT Lite\QTSystem;C:\Program Files\WIDCOMM\Bluetooth Software\;C:\Program Files\WIDCOMM\Bluetooth Software\syswow64;C:\Program Files (x86)\QT Lite\QTSystem\;c:\program files\java\jre6\bin
Trying c:\program files\java\jre6\bin\hotspot\jvm.dll (exists 0)
Trying c:\program files\java\jre6\bin\client\jvm.dll (exists 0)
Trying c:\program files\java\jre6\bin\server\jvm.dll (exists 1)
Loading of JVM-DLL successful
launching program
GetTempPath returned 35 (last error 6)
expanding %EXE4J_EXEDIR% to c:\Program Files\Serviio\bin\ in -Xms5M -XX:+UseParNewGC -XX:MinHeapFreeRatio=5 -XX:MaxHeapFreeRatio=10 -Djava.net.preferIPv4Stack=true -Dserviio.home='c:\Program Files\Serviio\bin\\..'.
adding options
vmoptions: exe file: c:\Program Files\Serviio\bin\ServiioConsole.exe, long: c:\Program Files\Serviio\bin\ServiioConsole.exe, opts1: c:\Program Files\Serviio\bin\ServiioConsole.vmoptions, file: 0000000000000000
vmoptions: opts2: c:\Program Files\Serviio\bin\ServiioConsole.exe.vmoptions, file: 0000000140031A60
default vmoptions file: 0000000140031A60
classpath entry S0..\.\lib;D0..\.\config;
GetTempPath returned 35 (last error 2)
vmoption count 14
vmoption 0: -Dexe4j.semaphoreName=Local\c:_program_files_pc5dczc_bin_serviioconsole.exe0
vmoption 1: -Dexe4j.moduleName=c:\Program Files\Serviio\bin\ServiioConsole.exe
vmoption 2: -Dsun.java.command=c:\Program Files\Serviio\bin\ServiioConsole.exe
vmoption 3: -Dexe4j.tempDir=C:\Users\afazel\AppData\Local\Temp\e4j4D84.tmp_dir1367909234
vmoption 4: -Dexe4j.unextractedPosition=636444
vmoption 5: -Djava.library.path=C:\Program Files (x86)\OSSBuild\GStreamer\v0.10.6\bin;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Common Files\Teleca Shared;C:\AndroidSDK;C:\AndroidSDK\platform-tools;C:\Program Files (x86)\QT Lite\QTSystem;C:\Program Files\WIDCOMM\Bluetooth Software\;C:\Program Files\WIDCOMM\Bluetooth Software\syswow64;C:\Program Files (x86)\QT Lite\QTSystem\;c:\program files\java\jre6\bin
vmoption 6: -Dexe4j.consoleCodepage=cp0
vmoption 7: -Xms5M
vmoption 8: -XX:+UseParNewGC
vmoption 9: -XX:MinHeapFreeRatio=5
vmoption 10: -XX:MaxHeapFreeRatio=10
vmoption 11: -Djava.net.preferIPv4Stack=true
vmoption 12: -Dserviio.home=c:\Program Files\Serviio\bin\\..
vmoption 13: -Djava.class.path=C:\Users\afazel\AppData\Local\Temp\e4j4D84.tmp_dir1367909234\exe4jlib.jar;c:\Program Files\Serviio\bin\..\.\lib\commons-codec.jar;c:\Program Files\Serviio\bin\..\.\lib\commons-io.jar;c:\Program Files\Serviio\bin\..\.\lib\commons-jxpath.jar;c:\Program Files\Serviio\bin\..\.\lib\commons-lang.jar;c:\Program Files\Serviio\bin\..\.\lib\concurrent.jar;c:\Program Files\Serviio\bin\..\.\lib\derby.jar;c:\Program Files\Serviio\bin\..\.\lib\freemarker.jar;c:\Program Files\Serviio\bin\..\.\lib\groovy-all.jar;c:\Program Files\Serviio\bin\..\.\lib\gson.jar;c:\Program Files\Serviio\bin\..\.\lib\httpcore.jar;c:\Program Files\Serviio\bin\..\.\lib\jaudiotagger.jar;c:\Program Files\Serviio\bin\..\.\lib\jcl-over-slf4j.jar;c:\Program Files\Serviio\bin\..\.\lib\jcs.jar;c:\Program Files\Serviio\bin\..\.\lib\jdom.jar;c:\Program Files\Serviio\bin\..\.\lib\jnat-pmplib.jar;c:\Program Files\Serviio\bin\..\.\lib\jul-to-slf4j.jar;c:\Program Files\Serviio\bin\..\.\lib\log4j.jar;c:\Program Files\Serviio\bin\..\.\lib\org.restlet.ext.gson.jar;c:\Program Files\Serviio\bin\..\.\lib\org.restlet.ext.net.jar;c:\Program Files\Serviio\bin\..\.\lib\org.restlet.ext.xstream.jar;c:\Program Files\Serviio\bin\..\.\lib\org.restlet.jar;c:\Program Files\Serviio\bin\..\.\lib\padlock.jar;c:\Program Files\Serviio\bin\..\.\lib\rome-modules.jar;c:\Program Files\Serviio\bin\..\.\lib\rome.jar;c:\Program Files\Serviio\bin\..\.\lib\sanselan.jar;c:\Program Files\Serviio\bin\..\.\lib\sbbi-upnp.jar;c:\Program Files\Serviio\bin\..\.\lib\serviio-client.jar;c:\Program Files\Serviio\bin\..\.\lib\serviio-media-browser.jar;c:\Program Files\Serviio\bin\..\.\lib\serviio.jar;c:\Program Files\Serviio\bin\..\.\lib\slf4j-api.jar;c:\Program Files\Serviio\bin\..\.\lib\slf4j-log4j12.jar;c:\Program Files\Serviio\bin\..\.\lib\winp.jar;c:\Program Files\Serviio\bin\..\.\lib\xstream.jar;c:\Program Files\Serviio\bin\..\.\config;
Creating JVM
serviio.log with detailed debugging:
2013-05-07 01:35:17,966 INFO  [MediaServer] ------------------------------------------------------------------------
2013-05-07 01:35:17,967 INFO  [MediaServer] Serviio DLNA media streaming server v 1.2.1 (rev. a2aa56064460+)
2013-05-07 01:35:17,967 INFO  [MediaServer] Petr Nejedly 2009-2013
2013-05-07 01:35:17,967 INFO  [MediaServer] http://www.serviio.org
2013-05-07 01:35:17,967 INFO  [MediaServer] Java 1.6.0_19-Sun Microsystems Inc.
