Serviio Not Adding Files from Library
cliverob
Post Thu May 09, 2013 11:19 pm
Hi, Sorry to raise this topic again but I cannot find answer to this problem on Forum. I've attached the latest log in the hope it will identify my problem.
I have a Samsung UA46ES5500 TV and my PC is a 64 bit running Windows 7. Initially I was able to play downloaded .wmv TV from BBC iPlayer on Allshare but about 10 days ago this stopped working. Have made many searches on various Forums & tried to get help from Samsung but to no avail - they say take the TV back to a service agent 200 miles away!!
I installed Serviio last week but cannot get it to add the files. Can you help please?
Thanks very much.
Serviio Log 10 April 2013.txt
(193.12 KiB) Downloaded 684 times
Post Fri May 10, 2013 4:26 pm
Re: Serviio Not Adding Files from Library
Did you keep turning the service on and off?
cliverob
Post Sat May 11, 2013 8:39 am
Thanks for looking at this. No, I have not turned it off & on. Here is a log from a few minutes ago when I restarted Serviio. Seem to be a lot of Java problems. Grateful for your advice thanks.
serviio log 11 May 2013.txt
(118.5 KiB) Downloaded 595 times
Post Mon May 13, 2013 10:26 am
The error is related to a online feed you entered, which is not a proper RSS feed. Otherwise the log looks fine.
Enable detailed log and post it again.
cliverob
Post Wed May 15, 2013 8:39 am
Re "The error is related to a online feed you entered, which is not a proper RSS feed. " I'm afraid I do not understand what this means. I am not aware of entering an online feed. The only manual entering I have done is to link the library folders. Can you explain please?
Re turning on detailed logging, I have tried to do this about 20 times but nothing happens. This is what I have tried - I have found the file log4j.xml in the config folder, right clicked on it, clicked on edit, copied
<category name="org.serviio">
<priority value="DEBUG"/>
</category>
into the text doc, saved it and exited. I have then clicked on restart as per the Serviio Windows service instructions. However, when I open the log folder there is no serviio.log file there. What am I doing wrong please?
Post Wed May 15, 2013 1:35 pm
restart the PC, it'll be easier
cliverob
Post Thu May 16, 2013 2:31 am
After multiple attempts I finally got a detailed log attached (I hope it's what you need).
I'd be grateful if you could explain this please "The error is related to a online feed you entered, which is not a proper RSS feed. "
Thanks very much.
PS
Before I tried to run Serviio I was using Samsung Allshare and this worked fine for a few weeks until 2 weeks ago when it stopped working. I can still get 2 or 3 BBCiPlayer downloads to play on the TV but most (over 20) will not play although I can play most of them on the PC with Windows Media Player. It's all very puzzling to me!
serviio log 16 May 2013.txt
(45.89 KiB) Downloaded 605 times
Post Mon May 20, 2013 1:27 pm
It looks like you have some shared folder
[LibraryAdditionsCheckerThread] Looking for files to share in folder: C:\Users\clive\My Videos
and some files have been added
[MediaItemDAOImpl] Media item Gardeners_World_2013_Episode_9_b01sfj56_1368238127.wmv already exists in DB
So you should see some files. What is the problem now?
cliverob
Post Tue May 21, 2013 1:35 am
Yes, I can see the files on the TV now but when I try to play any of them I get the message 'The selected file is not currently supported'. I get the same message if I try using Allshare.
I've attached a new detailed log if that is of help.
Thanks again for your time & effort on this.
serviio log 21 May.txt
(474.02 KiB) Downloaded 596 times
Post Wed May 22, 2013 9:50 am
Looks like you're using Generic profile? Assign the Samsung C/D/E to your device in the console.
cliverob
Post Thu May 23, 2013 7:55 am
I'm not sure which device you refer to - is it the TV (UA46ES5500) or PC-Allshare? In any case, I've tried both profile settings and still get the 'selected file is not currently supported' message. I've attached a screen dump of the Serviio Console and Windows Media Player. The latter has never shown any library files for Serviio. I get all media files on the TV but I can only get home video files & photos to play.
I've scanned the Forums for help and after seeing someone with the same problem get a fix by reinstalling Version 1.1, I have given it a try but without any success.
It is extremely frustrating as initially I was able to play downloaded TV programmes from the BBC iPlayer on Allshare but this suddenly stopped working about 4 weeeks ago.
Any further suggestions will be gratefully received.
SERVIIO CONSOLE & WINDOWS MEDIA PLAYER.pdf
(280.86 KiB) Downloaded 595 times
Post Thu May 23, 2013 10:45 am
Serviio won't work with WMP.
So if your TV's ip address is .3, I didn't see any requests from it in the log. Post another detailed log which includes you attempting to play the file.
