Pc freeze
Holowcow
Post Sat May 11, 2013 8:16 pm
Pc freeze
Since I installed Serviio, My PC Freeze every few hours, Only way to restart is hard reset.
I checked my event log and there are a lot of errors which I don't have a clue what their meaning.
Is it possible my computer freez because of the overload of the USB wifi adapter?
Post Sun May 12, 2013 12:16 am
Re: Pc freeze
Anything is possible, but I would think it unlikely. Have you confirmed that it is Serviio - shut down the Serviio service, close the console and see if it happens again. Have you plenty of free disk space and memory. What os are you using? What PC specs (memory, disk, processor, wireless adaptor). Have you reinstalled Serviio and Java?
If it is Serviio, post the event log and someone here may be able to interpret it for you.
Holowcow
Post Sun May 12, 2013 4:42 pm
Re: Pc freeze
How can i post the event log here?
when i installed serviio for the first time it didn't start, then after
reinstalling java it worked.
my system info:
3770k
670gtx
16GB ram
256gb ssd for windows
2tb for storage
seasonic 660x
tp link wireless usb adapter
tp link 54g router
sony bravia 26ex553
Post Mon May 13, 2013 12:42 am
Re: Pc freeze
You can save the Event Log to a file (In Win7 Event Viewer, down right hand side, "Save all events as..."). Unfortunately it saves the whole log, so you'll need to let us know times of when things occurred. It may be too big to post as well, so we may have to re-think.
Have you tried (if possible) a wired connection rather than wireless to rule out the adaptors. Where is your Windows temp file - on the SSD or normal hard drive. Are you transcoding when this happens?