2013-05-07 01:35:17,967 INFO  [MediaServer] OS Windows 7 amd64 6.1
2013-05-07 01:35:17,967 INFO  [MediaServer] File encoding: windows-1252
2013-05-07 01:35:17,967 INFO  [MediaServer] Headless mode enabled: true
2013-05-07 01:35:17,967 INFO  [MediaServer] User: AFAZEL-LAPTOP$
2013-05-07 01:35:17,967 INFO  [MediaServer] User home dir: C:\
2013-05-07 01:35:17,967 INFO  [MediaServer] Temp dir: C:\windows\TEMP\
2013-05-07 01:35:17,968 INFO  [MediaServer] ------------------------------------------------------------------------
2013-05-07 01:35:18,090 INFO  [WebServer] Socket buffer set to 65535 bytes
2013-05-07 01:35:18,092 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-05-07 01:35:18,126 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-05-07 01:35:18,127 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-05-07 01:35:18,140 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-05-07 01:35:21,751 INFO  [DBSchemaUpdateExecutor] Updating DB schema
2013-05-07 01:35:27,330 INFO  [DBSchemaUpdateExecutor] Cleaning persistent cache
2013-05-07 01:35:27,971 INFO  [Device] Created UPnP Device with UUID: 1dc59d19-f7a1-31e2-81d8-fa90987267ff, bound address: 192.168.0.123
2013-05-07 01:35:27,978 WARN  [IndexedDiskCache] Region [online_technical_metadata] Reseting cache
2013-05-07 01:35:28,336 INFO  [MediaServer] ------------------------------------------------------------------------
2013-05-07 01:35:28,336 INFO  [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2013-05-07 01:35:28,608 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2013-05-07 01:35:28,741 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2013-05-07 01:35:28,750 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2013-05-07 01:35:28,753 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2013-05-07 01:35:28,754 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2013-05-07 01:35:28,754 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2013-05-07 01:35:28,758 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2013-05-07 01:35:28,760 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2013-05-07 01:35:28,760 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2013-05-07 01:35:28,764 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2013-05-07 01:35:28,766 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2013-05-07 01:35:28,771 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2013-05-07 01:35:28,772 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2013-05-07 01:35:28,773 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2013-05-07 01:35:28,774 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2013-05-07 01:35:28,776 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2013-05-07 01:35:28,777 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2013-05-07 01:35:28,778 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2013-05-07 01:35:28,779 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2013-05-07 01:35:28,780 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2013-05-07 01:35:28,781 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2013-05-07 01:35:28,782 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2013-05-07 01:35:28,783 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2013-05-07 01:35:28,784 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2013-05-07 01:35:28,785 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2013-05-07 01:35:28,786 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2013-05-07 01:35:28,787 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2013-05-07 01:35:28,788 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2013-05-07 01:35:28,789 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2013-05-07 01:35:28,789 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2013-05-07 01:35:28,790 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2013-05-07 01:35:28,792 INFO  [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2013-05-07 01:35:28,792 INFO  [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2013-05-07 01:35:28,793 INFO  [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2013-05-07 01:35:28,796 INFO  [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2013-05-07 01:35:28,841 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2013-05-07 01:35:28,843 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2013-05-07 01:35:28,844 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2013-05-07 01:35:28,845 INFO  [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2013-05-07 01:35:28,859 INFO  [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2013-05-07 01:35:28,860 INFO  [PluginCompilerThread] Started looking for plugins
2013-05-07 01:35:28,862 INFO  [UpdateChecker] Checking if a new version is available
2013-05-07 01:35:29,205 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-05-07 01:35:29,234 INFO  [WebServer] WebServer starting on port 8895
2013-05-07 01:35:29,242 INFO  [EventDispatcher] Starting EventDispatcher
2013-05-07 01:35:29,243 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-05-07 01:35:29,247 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-05-07 01:35:29,248 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2013-05-07 01:35:29,410 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net3 (Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC) and address 192.168.0.123, timeout = 0
2013-05-07 01:35:29,413 INFO  [RendererSearchSender] Searching for Renderer devices
2013-05-07 01:35:30,581 INFO  [RendererManager] Stored a new renderer: uuid='31891429-3205-2000-0000-002248c6120f', name = 'Xbox 360', ipAddress='192.168.0.147', profile = '3'
2013-05-07 01:35:55,436 INFO  [FeedUpdaterThread] Started looking for information about online resources
2013-05-07 01:35:55,443 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-05-07 01:35:55,454 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-05-07 01:35:55,454 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2013-05-07 01:44:30,771 INFO  [RendererManager] Stored a new renderer: uuid='298e493b-935a-4f56-b2e6-68de87572a64', name = 'Unrecognized device', ipAddress='192.168.0.123', profile = '1'
Thanks in advance.
