Close: REQ: profile for Motorola Razr Maxx
ric_dk
Post Wed May 15, 2013 5:47 pm
Hello, I'm using my Moto Razer Maxx for streaming video to my TV. It works fine.. but I need a profile to force the correct transcoding/remapping
I use XBMC on the moto.
I found that using the profile "manta WIFI Center" gives perfect playback of 720p mkv files. (if I reed the profile correct it's mpeg2 video and mp3 audio), but trying to play a 1080p .m2ts (blueray stream) is not good.. it seems not to be transcoded.
So basically I need a profile that will transcode/remap all known formats so they will play on my Moto. Playing a 1080p mkv file don't run smooth either.. so 720p seems to be max for streaming video, and as my TV is 720p, all above is kinda waste)
I tried to look at the profiles to cut and paste one my self.. but it's beyond my brains capability to figure it out. So if someone would pls. provide a profile.
regards
ric_dk
Post Tue May 21, 2013 10:40 am
Re: Close: REQ: profile for Motorola Razr Maxx
I found this in another threat .. and it works.. and it's simple enough for my brain to understand.. so I can edit it to fit my needs :)
<Profile id="pelele" name="Pelele" extendsProfileId="1" alwaysEnableTranscoding="true" >
         <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="mp3" forceStereo="true" aSamplerate="44100" maxVBitrate="1000" maxHeight="480">
            <Matches container="*" />
thx to peter1212 for the code ;)
