Sony BluRay Players (BDP-S370)
BluePriest
Post Tue Jan 11, 2011 10:44 pm
Re: [Profile] Sony BluRay Players (BDP-S370)
FFmpeg version SVN-r23012, Copyright (c) 2000-2010 the FFmpeg developers
  built on May  3 2010 19:05:24 with gcc 3.4.5 (mingw-vista special r3)
erver --enable-memalign-hack --enable-libmp3lame --enable-w32threads --extra-ldf
lags=-L/static/lib --extra-cflags=-I/static/include
  libavutil     50.15. 0 / 50.15. 0
  libavcodec    52.66. 0 / 52.66. 0
  libavformat   52.62. 0 / 52.62. 0
  libavdevice   52. 2. 0 / 52. 2. 0
  libswscale     0.10. 0 /  0.10. 0
[matroska @ 010ec040]Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/
1001) -> 23.98 (48000/2002)
Input #0, matroska, from 'c:\users\t\downloads\myfile.mkv':
    title           : SHREK_3D
  Duration: 01:30:04.77, start: 0.000000, bitrate: N/A
    Chapter #0.0: start 0.000000, end 296.754000
      title           : (01)00:00:00:000
    Chapter #0.1: start 296.754000, end 702.702000
      title           : (02)00:04:56:754
    Chapter #0.2: start 702.702000, end 958.749000
      title           : (03)00:11:42:702
    Chapter #0.3: start 958.749000, end 1211.335000
      title           : (04)00:15:58:749
    Chapter #0.4: start 1211.335000, end 1579.411000
      title           : (05)00:20:11:335
    Chapter #0.5: start 1579.411000, end 1900.023000
      title           : (06)00:26:19:411
    Chapter #0.6: start 1900.023000, end 2113.236000
      title           : (07)00:31:40:023
    Chapter #0.7: start 2113.236000, end 2423.963000
      title           : (08)00:35:13:236
    Chapter #0.8: start 2423.963000, end 2701.115000
      title           : (09)00:40:23:963
    Chapter #0.9: start 2701.115000, end 2956.161000
      title           : (10)00:45:01:115
    Chapter #0.10: start 2956.161000, end 3327.657000
      title           : (11)00:49:16:161
    Chapter #0.11: start 3327.657000, end 3654.233000
      title           : (12)00:55:27:657
    Chapter #0.12: start 3654.233000, end 3933.304000
      title           : (13)01:00:54:233
    Chapter #0.13: start 3933.304000, end 4156.152000
      title           : (14)01:05:33:304
    Chapter #0.14: start 4156.152000, end 4292.663000
      title           : (15)01:09:16:152
    Chapter #0.15: start 4292.663000, end 4491.111000
      title           : (16)01:11:32:663
    Chapter #0.16: start 4491.111000, end 4653.774000
      title           : (17)01:14:51:111
    Chapter #0.17: start 4653.774000, end 4853.098000
      title           : (18)01:17:33:774
    Chapter #0.18: start 4853.098000, end 4981.977000
      title           : (19)01:20:53:098
    Chapter #0.19: start 4981.977000, end 5404.399000
      title           : (20)01:23:01:977
    Chapter #0.20: start 5404.399000, end 5404.774322
      title           : (21)01:30:04:399
    Stream #0.0: Video: h264, yuv420p, 1920x1080, PAR 1:1 DAR 16:9, 23.98 tbr, 4
8003.07 tbn, 47.95 tbc
    Stream #0.1(eng): Audio: truehd, 48000 Hz, 8 channels, s32
Im guessing the at least one output file must be specified is the key... but I dont understand what that means, or what I can do to make it work.
The region is US, and I am using the profile listed for the US version.
EDIT!
The US version of the profile has nothing listed as mkv for converting. And Im SURE the manual for the player said that mkv cant be played over dlna
EDIT gain,
Sorry, didnt realize a question you asked. By not working, I mean its not detecting the file
amunoz_tico
Post Wed Jan 12, 2011 12:05 am
patters wrote:I think Zip has stated a few times that he only wants it to use FFMPEG, presumably for simplicity reasons. So I guess you may need to focus your efforts on getting the FFMPEG project to add this functionality, which would be a good thing.