Post Tue May 07, 2013 9:18 am
Re: Serviio Console won't start Win7x64
do you get any error or it just doesn't open at all?
fazelanvari
Post Tue May 07, 2013 12:21 pm
It just doesn't open at all.
slyguy42o
Post Tue May 07, 2013 7:25 pm
post a copy of your detailed server logs please.
fazelanvari
Post Tue May 07, 2013 7:32 pm
slyguy42o wrote:post a copy of your detailed server logs please.
I believe I did in my original post.
slyguy42o
Post Tue May 07, 2013 7:56 pm
we need detailed logs :)
see here how to do it.
viewtopic.php?f=5&t=7
fazelanvari
Post Tue May 07, 2013 8:02 pm
slyguy42o wrote:we need detailed logs :)
That's what I did. Maybe it didn't take. I'll do it again tonight after I get off work.
Thanks for the help.
fazelanvari
Post Wed May 08, 2013 4:23 am
Ok, did it again and it looks like there's more data this time. I attahed it below, but I'll paste it here as well.
Another thing I noticed. The start and stop service shortcuts in the start menu don't appear to be working. I had to go into services.msc to stop and start the service.
2013-05-07 12:59:09,401 INFO  [RendererManager] Stored a new renderer: uuid='64040893-e15e-43e6-bf91-1ee352ebfa92', name = 'Unrecognized device', ipAddress='192.168.0.129', profile = '1'
2013-05-07 21:00:07,220 INFO  [RendererManager] Stored a new renderer: uuid='74303eca-bd84-4ed1-b76d-1c8b728c10e7', name = 'Unrecognized device', ipAddress='192.168.0.128', profile = '1'
2013-05-07 21:00:10,659 INFO  [RendererManager] Stored a new renderer: uuid='c94c2f18-4ace-5a15-0000-000011f1aec6', name = 'BubbleUPnP Media Renderer', ipAddress='192.168.0.128', profile = '1'
2013-05-07 21:00:15,472 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2013-05-07 21:00:16,245 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2013-05-07 23:13:14,126 INFO  [MediaServer] Serviio server instance is already running
2013-05-07 23:13:36,959 INFO  [MediaServer] Serviio server instance is already running
2013-05-07 23:15:34,974 WARN  [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2013-05-07 23:15:34,974 WARN  [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2013-05-07 23:15:34,975 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2013-05-07 23:15:35,074 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2013-05-07 23:15:35,174 INFO  [FeedUpdaterThread] Finished looking for online resources information
2013-05-07 23:15:35,274 INFO  [PluginCompilerThread] Finished looking for plugins
2013-05-07 23:15:35,395 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2013-05-07 23:15:35,395 INFO  [WebServer] WebServer shutting down
2013-05-07 23:15:35,395 INFO  [EventDispatcher] Leaving EventDispatcher
2013-05-07 23:15:35,395 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2013-05-07 23:15:35,395 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2013-05-07 23:15:35,603 INFO  [DatabaseManager] Shutting down database
2013-05-07 23:15:36,124 INFO  [RendererExpirationChecker] Leaving RendererExpirationChecker
2013-05-07 23:15:38,080 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-05-07 23:18:19,664 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2013-05-07 23:18:19,668 INFO  [MediaServer] ------------------------------------------------------------------------
2013-05-07 23:18:19,668 INFO  [MediaServer] Serviio DLNA media streaming server v 1.2.1 (rev. a2aa56064460+)
2013-05-07 23:18:19,668 INFO  [MediaServer] Petr Nejedly 2009-2013
2013-05-07 23:18:19,668 INFO  [MediaServer] http://www.serviio.org
2013-05-07 23:18:19,669 INFO  [MediaServer] Java 1.6.0_19-Sun Microsystems Inc.
