Films with (year) in name not found by TMDb
ghostuw
Post Thu May 09, 2013 4:45 pm
I'm using Serviio PRO 1.2.1 and just started to see this issue a few days ago. When a film with the year in the file name is added it never finds a match at TMDb. However, if the year is removed from the file name it works fine. It seems like a problem with TMDb but I thought I would start here and see if others are having the same issue. Below is the TMDb part of the DEBUG logs for with and without the year. Also, I have reproduced this with many different movies many times. Any help/advice would be appreciated. Thanks!
WITH YEAR:
2013-05-09 09:07:07,970 DEBUG [TheMovieDBSourceAdaptor] Searching for movie 'parker' 2013 (language: en)
2013-05-09 09:07:08,219 DEBUG [TheMovieDBSourceAdaptor] Found 0 matches
2013-05-09 09:07:08,219 DEBUG [TheMovieDBSourceAdaptor] Searching for movie 'new movies' 2013 (language: en)
2013-05-09 09:07:08,465 DEBUG [TheMovieDBSourceAdaptor] Found 0 matches
2013-05-09 09:07:08,465 DEBUG [TheMovieDBSourceAdaptor] No movie with the name has been found
2013-05-09 09:07:08,466 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Parker (2013).mkv [VideoDescription [type=FILM, names=[parker, new movies], year=2013, season=null, episode=null]]
WITHOUT YEAR:
2013-05-09 09:22:02,529 DEBUG [TheMovieDBSourceAdaptor] Searching for movie 'parker' (language: en)
2013-05-09 09:22:02,925 DEBUG [TheMovieDBSourceAdaptor] Found 10 matches
2013-05-09 09:22:02,939 DEBUG [TheMovieDBSourceAdaptor] Searching for movie 'new movies' (language: en)
2013-05-09 09:22:03,089 DEBUG [TheMovieDBSourceAdaptor] Found 0 matches
2013-05-09 09:22:03,144 DEBUG [TheMovieDBSourceAdaptor] Found a suitable movie match, id = 119283
2013-05-09 09:22:03,144 DEBUG [TheMovieDBSourceAdaptor] Retrieving details of movie (movieId = 119283, language = en)
2013-05-09 09:22:04,069 DEBUG [TheMovieDBSourceAdaptor] Retrieved poster:
alando22
Post Thu May 09, 2013 5:22 pm
Re: Films with (year) in name not found by TMDb
Same issue here.
Sounds like a API-Problem, look here: https://www.themoviedb.org/talk/5171c55b19c29526180e5df2
Post Fri May 10, 2013 5:53 am
Thanks for this. Added some files to my server this morning, did a refresh and lost a whole lot of movie listings from my library!!! It was driving me nuts - I thought I had done something to kill my library. At least now I know it's not something unique to me.
.... now to get it fixed.
Post Fri May 10, 2013 1:54 pm
I posted on tmdb forum, let's hope they fix it soon.
http://www.themoviedb.org/talk/518cb6c919c2950e0814e9ab
lesourcil
Post Mon May 13, 2013 7:54 pm
FYI,
Having a date also on the folder and not only the file will give no results. Quite annoying.
Post Sat May 18, 2013 9:28 am
My Movies have all re-appeared today so it looks as if the problem is fixed. Nothing yet reported in the tmdb forum (zip's post) though.
Much happier now :D
Post Sat May 18, 2013 9:33 pm
Yep, I was ripped some videos last night, and for a while FileBot was unable to connect to their site at all. Then it suddenly began working, and my missing videos began appearing in Serviio. I did have to rename the files to force Serviio to refresh the DB. Maybe it would have done it automatically if I waiting, but I didn't have the patience :lol:
