No Renderers/Devices Found
Lindhorst
Post Wed May 15, 2013 3:08 pm
Hi there! I just installed Serviio and it's not picking up ANY of my renderers/devices that it should. I have a Panasonic VIERA TC-55VT50 telvision, a PS3, and an Oppo blu-ray player--all of which should be listed. They were listed when I used the PS3 Media Server. In fact, I changed to Serviio because the PS3 Media Server stopped listing my devices. So i'm guessing whatever problem caused that is causing the same here. However, when I get it fixed I'm definitely staying with Serviio. I like everything else about this much more than the PMS. I've tried turning off Windows Firewall, but that didn't change anything.
Has anyone else had this problem? I looked through the FAQ and did a couple of searches through the forum, but I couldn't find anything else along these lines. Any help you guys could give me would be much appreciated. I'm ready to give this new program a whirl!!
Lindhorst
Post Wed May 15, 2013 5:12 pm
Re: No Renderers/Devices Found
Lindhorst
Post Wed May 15, 2013 7:56 pm
It's pretty long, but here it is. Thanks for the info showing me how to do this.
2013-05-15 09:44:00,173 INFO [MediaServer] ------------------------------------------------------------------------
2013-05-15 09:44:00,174 INFO [MediaServer] Serviio DLNA media streaming server v 1.2.1 (rev. a2aa56064460+)
2013-05-15 09:44:00,174 INFO [MediaServer] Petr Nejedly 2009-2013
2013-05-15 09:44:00,174 INFO [MediaServer] http://www.serviio.org
2013-05-15 09:44:00,174 INFO [MediaServer] Java 1.7.0_09-Oracle Corporation
2013-05-15 09:44:00,174 INFO [MediaServer] OS Windows 8 x86 6.2
2013-05-15 09:44:00,174 INFO [MediaServer] File encoding: windows-1252
2013-05-15 09:44:00,175 INFO [MediaServer] Headless mode enabled: true
2013-05-15 09:44:00,175 INFO [MediaServer] User: OWNER-7071F8FDE$
2013-05-15 09:44:00,175 INFO [MediaServer] User home dir: C:\
2013-05-15 09:44:00,175 INFO [MediaServer] Temp dir: C:\WINDOWS\TEMP\
2013-05-15 09:44:00,175 INFO [MediaServer] ------------------------------------------------------------------------
2013-05-15 09:44:00,319 INFO [WebServer] Socket buffer set to 65535 bytes
2013-05-15 09:44:00,321 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-05-15 09:44:00,346 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-05-15 09:44:00,346 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-05-15 09:44:00,361 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-05-15 09:44:08,234 INFO [DBSchemaUpdateExecutor] Updating DB schema
2013-05-15 09:44:20,754 INFO [DBSchemaUpdateExecutor] Cleaning persistent cache
2013-05-15 09:44:22,161 INFO [Device] Created UPnP Device with UUID: c5db91ac-54f5-3daa-b7ba-6fea634c26b1, bound address: 192.168.0.3
2013-05-15 09:44:22,176 WARN [IndexedDiskCache] Region [online_technical_metadata] Reseting cache
2013-05-15 09:44:22,930 INFO [MediaServer] ------------------------------------------------------------------------
2013-05-15 09:44:22,930 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2013-05-15 09:44:23,279 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2013-05-15 09:44:23,321 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2013-05-15 09:44:23,327 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2013-05-15 09:44:23,329 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2013-05-15 09:44:23,330 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2013-05-15 09:44:23,330 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2013-05-15 09:44:23,335 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2013-05-15 09:44:23,336 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2013-05-15 09:44:23,337 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2013-05-15 09:44:23,339 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2013-05-15 09:44:23,339 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2013-05-15 09:44:23,340 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2013-05-15 09:44:23,340 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2013-05-15 09:44:23,341 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2013-05-15 09:44:23,341 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2013-05-15 09:44:23,342 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2013-05-15 09:44:23,342 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2013-05-15 09:44:23,342 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2013-05-15 09:44:23,342 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2013-05-15 09:44:23,343 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2013-05-15 09:44:23,343 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2013-05-15 09:44:23,343 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2013-05-15 09:44:23,344 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2013-05-15 09:44:23,344 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2013-05-15 09:44:23,344 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2013-05-15 09:44:23,344 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2013-05-15 09:44:23,345 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2013-05-15 09:44:23,345 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2013-05-15 09:44:23,345 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2013-05-15 09:44:23,345 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2013-05-15 09:44:23,345 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2013-05-15 09:44:23,346 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2013-05-15 09:44:23,346 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2013-05-15 09:44:23,346 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2013-05-15 09:44:23,347 INFO [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2013-05-15 09:44:23,362 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2013-05-15 09:44:23,363 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2013-05-15 09:44:23,363 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2013-05-15 09:44:23,363 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2013-05-15 09:44:23,373 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2013-05-15 09:44:23,373 INFO [PluginCompilerThread] Started looking for plugins
2013-05-15 09:44:23,374 INFO [UpdateChecker] Checking if a new version is available