2013-05-07 23:18:19,669 INFO  [MediaServer] OS Windows 7 amd64 6.1
2013-05-07 23:18:19,669 INFO  [MediaServer] File encoding: windows-1252
2013-05-07 23:18:19,669 INFO  [MediaServer] Headless mode enabled: true
2013-05-07 23:18:19,669 INFO  [MediaServer] User: AFAZEL-LAPTOP$
2013-05-07 23:18:19,669 INFO  [MediaServer] User home dir: C:\
2013-05-07 23:18:19,669 INFO  [MediaServer] Temp dir: C:\windows\TEMP\
2013-05-07 23:18:19,669 INFO  [MediaServer] ------------------------------------------------------------------------
2013-05-07 23:18:19,891 INFO  [WebServer] Socket buffer set to 65535 bytes
2013-05-07 23:18:19,892 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-05-07 23:18:19,920 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-05-07 23:18:19,921 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-05-07 23:18:19,950 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-05-07 23:18:19,982 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2013-05-07 23:18:20,935 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2013-05-07 23:18:20,936 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2013-05-07 23:18:20,937 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2013-05-07 23:18:20,937 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2013-05-07 23:18:20,938 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2013-05-07 23:18:20,939 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2013-05-07 23:18:20,939 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2013-05-07 23:18:20,940 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2013-05-07 23:18:20,941 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2013-05-07 23:18:20,941 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2013-05-07 23:18:20,942 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2013-05-07 23:18:20,942 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2013-05-07 23:18:20,943 DEBUG [DBLogDAOImpl] Checking if script 'script-1.1.sql' has been run
2013-05-07 23:18:20,944 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.sql' has been run
2013-05-07 23:18:20,944 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.1.sql' has been run
2013-05-07 23:18:20,972 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2013-05-07 23:18:20,993 DEBUG [LicenseValidator] Validating license file (352 bytes)
2013-05-07 23:18:21,226 INFO  [MediaServer] ------------------------------------------------------------------------
2013-05-07 23:18:21,226 INFO  [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2013-05-07 23:18:21,227 DEBUG [LocalAddressResolverStrategy] Resolving host IP address automatically
2013-05-07 23:18:21,800 INFO  [Device] Created UPnP Device with UUID: 1dc59d19-f7a1-31e2-81d8-fa90987267ff, bound address: 192.168.0.123
2013-05-07 23:18:22,387 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2013-05-07 23:18:22,389 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2013-05-07 23:18:22,477 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2013-05-07 23:18:22,477 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2013-05-07 23:18:22,516 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2013-05-07 23:18:22,516 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2013-05-07 23:18:22,519 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2013-05-07 23:18:22,519 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2013-05-07 23:18:22,520 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2013-05-07 23:18:22,520 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2013-05-07 23:18:22,521 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2013-05-07 23:18:22,521 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2013-05-07 23:18:22,525 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2013-05-07 23:18:22,525 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2013-05-07 23:18:22,527 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2013-05-07 23:18:22,527 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2013-05-07 23:18:22,527 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2013-05-07 23:18:22,527 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012
2013-05-07 23:18:22,531 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2013-05-07 23:18:22,531 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2012
2013-05-07 23:18:22,533 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2013-05-07 23:18:22,533 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010
2013-05-07 23:18:22,538 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2013-05-07 23:18:22,538 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010us
2013-05-07 23:18:22,539 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2013-05-07 23:18:22,539 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2011
2013-05-07 23:18:22,540 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2013-05-07 23:18:22,541 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2013-05-07 23:18:22,542 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2013-05-07 23:18:22,542 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2013-05-07 23:18:22,543 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2013-05-07 23:18:22,543 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2013-05-07 23:18:22,544 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2013-05-07 23:18:22,544 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2013-05-07 23:18:22,545 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2013-05-07 23:18:22,545 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2013-05-07 23:18:22,546 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2013-05-07 23:18:22,546 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2013-05-07 23:18:22,547 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2013-05-07 23:18:22,547 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011
2013-05-07 23:18:22,548 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2013-05-07 23:18:22,548 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2010
2013-05-07 23:18:22,549 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2013-05-07 23:18:22,550 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile plps2010
2013-05-07 23:18:22,551 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2013-05-07 23:18:22,551 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2013-05-07 23:18:22,552 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2013-05-07 23:18:22,552 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2009
2013-05-07 23:18:22,553 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2013-05-07 23:18:22,553 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 22
2013-05-07 23:18:22,554 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2013-05-07 23:18:22,554 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011a
2013-05-07 23:18:22,555 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2013-05-07 23:18:22,556 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011
