Change Aspect Ratio
Welsh_J_2000
Post Tue May 07, 2013 6:31 pm
Change Aspect Ratio
Hi.
Does anyone know how to change aspect ratio on sony BDV-E490? Some of the older programme files, play in 4:3 but I want to play everything as 16:9? Any help would be great as im struggling to get this to happen!
Cheers
Jazz.
slyguy42o
Post Wed May 08, 2013 4:59 pm
Re: Change Aspect Ratio
you can edit the profile to specify the apect ratio if you want to force it.
Welsh_J_2000
Post Wed May 08, 2013 5:17 pm
Hi mate,
Thanks for your reply, how do I go about doing that? I've tried inserting DAR=16:9 in nearly every transcoding line but if im honest im just randomly sticking it where I think it should go without any idea what im doing, lol.
If you could help would be great. Im using the "Sony BDP-Sx90 (2012)" profile as my unit is a BDV-E490 so i thought that would be the best match for it.
Cheers
slyguy42o
Post Wed May 08, 2013 6:17 pm
Go ahead and post your profile section including your edits and we will double check it for you.
Welsh_J_2000
Post Thu May 09, 2013 1:48 pm
slyguy42o wrote:Go ahead and post your profile section including your edits and we will double check it for you.
I had to do a fresh install cos for some reason Serviio wouldnt start so profile has gone back to standard.
<Profile id="bdp2012" name="Sony BDP-Sx90 (2012)" extendsProfileId="1">
<!-- For this BDP profile MKVs with multiple audio tracks and multiple subtitles are natively supported AVIs with DivX FourCC are transcoded,
no XSub subtitle support -->
<DeviceDescription>
<!-- act as WMP so that the TV doesn't show root categories -->
<ModelName>Windows Media Player Sharing</ModelName>
<ModelNumber>3.0</ModelNumber>
<Manufacturer>Microsoft Corporation</Manufacturer>
</DeviceDescription>
<ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.SonyDLNAMessageBuilder</ContentDirectoryMessageBuilder>
<ContentDirectoryDefinitionFilter>org.serviio.upnp.service.contentdirectory.definition.WMPContentDirectoryDefinitionFilter</ContentDirectoryDefinitionFilter>
<MediaFormatProfiles>
<!-- rename native WMA formats to those supported by the tv -->
<MediaFormatProfile mime-type="audio/x-ms-wma" name="WMABASE">WMA_BASE</MediaFormatProfile>
<MediaFormatProfile mime-type="audio/x-ms-wma" name="WMAFULL">WMA_FULL</MediaFormatProfile>
<!-- rename 3gp profiles that can be played as AVC -->
<MediaFormatProfile mime-type="video/mp4" name="AVC_MP4_MP_SD_AAC_MULT5">AVC_3GPP_BL_QCIF15_AAC</MediaFormatProfile>
</MediaFormatProfiles>
<H264LevelCheck>FILE_ATTRIBUTES</H264LevelCheck>
<!-- For dvr-ms files force mpeg2video transcoding to fix monotone timestamps problems -->
<Video targetContainer="mpegts" targetACodec="ac3" forceVTranscoding="true" forceInheritance="true">
<Matches container="asf" vCodec="mpeg2video" />
<Matches container="asf" vCodec="mpeg1video" />
<!-- h264 videos with high/main profile level > 4.1 will be transcoded to mpegts with mpeg2video and ac3 audio -->
<Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="320" forceInheritance="true">
<!-- unsupported codecs will be transcoded to mpegts with mpeg2video and ac3 audio -->
<Matches container="asf" vCodec="vc1" aCodec="wmapro" />
<Matches container="flv" />
<Matches container="wtv" />
<Matches container="ogg" />
<Matches container="rm" />
<Matches container="mp4" vCodec="dvvideo" />
<!-- digital camera video formats -->
<Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="320">
<!-- DivX -->
<Matches container="avi" vCodec="mpeg4" vFourCC="div3,div4,div5,divx,dm4v,dx50" />
<Matches container="avi" vCodec="msmpeg4" vFourCC="div3,div4,div5,divx,dm4v,dx50" />
<Audio targetContainer="lpcm" forceInheritance="true">
<!-- To allow "pause" then "resume" functions and album art for TVs that support it - transcode to mp3 instead -->
<Matches container="flac" />
</Audio>
<Image forceInheritance="true">
<Matches container="jpeg" subsampling="YUV444" />
</Image>
<OnlineTranscoding>
<Video targetContainer="mpegts"> <!-- do not transcode to ac3 -->
<Matches container="mp4" />
<Matches container="applehttp" vCodec="h264" />
<Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="320" forceInheritance="true">
<Matches container="asf" /> <!-- to support mms:// streams -->
</OnlineTranscoding>
<HardSubsTranscoding>
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" maxVBitrate="17000" aBitrate="320" />
</HardSubsTranscoding>
Any ideas where to force aspect ratio within this profile? Its for .avi files.
Cheers
Jazz.