Sure patters!! No problem!! Don't forget that we shared some comments through a private part of this Forum, so I just shared with other guys my comments.
Nice day!
Samsung PN60E7000, UN46C7000, BD-C6900, BD-D5500, BD-E5700 ¬ Sony PS3, Wii ¬ LG BD670 ¬ Pioneer VSX-820-K ¬ Bose Acoustimass 15 ¬ Synology DS413j ¬ Cisco EA4500 ¬ Monster HDP2400
patters
Post Wed Jan 12, 2011 12:26 am
@Bluepriest
That could be a weird file - I haven't tried any that have chapter marks. Have you got others you can try?
The web info and possibly the manual for the player in the US do state that it won't work over DLNA. This is kind of true, but we get around this by using the device profile to fake the mime type and the DLNA resource type for MKV files.
Don't worry about the "at least one output must be specified" line. When you run FFMPEG -i you're saying use this file as an input, but you're not declaring an output so that's to be expected.
If you want to force all MKV files to be remuxed to M2TS (not processor heavy at all), find this in the Sony BDP profile:
         <!-- remux MP4 container files to allow seeking (AVC_TS_MP_HD_AC3_ISO or AVC_TS_MP_SD_AC3_ISO) -->
and change it to:
BluePriest
Post Wed Jan 12, 2011 12:57 am
Hmmm.... even adding that doesnt work... This is the only file I have right now...
patters
Post Wed Jan 12, 2011 1:33 am
Grab some samples here:
viewtopic.php?f=5&t=608
amunoz_tico
Post Wed Jan 12, 2011 2:01 am
BluePriest wrote:Hmmm.... even adding that doesnt work... This is the only file I have right now...
@BluePriest
I suggest you to visit the pag 3 of this topic, or go direct with the following link. There you can download an example file and get other solutions for your case that worked for me.
viewtopic.php?f=11&t=1126&hilit=S370&start=20#p5778
Regards!
BluePriest
Post Wed Jan 12, 2011 4:37 pm
@BluePriest
Regards!
I downloaded the matrix trailer in mkv format. Cant play that. This is WITHOUT the code to transcode mkv files added in since you said it shouldnt be needed. Im going to try WITH the code next though.
http://samples.ffmpeg.org/Matroska/matrix/
by doesnt work, I mean it doesnt show up in serviio.
With the added mkv it doest work either.... mkv files are the only ones Im having trouble with though
amunoz_tico
Post Wed Jan 12, 2011 5:37 pm
@BluePriest
My profile looks like the one that I posted below, based on my tests and the recommendations that I got,
Tonight, I will download and test the MKV videos that you posted. I will let you know my results. :D
   <Profile id="90" name="My Sony Blu-Ray Player" extendsProfileId="1">
          <Detection>
             <FriendlyName>^Blu-ray Disc Player$</FriendlyName>
          </Detection>
         <!-- The subtitles are not supported by the player for the moment-->
          <MediaFormatProfiles>
          <MediaFormatProfile mime-type="audio/mpeg" name="MP3">WMA_BASE</MediaFormatProfile>
          <MediaFormatProfile mime-type="audio/mpeg" name="MP3">WMA_FULL</MediaFormatProfile>
          <!-- For DivX and MKV -->
          <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">MATROSKA</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/divx" name="MPEG_PS_NTSC">AVI</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">AVC_MP4_MP_SD_AAC_MULT5</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">AVC_MP4_MP_SD_MPEG1_L3</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">AVC_MP4_MP_SD_AC3</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">AVC_MP4_MP_HD_720p_AAC</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">AVC_MP4_MP_HD_1080i_AAC</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">AVC_MP4_HP_HD_AAC</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">AVC_MP4_LPCM</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">MPEG4_P2_MP4_ASP_AAC</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">MPEG4_P2_MP4_SP_L6_AAC</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">MPEG4_P2_TS_ASP_AAC</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">MPEG4_P2_TS_ASP_AAC_T</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">MPEG4_P2_TS_ASP_AAC_ISO</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">MPEG4_P2_TS_ASP_AC3</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">MPEG4_P2_TS_ASP_AC3_T</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">MPEG4_P2_TS_ASP_AC3_ISO</