2013-05-07 23:18:22,556 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2013-05-07 23:18:22,557 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2010
2013-05-07 23:18:22,557 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2013-05-07 23:18:22,558 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012us
2013-05-07 23:18:22,558 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2013-05-07 23:18:22,558 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011us
2013-05-07 23:18:22,559 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2013-05-07 23:18:22,559 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonySTR
2013-05-07 23:18:22,561 INFO  [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2013-05-07 23:18:22,561 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonyCMT
2013-05-07 23:18:22,562 INFO  [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2013-05-07 23:18:22,562 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viziotv
2013-05-07 23:18:22,563 INFO  [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2013-05-07 23:18:22,563 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile win8metro
2013-05-07 23:18:22,566 INFO  [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2013-05-07 23:18:22,615 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2013-05-07 23:18:22,615 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile flv_player
2013-05-07 23:18:22,617 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2013-05-07 23:18:22,617 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo
2013-05-07 23:18:22,618 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2013-05-07 23:18:22,618 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile wp8
2013-05-07 23:18:22,619 INFO  [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2013-05-07 23:18:22,717 INFO  [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2013-05-07 23:18:22,717 INFO  [PluginCompilerThread] Started looking for plugins
2013-05-07 23:18:22,719 INFO  [UpdateChecker] Checking if a new version is available
2013-05-07 23:18:22,725 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2013-05-07 23:18:22,728 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2013-05-07 23:18:22,952 DEBUG [DCRawWrapper] Invoking DCRAW to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/dcraw.exe
2013-05-07 23:18:22,953 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/dcraw.exe
2013-05-07 23:18:23,058 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-05-07 23:18:23,112 INFO  [WebServer] WebServer starting on port 8895
2013-05-07 23:18:23,118 DEBUG [DiscoveryManager] UPNP device 1dc59d19-f7a1-31e2-81d8-fa90987267ff (192.168.0.123) is available
2013-05-07 23:18:23,119 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-05-07 23:18:23,119 INFO  [EventDispatcher] Starting EventDispatcher
2013-05-07 23:18:23,122 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-05-07 23:18:23,125 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2013-05-07 23:18:23,346 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net3 (Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC) and address 192.168.0.123, timeout = 0
2013-05-07 23:18:23,351 INFO  [RendererSearchSender] Searching for Renderer devices
2013-05-07 23:18:23,352 DEBUG [RendererSearchSender$RendererSearchWorker] Multicasting SSDP M-SEARCH using interface net3 (Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC) and address 192.168.0.123, timeout = 0
2013-05-07 23:18:23,365 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net3 (Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC) and address 192.168.0.123, timeout = 0
2013-05-07 23:18:23,406 DEBUG [RendererSearchSender$RendererSearchWorker] Sending 1 'm-search' messages
2013-05-07 23:18:23,407 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 1dc59d19-f7a1-31e2-81d8-fa90987267ff
2013-05-07 23:18:23,414 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.0.123:56523s
2013-05-07 23:18:23,416 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.0.123:56523s
2013-05-07 23:18:24,047 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.0.147:1025/, st: urn:schemas-upnp-org:device:MediaRenderer:1
2013-05-07 23:18:24,048 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 31891429-3205-2000-0000-002248c6120f from address /192.168.0.147:31585
2013-05-07 23:18:24,067 DEBUG [RendererManager] Adding renderer Renderer [uuid=31891429-3205-2000-0000-002248c6120f, ipAddress=192.168.0.147, name=Xbox 360, profileId=3, manuallyAdded=false, forcedProfile=false, enabled=true, accessGroupId=1] to list of active renderers
2013-05-07 23:18:25,095 WARN  [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2013-05-07 23:18:25,095 WARN  [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2013-05-07 23:18:25,117 INFO  [PluginCompilerThread] Finished looking for plugins
2013-05-07 23:18:25,208 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:07 (advertisement duration is 1800 sec.)
2013-05-07 23:18:25,219 DEBUG [DiscoveryManager] UPNP device 1dc59d19-f7a1-31e2-81d8-fa90987267ff (192.168.0.123) is unavailable
2013-05-07 23:18:25,219 DEBUG [WebServer] Socket closed
2013-05-07 23:18:25,219 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2013-05-07 23:18:25,219 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2013-05-07 23:18:25,219 INFO  [EventDispatcher] Leaving EventDispatcher
2013-05-07 23:18:25,219 INFO  [WebServer] WebServer shutting down
2013-05-07 23:18:25,219 DEBUG [DiscoverySSDPMessageListener] Socket closed: socket closed
2013-05-07 23:18:25,220 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2013-05-07 23:18:25,372 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP byebye using interface net3 (Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC) and address 192.168.0.123, timeout = 0
2013-05-07 23:18:25,374 INFO  [DatabaseManager] Shutting down database
2013-05-07 23:18:25,375 DEBUG [DBConnectionPool] Closed connection for pool Serviio DB Pool
2013-05-07 23:18:25,381 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.0.147:1025/, st: urn:schemas-upnp-org:device:MediaRenderer:1
2013-05-07 23:18:25,381 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 31891429-3205-2000-0000-002248c6120f from address /192.168.0.147:31585
2013-05-07 23:18:25,400 DEBUG [DatabaseManager] DB shutdown returned: Derby system shutdown.
2013-05-07 23:18:25,400 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-05-07 23:18:26,519 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2013-05-07 23:18:26,522 INFO  [MediaServer] ------------------------------------------------------------------------
2013-05-07 23:18:26,523 INFO  [MediaServer] Serviio DLNA media streaming server v 1.2.1 (rev. a2aa56064460+)
2013-05-07 23:18:26,523 INFO  [MediaServer] Petr Nejedly 2009-2013
2013-05-07 23:18:26,523 INFO  [MediaServer] http://www.serviio.org
2013-05-07 23:18:26,523 INFO  [MediaServer] Java 1.6.0_19-Sun Microsystems Inc.
