Serviio on Windows Home Server v1
fozzie bear
Post Wed May 08, 2013 5:50 pm
Apologies its been a long while since I visited these forums and I have lost touch a bit with progress.
Please can someone tell me what the current arrangements are for Windows Home Server v1? Is the WHS add in still supported or has this been dropped for a standalone generic application for all versions of windows. I was looking at my Home Server that just chugs away 24 x7 x 365 without being touched and I notice I have both a Serviio Add-In installed and a standalone application also in Add Remove Programs for some reason. The add in is 0.6.1.0 and the standalone app v 1.1.
Will the two be conflicting with each other and should I remove one. If so what does the standalone version offer over the WHS Add-in
Many thanks
Fozzie
Post Thu May 09, 2013 4:25 pm
Re: Serviio on Windows Home Server v1
Remove the add-in. It's just a console replacement. You will have to use the console in Remote Desktop mode to configure your Serviio server.
fozzie bear
Post Sun May 12, 2013 7:35 pm
Many thanks Zip
Fozzie