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">MPEG4_P2_TS_ASP_MPEG1_L3</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">MPEG4_P2_TS_ASP_MPEG1_L3_T</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">MPEG4_P2_TS_ASP_MPEG1_L3_ISO</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">MPEG4_P2_MP4_NDSD</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">WMVMED_BASE</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">WMVMED_FULL</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">WMVHIGH_FULL</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">WMVMED_PRO</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">WMVHIGH_PRO</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">VC1_ASF_AP_L1_WMA</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">VC1_ASF_AP_L2_WMA</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_NTSC">VC1_ASF_AP_L3_WMA</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_SD_AAC_MULT5</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_SD_AAC_MULT5_T</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_SD_MPEG1_L3</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_SD_MPEG1_L3_T</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_SD_AC3</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_HD_AAC_MULT5</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_HD_AAC_MULT5_T</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_HD_MPEG1_L3</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_HD_MPEG1_L3_T</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_HD_AC3</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_HD_50_LPCM_T</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_HD_DTS_T</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_HD_DTS_ISO</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_HP_SD_MPEG1_L2_ISO</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_HP_SD_MPEG1_L2_T</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_HP_HD_MPEG1_L2_ISO</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_HP_HD_MPEG1_L2_T</MediaFormatProfile>
          <!-- rename remuxed mpeg2ts with h264 to one of the player's supported profiles -->
          <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
          <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_NA">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
          </MediaFormatProfiles>
                <Matches container="avi" vCodec="mpeg4" />
                <Matches container="matroska" vCodec="mpeg4" />
NOTES
1. My Blu-Ray is an US Model.
2. I have Serviio 0.5.4b (BETA) installed. The last public version, 0.4.2, could not support some "MediaFormatProfile" lines. So you have to check the Log file to locate the errors and remove them from your profile. The log file is located here = C:\Program Files\Serviio\log - It is a easy process :!: So, don't worry about, Patience!
3. I suggest you to use NotePad++ to edit the profile file which is based on XML format.
BluePriest
Post Wed Jan 12, 2011 9:35 pm
I wasnt using notepad ++ before. i love it. Makes it so much easier to edit thank you. I removed all the errors, but it still isnt showing the files.
amunoz_tico
Post Wed Jan 12, 2011 9:55 pm
BluePriest wrote:I wasnt using notepad ++ before. i love it. Makes it so much easier to edit thank you. I removed all the errors, but it still isnt showing the files.
@BluePriest
I'm so sorry to hear that news.
Try any of the other profiles that appear in this Topic.
BluePriest
Post Wed Jan 12, 2011 10:20 pm
I will continue to experiment. Thank you for your help. did you happen to try the matrix trailer I linked to to see if it worked for you?
amunoz_tico
Post Wed Jan 12, 2011 10:46 pm
BluePriest wrote:did you happen to try the matrix trailer I linked to to see if it worked for you?
I will try those videos this week. No problem, I can post my results.
amunoz_tico
Post Thu Jan 13, 2011 3:49 pm
[quote="amunoz_tico"][/quote]
Hi BluePriest,
As I promised you, I tested the files that you posted. Here my comments:
- I could play only this file Matrix.Reloaded.Trailer-640x346-XviD-1.0beta2-HE_AAC_subtitled.mkv
- The other one didn't appear in the tree.
- The subtitles are not supported. I couldn't enabled them.
I think that you issue could be resolved with the coming version, 0.5. It works for me. However, I don't sure when will release it.