2013-05-07 23:18:26,523 INFO  [MediaServer] OS Windows 7 amd64 6.1
2013-05-07 23:18:26,523 INFO  [MediaServer] File encoding: windows-1252
2013-05-07 23:18:26,523 INFO  [MediaServer] Headless mode enabled: true
2013-05-07 23:18:26,524 INFO  [MediaServer] User: AFAZEL-LAPTOP$
2013-05-07 23:18:26,524 INFO  [MediaServer] User home dir: C:\
2013-05-07 23:18:26,524 INFO  [MediaServer] Temp dir: C:\windows\TEMP\
2013-05-07 23:18:26,524 INFO  [MediaServer] ------------------------------------------------------------------------
2013-05-07 23:18:26,627 INFO  [WebServer] Socket buffer set to 65535 bytes
2013-05-07 23:18:26,628 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-05-07 23:18:26,662 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-05-07 23:18:26,662 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-05-07 23:18:26,674 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-05-07 23:18:26,683 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2013-05-07 23:18:27,368 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2013-05-07 23:18:27,369 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2013-05-07 23:18:27,369 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2013-05-07 23:18:27,370 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2013-05-07 23:18:27,371 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2013-05-07 23:18:27,371 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2013-05-07 23:18:27,372 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2013-05-07 23:18:27,373 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2013-05-07 23:18:27,373 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2013-05-07 23:18:27,374 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2013-05-07 23:18:27,375 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2013-05-07 23:18:27,375 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2013-05-07 23:18:27,376 DEBUG [DBLogDAOImpl] Checking if script 'script-1.1.sql' has been run
2013-05-07 23:18:27,377 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.sql' has been run
2013-05-07 23:18:27,377 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.1.sql' has been run
2013-05-07 23:18:27,389 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2013-05-07 23:18:27,404 DEBUG [LicenseValidator] Validating license file (352 bytes)
2013-05-07 23:18:27,586 INFO  [MediaServer] ------------------------------------------------------------------------
2013-05-07 23:18:27,586 INFO  [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2013-05-07 23:18:27,587 INFO  [MediaServer] ------------------------------------------------------------------------
2013-05-07 23:18:27,588 DEBUG [LocalAddressResolverStrategy] Resolving host IP address automatically
2013-05-07 23:18:28,135 INFO  [Device] Created UPnP Device with UUID: 1dc59d19-f7a1-31e2-81d8-fa90987267ff, bound address: 192.168.0.123
2013-05-07 23:18:28,531 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2013-05-07 23:18:28,533 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2013-05-07 23:18:28,603 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2013-05-07 23:18:28,603 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2013-05-07 23:18:28,620 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2013-05-07 23:18:28,620 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2013-05-07 23:18:28,623 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2013-05-07 23:18:28,623 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2013-05-07 23:18:28,624 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2013-05-07 23:18:28,624 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2013-05-07 23:18:28,625 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2013-05-07 23:18:28,625 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2013-05-07 23:18:28,629 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2013-05-07 23:18:28,629 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2013-05-07 23:18:28,631 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2013-05-07 23:18:28,631 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2013-05-07 23:18:28,632 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2013-05-07 23:18:28,632 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012
2013-05-07 23:18:28,635 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2013-05-07 23:18:28,635 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2012
2013-05-07 23:18:28,637 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2013-05-07 23:18:28,637 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010
2013-05-07 23:18:28,642 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2013-05-07 23:18:28,642 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010us
2013-05-07 23:18:28,643 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2013-05-07 23:18:28,643 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2011
2013-05-07 23:18:28,644 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2013-05-07 23:18:28,644 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2013-05-07 23:18:28,645 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2013-05-07 23:18:28,645 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2013-05-07 23:18:28,646 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2013-05-07 23:18:28,647 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2013-05-07 23:18:28,647 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2013-05-07 23:18:28,647 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2013-05-07 23:18:28,648 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2013-05-07 23:18:28,648 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2013-05-07 23:18:28,649 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2013-05-07 23:18:28,649 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2013-05-07 23:18:28,650 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2013-05-07 23:18:28,650 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011
2013-05-07 23:18:28,651 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2013-05-07 23:18:28,651 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2010
2013-05-07 23:18:28,652 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2013-05-07 23:18:28,653 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile plps2010
2013-05-07 23:18:28,654 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2013-05-07 23:18:28,654 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2013-05-07 23:18:28,655 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2013-05-07 23:18:28,655 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2009
2013-05-07 23:18:28,656 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2013-05-07 23:18:28,656 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 22
2013-05-07 23:18:28,657 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2013-05-07 23:18:28,657 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011a
2013-05-07 23:18:28,658 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2013-05-07 23:18:28,658 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011
2013-05-07 23:18:28,659 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2013-05-07 23:18:28,659 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2010
2013-05-07 23:18:28,660 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2013-05-07 23:18:28,660 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012us
2013-05-07 23:18:28,661 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2013-05-07 23:18:28,661 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011us
2013-05-07 23:18:28,662 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2013-05-07 23:18:28,662 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonySTR
2013-05-07 23:18:28,663 INFO  [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2013-05-07 23:18:28,664 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonyCMT
2013-05-07 23:18:28,664 INFO  [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2013-05-07 23:18:28,665 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viziotv
2013-05-07 23:18:28,665 INFO  [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2013-05-07 23:18:28,665 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile win8metro
2013-05-07 23:18:28,668 INFO  [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2013-05-07 23:18:28,717 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2013-05-07 23:18:28,717 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile flv_player
2013-05-07 23:18:28,719 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2013-05-07 23:18:28,719 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo
2013-05-07 23:18:28,720 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2013-05-07 23:18:28,720 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile wp8