Also post ffmpeg -i for the file.
cliverob
Post Fri May 24, 2013 8:35 am
Attached is a detailed log 'serviio.pdf'. Re '... post ffmpeg -i for the file', I am afraid I have no idea what this means or how to do it despite searching the Forum for an explanation.
I also had no idea that WMP won't work with Serviio - that is not mentioned in the Support info on the website.
serviio.pdf
(492.97 KiB) Downloaded 858 times
Post Sun May 26, 2013 6:02 pm
Here is how to post ffmpeg -i info: viewtopic.php?f=5&t=1123
cliverob
Post Mon May 27, 2013 1:11 am
Thanks for that. The ffmpeg info log is below.
I can see this - '[asf @ 034A5AE0] Ext DRM protected stream detected, decoding will likely fail!' in the ffmpeg log but the file plays on the PC on Samsung Allshare so DRM must be OK. But if I try and play it on another device, i.e. the TV it fails with the message "The selected file is not currently supported".
The latest detailed log zip file is attached also a copy of the media Info for the .wmv file.
Hope this all helps to find the problem. Thanks again.
Clive
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\clive>cd"\ProgramFiles\Serviio\lib
The system cannot find the path specified.
C:\Users\clive>cd"\Program\Serviio\lib
C:\Users\clive> cd "\Program Files\Serviio\lib
C:\Program Files\Serviio\lib>ffmpeg.exe -i "C:\Users\clive\My Videos\Gardeners_W
orld_2013_Episode_7.wmv"
ffmpeg version 1.1.1 Copyright (c) 2000-2013 the FFmpeg developers
built on Feb 5 2013 21:59:54 with gcc 4.7.2 (GCC)
p --enable-fontconfig --enable-libfreetype --enable-zlib --extra-libs='-lrtmp -l
polarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-
runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-
mingw32- --pkg-config=pkg-config
libavutil 52. 13.100 / 52. 13.100
libavcodec 54. 86.100 / 54. 86.100
libavformat 54. 59.106 / 54. 59.106
libavdevice 54. 3.102 / 54. 3.102
libavfilter 3. 32.100 / 3. 32.100
libswscale 2. 1.103 / 2. 1.103
[asf @ 034A5AE0] DRM protected stream detected, decoding will likely fail!
[asf @ 034A5AE0] Digital signature detected!
[wmv3 @ 0003E660] Extra data: 8 bits left, value: 0
Guessed Channel Layout for Input Stream #0.0 : stereo
Input #0, asf, from 'C:\Users\clive\My Videos\Gardeners_World_2013_Episode_7.wmv
title : Gardeners' World: 2013: Episode 7
encryption : ASF Extended Content Encryption
ASF_Protection_Type: DRM
ASF_Key_ID : sbdZL4sXiE2ASYoSN15y0A==
ASF_License_URL : http://www.microsoft.com/isapi/redir.dl ... rm&pver=2&
os=win&sbp=newclient
WMFSDKVersion : 12.0.7601.17514
WMFSDKNeeded : 0.0.0.0000
IsVBR : 0
Agility FPS : 1103626
Duration: 00:28:55.04, start: 0.000000, bitrate: 1384 kb/s
Stream #0:0: Audio: wmav2 (a[1][0][0] / 0x0161), 48000 Hz, stereo, fltp, 128
kb/s
Stream #0:1: Video: wmv3 (Main) (WMV3 / 0x33564D57), yuv420p, 720x404, 1250
kb/s, 25 tbr, 1k tbn, 1k tbc
serviio detailed log 27 MAY.7z
(29.95 KiB) Downloaded 504 times
MediaInfo Gardeners_World_2013_Episode_7.wmv.txt
(4.46 KiB) Downloaded 618 times
Post Tue May 28, 2013 11:42 am
Does it play on the TV using AllShare server?
the DRM is the likely cause.
cliverob
Post Fri May 31, 2013 2:39 am
No, it does not play on the TV using AllShare server. However, the file plays on the PC on Samsung Allshare so surely DRM must be OK?
What I still find difficult to understand is that the .wmv files used to play on the TV with Allshare but don't now!
Post Sun Jun 02, 2013 1:46 pm
Try to transcode all wmv files. Add this
<Matches container="asf" />
after
in the C/D/E profile.
cliverob
Post Mon Jun 03, 2013 8:28 am
Hi Petr,
Was not sure what to do but after searching found 'profiles' in 'config' with '<Matches container="mp4" vCodec="mjpeg" />' under 'C/D/E-series'. Did an edit adding '<Matches container="asf" />', saved and closed. Restarted Serviio and PC and attached is the profile log. Not sure if this was correct though. Does this help please?
Still getting 'file not supported' error message.
Thanks very much.
profiles 3 June 13.txt
(91.77 KiB) Downloaded 572 times
Post Mon Jun 03, 2013 1:11 pm
that's right. an you post a new log of playng the file now?
