"The archive you selected isn't aviable at this moment"
jibiril
Post Fri May 10, 2013 2:08 am
Hello, I have an UN46ES6800GCDF and I am trying to reproduce the file in the image:
and the message in the title("The archive you selected isn't aviable at this moment") is shown,
originally the video was this:
and the same message was displayed, I thought it was all those fonts and subs with weird characters so I extracted only the tracks I was interested in but the problem as I stated before persisted.
the most strange thing I noticed is that I can reproduce the following file without any problem(which to my understanding is equivalent)
Thank you.
Edit: this is what the log says: 2013-05-10 00:18:42,862 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Canot transcode to H264
java.lang.RuntimeException: Canot transcode to H264
Post Fri May 10, 2013 4:22 pm
Re: "The archive you selected isn't aviable at this moment"
Did you edit your profile in any way?
jibiril
Post Sat May 11, 2013 1:59 am
zip wrote:Did you edit your profile in any way?
Yes, but just a little, I added
maxVBitrate="14500"
to all possible video transcoding in the "Samsung TV / player (C/D/E-series)" profile to not experience "latency" issues.
Post Mon May 13, 2013 10:24 am
Yes, but but adding that you're saying not to remux, but to transcode. Thus you will lose quality and increase CPU load. Also, you have to set targetVCodec="mpeg2video" on all the configs you changed, to tell it to transcode to mpeg2, otherwise it tries to transcode to the original codec (but transcoding to h264 is not supported - hence the message)
jibiril
Post Sun May 19, 2013 5:45 pm
zip wrote:Yes, but but adding that you're saying not to remux, but to transcode. Thus you will lose quality and increase CPU load. Also, you have to set targetVCodec="mpeg2video" on all the configs you changed, to tell it to transcode to mpeg2, otherwise it tries to transcode to the original codec (but transcoding to h264 is not supported - hence the message)
This worked, thanks, but this brought a new problem(Which I think it's unrelated to this solution) so movies started having long loading times while it is playing, like there is a "loading" message in the right top corner, I had the same problem before limiting the maxVbitrate but now the loading problems doesn't present when there is a peak of bitrate, also it's happening with movies that didn't happen before and I tried with those erassing that new 'targetVCodec="mpeg2video"' line and the problem persist, nothing in the computer or in the net have changed, do someone have any idea what this might be? I am really at lost.