2013-05-07 23:18:28,721 INFO  [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2013-05-07 23:18:28,759 INFO  [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2013-05-07 23:18:28,760 INFO  [PluginCompilerThread] Started looking for plugins
2013-05-07 23:18:28,761 INFO  [UpdateChecker] Checking if a new version is available
2013-05-07 23:18:28,769 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2013-05-07 23:18:28,774 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2013-05-07 23:18:28,862 DEBUG [DCRawWrapper] Invoking DCRAW to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/dcraw.exe
2013-05-07 23:18:28,863 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/dcraw.exe
2013-05-07 23:18:28,896 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-05-07 23:18:28,919 INFO  [WebServer] WebServer starting on port 8895
2013-05-07 23:18:28,924 DEBUG [DiscoveryManager] UPNP device 1dc59d19-f7a1-31e2-81d8-fa90987267ff (192.168.0.123) is available
2013-05-07 23:18:28,924 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-05-07 23:18:28,924 INFO  [EventDispatcher] Starting EventDispatcher
2013-05-07 23:18:28,925 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-05-07 23:18:28,929 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2013-05-07 23:18:29,091 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net3 (Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC) and address 192.168.0.123, timeout = 0
2013-05-07 23:18:29,098 INFO  [RendererSearchSender] Searching for Renderer devices
2013-05-07 23:18:29,100 DEBUG [RendererSearchSender$RendererSearchWorker] Multicasting SSDP M-SEARCH using interface net3 (Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC) and address 192.168.0.123, timeout = 0
2013-05-07 23:18:29,173 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net3 (Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC) and address 192.168.0.123, timeout = 0
2013-05-07 23:18:29,188 DEBUG [RendererSearchSender$RendererSearchWorker] Sending 1 'm-search' messages
2013-05-07 23:18:29,190 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 1dc59d19-f7a1-31e2-81d8-fa90987267ff
2013-05-07 23:18:29,192 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.0.123:51209s
2013-05-07 23:18:29,194 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.0.123:56530s
2013-05-07 23:18:29,195 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.0.123:56530s
2013-05-07 23:18:30,380 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.0.147:1025/, st: urn:schemas-upnp-org:device:MediaRenderer:1
2013-05-07 23:18:30,381 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 31891429-3205-2000-0000-002248c6120f from address /192.168.0.147:31585
2013-05-07 23:18:30,401 DEBUG [RendererManager] Adding renderer Renderer [uuid=31891429-3205-2000-0000-002248c6120f, ipAddress=192.168.0.147, name=Xbox 360, profileId=3, manuallyAdded=false, forcedProfile=false, enabled=true, accessGroupId=1] to list of active renderers
2013-05-07 23:18:30,712 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.0.147:1025/, st: urn:schemas-upnp-org:device:MediaRenderer:1
2013-05-07 23:18:30,712 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 31891429-3205-2000-0000-002248c6120f from address /192.168.0.147:31585
2013-05-07 23:18:30,812 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.0.147:1025/, st: urn:schemas-upnp-org:device:MediaRenderer:1
2013-05-07 23:18:30,812 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 31891429-3205-2000-0000-002248c6120f from address /192.168.0.147:31585
2013-05-07 23:18:30,991 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:07 (advertisement duration is 1800 sec.)
2013-05-07 23:18:32,154 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.0.123:51209s
2013-05-07 23:18:35,190 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2013-05-07 23:18:39,082 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net3 (Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC) and address 192.168.0.123, timeout = 0
2013-05-07 23:18:39,083 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 1dc59d19-f7a1-31e2-81d8-fa90987267ff
2013-05-07 23:18:40,884 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:08 (advertisement duration is 1800 sec.)
2013-05-07 23:18:49,091 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net3 (Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC) and address 192.168.0.123, timeout = 0
2013-05-07 23:18:49,092 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 1dc59d19-f7a1-31e2-81d8-fa90987267ff
2013-05-07 23:18:50,893 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:43 (advertisement duration is 1800 sec.)
2013-05-07 23:18:55,193 INFO  [FeedUpdaterThread] Started looking for information about online resources
2013-05-07 23:18:55,193 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-05-07 23:18:55,196 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-05-07 23:18:55,212 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-05-07 23:18:55,227 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-05-07 23:18:55,247 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-05-07 23:18:55,247 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-05-07 23:18:55,248 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2013-05-07 23:18:55,270 DEBUG [PlaylistDAOImpl] Reading all Playlists
2013-05-07 23:19:18,141 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.0.123:51209s
2013-05-07 23:19:21,141 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.0.123:51209s
2013-05-07 23:19:24,141 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.0.123:51209s
2013-05-07 23:19:27,160 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.0.123:51209s
2013-05-07 23:19:30,160 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.0.123:51209s
2013-05-07 23:19:33,160 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.0.123:51209s
2013-05-07 23:19:55,290 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-05-07 23:19:55,290 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-05-07 23:20:47,580 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.0.123:51209s
2013-05-07 23:20:47,582 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.123:51209
2013-05-07 23:20:47,692 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-wifialliance-org:device:WFADevice:1 from address /192.168.0.123:51209s
2013-05-07 23:20:48,755 DEBUG [ServiioHttpService] Incoming request from /192.168.0.123:56328: GET /deviceDescription/1dc59d19-f7a1-31e2-81d8-fa90987267ff HTTP/1.1, headers = [Cache-Control: no-cache,Connection: Keep-Alive,Pragma: no-cache,Accept: text/xml, application/xml,User-Agent: FDSSDP,Host: 192.168.0.123:8895]]
2013-05-07 23:20:48,756 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.123
2013-05-07 23:20:48,768 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 1dc59d19-f7a1-31e2-81d8-fa90987267ff from 192.168.0.123 (headers = [Cache-Control: no-cache,Connection: Keep-Alive,Pragma: no-cache,Accept: text/xml, application/xml,User-Agent: FDSSDP,Host: 192.168.0.123:8895])
2013-05-07 23:20:48,768 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.123
2013-05-07 23:20:48,769 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Cache-Control: no-cache,Connection: Keep-Alive,Pragma: no-cache,Accept: text/xml, application/xml,User-Agent: FDSSDP,Host: 192.168.0.123:8895]
2013-05-07 23:20:48,771 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.123
2013-05-07 23:20:48,937 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2013-05-07 23:20:50,580 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.0.123:51209s
2013-05-07 23:20:50,581 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.123:51209
2013-05-07 23:20:50,692 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-wifialliance-org:device:WFADevice:1 from address /192.168.0.123:51209s
2013-05-07 23:20:53,581 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.0.123:51209s
2013-05-07 23:20:53,582 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.123:51209
2013-05-07 23:20:53,693 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-wifialliance-org:device:WFADevice:1 from address /192.168.0.123:51209s
2013-05-07 23:20:55,293 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-05-07 23:20:55,293 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-05-07 23:21:49,196 DEBUG [WebServer] I/O error: Connection reset
2013-05-07 23:21:55,293 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-05-07 23:21:55,293 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-05-07 23:22:34,272 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net3 (Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC) and address 192.168.0.123, timeout = 0
2013-05-07 23:22:34,273 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 1dc59d19-f7a1-31e2-81d8-fa90987267ff
2013-05-07 23:22:36,073 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:02 (advertisement duration is 1800 sec.)
