SONY kdl-40ex621 TV with Serviio
nomi2013
Post Wed May 08, 2013 11:48 am
Hi
I am using latest version of serviio on my windows 7 (32 bits) connected to the network.
When I open my son TV kdl-40ex621 (Canadian) it shows me serviio server and I can see the folders in TV.
I added some online contents (RSS) as mentioned in one of the forum , my issue is when I open the online folder on my TV I see "There are no items to display"
I have Serviio is set to the Sony Bravia TV (2011) profile with GREEN light (automatically detected by serviio) I have following questions
a) As I don't see my TV model mention in serviio sony forum I am wondering if my TV can work with serviio?
b) Although I can see folders in TV but as mentioned above "There are no items to display" message though have online contents added to library (RSS feeds) can someone tell me If I am doing it correctly or help me with steps for this
Thanks alot
Nomi
slyguy42o
Post Wed May 08, 2013 3:18 pm
Re: SONY kdl-40ex621 TV with Serviio
have you tried any of the other Sony profiles to see if it makes a difference?
Also you can test with VLC to make sure the feeds are active and will stream.
Post Wed May 08, 2013 3:46 pm
If it's an US model, you probably have to manually change to "Sony Bravia TV (2011) US " profile on serviio console (we could not distinguish EU / US models).
nomi2013
Post Wed May 08, 2013 4:42 pm
Hi Thanks for the replies
Yes I tried with 2011 US profile but same affect, I bought my TV in Canada.
still I am not sure if my TV is supported? how can I know as I don't see my serial no in Serviio List of Sony TV?
viewtopic.php?f=11&t=2396
And about VLC I will try but my question is does it make any difference as I am not seeing any items in Online folder on TV shows "There are no items to display" although I added online video streams (RSS Feeds) , May be I did something wrong but I follow the forum to add online RSS Feeds, do you tell me a working video stream for test which I can add to servvio's console and try again?
Thanks alot for all the help.
Nomi
nomi2013
Post Thu May 09, 2013 1:58 pm
Ok some progress
I can see and access my folders for VIDEO,Pictures and Audit in the TV.
and I copied the test files .mp4 (videos),.mp3 (audit) and .jpg (picture) so I can open these files successfully to my SONY Bravia TV using Sony Bravia 2011 profile
Now the only issue is that when I access the online folder on my TV I see "There are no items to display"
So this looks like I am doing something wrong for adding online video streams and RSS , can someone help me how to figure it out? or tell me some steps of adding and seeing those streams as files in my TV.
THanks
Nomi
nomi2013
Post Mon May 13, 2013 3:21 pm
Okay now I can see online folder and can play from some webresources
Now issue which I am facing is refresh online folder on my TV what I found is that if I add a new online resource using serviio controller it will not show in my TV I tried everything like force refresh in Console and start stop service and controller but no success. After running certain time on TV I can see my online folders coming..can anyone help what could be the issue
Regards
Nomi
Post Wed May 22, 2013 1:32 pm
It may take some time to download information about the online sources, so just give it a time.
