Serviio not visible on samsung c7000 smart tv.
Coopermed
Post Thu Mar 28, 2013 12:18 pm
Good afternoon,
I`ve been trying to make serviio visible on samsung c7000 smart tv but seems impossible.
Serviio shows the pc bound ip address (10.10.10.116), samsung smart tv profile (10.10.10.127).
I opened the 8895 and 1900 ports on eset firewall.
But tv still doesn`t recognizes any conection.
Thanks and best regards.
(210.48 KiB) Downloaded 405 times
slyguy42o
Post Thu Mar 28, 2013 2:30 pm
Re: Serviio not visible on samsung c7000 smart tv.
so you see the device in the serviio console but your not able to see the server from you TV? I would try dropping all firewalls completely just to see if there is something else being blocked.
darkcloud784
Post Mon May 13, 2013 12:32 am
I am having this same issue. I can see my ln46c630k1fxza samsung tv on my console but the tv cant see serviio. I have all firewalls disabled. Im using ubuntu 12.10. All ports are open on our network, the tv can see my computer even. Help would be appreciated.
Post Mon May 13, 2013 10:36 am
darkcloud784
Post Wed May 15, 2013 2:12 am
zip wrote:post detailed log
Thanks for the reply, I figured it finally though. Apparently multicasting wasn't setup right for some reason, added static route to my router and bam-o it was there.
Users browsing this forum: Google [Bot] and 30 guests