(50.04 KiB) Downloaded 451 times
fazelanvari
Post Wed May 08, 2013 4:33 am
I found a log in the Windows Event Viewer as well:
Version=1
EventType=PCA2
EventTime=130124602007936402
Consent=1
ReportIdentifier=14e26acf-b796-11e2-a810-00266c4505c4
Response.type=4
Sig[0].Name=Problem Signature 01
Sig[0].Value=ServiioConsole.exe
Sig[1].Name=Problem Signature 02
Sig[1].Value=0.0.0.0
Sig[2].Name=Problem Signature 03
Sig[2].Value=ServiioConsole.exe
Sig[3].Name=Problem Signature 04
Sig[3].Value=unknown
Sig[4].Name=Problem Signature 05
Sig[4].Value=unknown
Sig[5].Name=Problem Signature 06
Sig[5].Value=200
Sig[6].Name=Problem Signature 07
Sig[6].Value=-1
DynamicSig[1].Name=OS Version
DynamicSig[1].Value=6.1.7601.2.1.0.256.48
DynamicSig[2].Name=Locale ID
DynamicSig[2].Value=1033
File[0].CabName=appcompat.txt
File[0].Path=appcompat.txt
File[0].Flags=65536
File[0].Type=5
File[0].Original.Path=C:\Users\<username>\AppData\Local\Temp\{6672ca48-84f6-47f1-8ff3-d03aa53e23b1}\appcompat.txt
File[1].CabName=TabD10D.tmp
File[1].Path=TabD10D.tmp
File[1].Flags=65536
File[1].Type=5
File[1].Original.Path=C:\Users\<username>\AppData\Local\Temp\TabD10D.tmp
FriendlyEventName=Program Compatibility
ConsentKey=PCA2
AppName=ServiioConsole.exe
AppPath=C:\Program Files\Serviio\bin\ServiioConsole.exe
The log references an "appcompat.txt" file:
<?xml version="1.0" encoding="UTF-16"?>
<DATABASE>
<EXE NAME="ServiioConsole.exe" FILTER="GRABMI_FILTER_PRIVACY">
    <MATCHING_FILE NAME="ServiioConsole.exe" SIZE="636928" CHECKSUM="0xB9FAA46D" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="11/12/2012 17:03:15" UPTO_LINK_DATE="11/12/2012 17:03:15" EXE_WRAPPER="0x0" />
    <MATCHING_FILE NAME="ServiioService.exe" SIZE="354816" CHECKSUM="0x631F67F2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="11/12/2012 17:03:36" UPTO_LINK_DATE="11/12/2012 17:03:36" EXE_WRAPPER="0x0" />
</EXE>
</DATABASE>
Post Wed May 08, 2013 9:51 am
Does the console start if you run it via ServiioConsole.bat file, instead of the .exe?
fazelanvari
Post Wed May 08, 2013 11:50 am
It does not.
Post Wed May 08, 2013 3:48 pm
Do you have Java 1.6.0_19? Try to upgrade and then run again.
fazelanvari
Post Wed May 08, 2013 9:54 pm
zip wrote:Do you have Java 1.6.0_19? Try to upgrade and then run again.
I will check for an upgrade, but here's what's installed:
Edit:
Oracle says I'm good to go:
Should I remove the old Java versions? Unless you tell me I need them, I plan on it.
Post Wed May 08, 2013 10:06 pm
yes, uninstall them.
then type this in command prompt:
java --version
fazelanvari
Post Wed May 08, 2013 10:10 pm
zip wrote:yes, uninstall them.
java --version
c:\>java --version
'java' is not recognized as an internal or external command,
operable program or batch file.
Post Wed May 08, 2013 11:28 pm
do you have any Java installed now? It should be on the path.
fazelanvari
Post Thu May 09, 2013 12:03 am
zip wrote:do you have any Java installed now? It should be on the path.
I do. I uninstalled and reinstalled as well:
There's no executables in the java directory, just jars in the lib directory.
fazelanvari
Post Thu May 09, 2013 1:51 am
Just an update. I uninstalled Serviio and reinstalled. When I ran the installation, it told me I didn't have Java JRE 6 and asked if I wanted to install it. I told it yes and it went through with the Java setup.
Why isn't the latest Java supported? Further, why isn't it backwards compatible? I blame Oracle.
Anyway, that fixed it for me. Thanks for walking me through!
slyguy42o
Post Thu May 09, 2013 3:16 pm
Re: [Resolved] Serviio Console won't start Win7x64
it defaults to java 6 but through config you can change it to use java 7
fazelanvari
Post Thu May 09, 2013 4:32 pm
slyguy42o wrote:it defaults to java 6 but through config you can change it to use java 7
Maybe I'll be able to change it over now that I can get the console to launch.