Regards!
ktwo
Post Thu Jan 13, 2011 5:30 pm
Just wanted to toss out a huge KUDOS! to all the work on this thread and the development of serviio. My Sony X57 (same as the S series but it just comes with a HDMI cable) DLNA was not working with anything windows based dlna consistently, even after I determined I had to recode my library to make it work with the few formats Sony allows. I hated the idea of re-ripping every MKV into another format not worth my time ($135 spent on the player=1 hour of real work for me). I was 99% sure I was returning the player (not that it was bad, just I hate purchasing a product advertised a certain way and then one discovers the ad was a bit missleading and the support from Sony is extreemly lacking). After trying a variety of other programs with transcoding I gave this a try as a truely last resort (I tend to like mature- usually older and widely used- products).
It was sooo easy install, easy set up, almost too easy. Sony see's it, picts- check, music-check, video.... However it wouldn't play my MKV files (but that was nothing new of the other services I tried either- some would play some files, but not other etc).... then I tried the US profile as listed on this thread and received a "Plasma screen of beauty." :shock:
Seriously I have spent hours attempting to get the Sony to even see another DLNA device (learned quickly the difference between Upnp with DNLA is not the same for all media servers), much less getting the Sony to actually find a file with playable format. "No file with playable format available" was like a bad nightmare you just can't get rid of. The profiles are amazing- no need to attempt to set it up on your own, copy paste baby. Hours saved on my end.
The new US profile listed here did the trick on my test laptop with Business VISTA, but not the XP version (99% sure it was a firewall issue with XP as the Sony didn't even see the service, but it's my work one so no admin of the firewall allowed). Yah, copy code, paste it, reboot service= THANKS!
I look forward to using the linux build on my main next week for my main streaming service.
Oh, I am using the .4.2 build.
Keep up the great work!
ktwo
Post Thu Jan 13, 2011 9:55 pm
Bother, I knew writing a post full of great news would bite me... apparently not all the MVK files play.... tried a fresh rip too, rips plays on VCL, but not on the sony. I see if I can re-create the programs/process I used, as I know at one point I had avi files which i converted over to divx then to mvk.
amunoz_tico
Post Thu Jan 13, 2011 11:15 pm
ktwo wrote:Just wanted to toss out a huge KUDOS! to all the work on this thread and the development of serviio.
This is the idea of the FORUM.. Share the experience, make friends, and enjoy the life!
amunoz_tico
Post Thu Jan 13, 2011 11:21 pm
ktwo wrote:Bother, I knew writing a post full of great news would bite me... apparently not all the MVK files play.... tried a fresh rip too, rips plays on VCL, but not on the sony. I see if I can re-create the programs/process I used, as I know at one point I had avi files which i converted over to divx then to mvk.
Well.. sometimes you couldn't get a good transcoding process with some files. Usually it is due to the codecs. You can review the codecs of your video files with MediaInfo (http://mediainfo.sourceforge.net/en). There are more tools in the web, but it works excellent for me.
Decatf
Post Mon Jan 24, 2011 10:45 pm
Will subtitles ever work with m2ts transcoding of matroska files or is it a technical limitation somewhere?
I have tried external subtitles but the player won't read those unless the matroska transcoding is disabled. The US profile plays files a lot better on Serviio 0.5 but I need subtitles. :(
This is with the Canadian version.
Post Tue Jan 25, 2011 2:05 am
Decatf wrote:Will subtitles ever work with m2ts transcoding of matroska files or is it a technical limitation somewhere?
FFmpeg does not support encoding subs into the MKV video container so no it wont work :) maybe once FFmpeg adds this Zip can add it too
patters
Post Tue Jan 25, 2011 10:24 am
I've looked into it, and the player cannot play subs in m2ts, only mkv (which stream like crap over wifi). So basically, I think we'll just have to stick to m2ts remuxing for mkv (unless you're on a wired connection then you can comment out the matroska transcode sections in the profile, as per my comments in the file).
I've also submitted a ticket with a suggestion about how to remove the need for region-specific device profiles (particularly as the Sony BDP uses the same ID string for all regions) - so hopefully that'll keep things simple for new users.
Users browsing this forum: No registered users and 56 guests
