SSL / https
would it be possible to incorporate a way to allow the use of ssl certificates (including self signed) for the media browsers? possibly have a section on the console that allows you to input the keys and enable it?
spudy12 wrote:Do you by any chance have a guide on how to set it up?
syoa28 wrote:HI , I'm new and I'm trying to enable SSL on my serviio media browser but unable to do so with the instructions here. I'm running windows 2012 essentials server and running anywhere access remote as my default site. i don't see serviio in my IIS.
would you be able to provide instructions to use IIS for Serviio, then enable SSL?
Also what xml file do I edit to edit the login page for serviio? and can we integrate AD to authenticate users?
thnaks
7) Enable Proxy (IIS -> Computer Node -> IIS (Section) -> Application Routing -> Server Proxy Settings (Sidebar) -> Check Enable Proxy)