2013-05-15 09:44:24,337 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-05-15 09:44:24,365 INFO [WebServer] WebServer starting on port 8895
2013-05-15 09:44:24,371 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-05-15 09:44:24,372 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-05-15 09:44:24,372 INFO [EventDispatcher] Starting EventDispatcher
2013-05-15 09:44:24,381 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2013-05-15 09:44:24,493 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth5 (NVIDIA nForce Networking Controller #2) and address 192.168.0.3, timeout = 0
2013-05-15 09:44:24,506 INFO [RendererSearchSender] Searching for Renderer devices
2013-05-15 09:44:50,543 INFO [FeedUpdaterThread] Started looking for information about online resources
2013-05-15 09:44:50,547 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-05-15 09:44:50,554 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-05-15 09:44:50,555 INFO [PlaylistMaintainerThread] Started looking playlist changes
2013-05-15 09:45:10,389 INFO [ServiioConsole] Starting Serviio Console
2013-05-15 09:45:10,484 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2013-05-15 09:45:11,166 INFO [Messages] Loaded console message bundle for locale: en
2013-05-15 09:45:14,181 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2013-05-15 09:45:14,801 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2013-05-15 09:46:35,762 INFO [PortMappingChecker] Running a check for external mapping of port 23424 on '70.116.69.177'
2013-05-15 09:46:39,397 INFO [PortMappingChecker] Port 23424 is closed
2013-05-15 09:46:49,224 WARN [ServiioStatusService] ValidationException occured. Returning error code 400 to the REST layer. Message: null
2013-05-15 09:46:59,685 WARN [ServiioStatusService] ValidationException occured. Returning error code 400 to the REST layer. Message: null
2013-05-15 09:47:54,107 INFO [PortMappingChecker] Running a check for external mapping of port 23424 on '70.116.69.177'
2013-05-15 09:47:57,453 INFO [PortMappingChecker] Port 23424 is closed
2013-05-15 14:51:41,159 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2013-05-15 14:51:41,230 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2013-05-15 14:51:41,231 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2013-05-15 14:51:41,287 INFO [EventDispatcher] Leaving EventDispatcher
2013-05-15 14:51:41,304 INFO [WebServer] WebServer shutting down
2013-05-15 14:51:42,645 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2013-05-15 14:51:47,214 INFO [WebServer] WebServer starting on port 8895
2013-05-15 14:51:47,215 INFO [EventDispatcher] Starting EventDispatcher
2013-05-15 14:51:47,226 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-05-15 14:51:47,226 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-05-15 14:51:47,319 INFO [RendererSearchSender] Searching for Renderer devices
2013-05-15 14:51:47,330 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth5 (NVIDIA nForce Networking Controller #2) and address 192.168.0.3, timeout = 0
2013-05-15 14:52:51,374 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2013-05-15 14:52:51,395 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2013-05-15 14:52:51,422 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2013-05-15 14:52:51,395 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2013-05-15 14:52:51,510 INFO [FeedUpdaterThread] Finished looking for online resources information
2013-05-15 14:52:51,596 INFO [PluginCompilerThread] Finished looking for plugins
2013-05-15 14:52:52,529 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2013-05-15 14:52:52,529 INFO [WebServer] WebServer shutting down
2013-05-15 14:52:52,529 INFO [EventDispatcher] Leaving EventDispatcher
2013-05-15 14:52:52,529 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2013-05-15 14:52:52,529 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2013-05-15 14:52:52,637 INFO [DatabaseManager] Shutting down database
2013-05-15 14:53:00,978 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-05-15 14:53:02,491 INFO [ServiioConsole] Leaving Serviio Console
2013-05-15 14:53:39,864 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2013-05-15 14:53:40,348 INFO [MediaServer] ------------------------------------------------------------------------
2013-05-15 14:53:40,348 INFO [MediaServer] Serviio DLNA media streaming server v 1.2.1 (rev. a2aa56064460+)
2013-05-15 14:53:40,348 INFO [MediaServer] Petr Nejedly 2009-2013
2013-05-15 14:53:40,348 INFO [MediaServer] http://www.serviio.org
2013-05-15 14:53:40,348 INFO [MediaServer] Java 1.7.0_09-Oracle Corporation
2013-05-15 14:53:40,348 INFO [MediaServer] OS Windows 8 x86 6.2
2013-05-15 14:53:40,348 INFO [MediaServer] File encoding: windows-1252
2013-05-15 14:53:40,372 INFO [MediaServer] Headless mode enabled: true
2013-05-15 14:53:40,372 INFO [MediaServer] User: Jason Wesley Clark
2013-05-15 14:53:40,372 INFO [MediaServer] User home dir: C:\Users\Jason Wesley Clark
2013-05-15 14:53:40,372 INFO [MediaServer] Temp dir: C:\Users\JASONW~1\AppData\Local\Temp\
2013-05-15 14:53:40,372 INFO [MediaServer] ------------------------------------------------------------------------
2013-05-15 14:53:43,044 INFO [WebServer] Socket buffer set to 65535 bytes
2013-05-15 14:53:43,052 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-05-15 14:53:43,205 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-05-15 14:53:43,205 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-05-15 14:53:43,237 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-05-15 14:53:43,274 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2013-05-15 14:53:45,431 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2013-05-15 14:53:45,431 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2013-05-15 14:53:45,432 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2013-05-15 14:53:45,432 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2013-05-15 14:53:45,433 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2013-05-15 14:53:45,433 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2013-05-15 14:53:45,434 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2013-05-15 14:53:45,434 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2013-05-15 14:53:45,434 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2013-05-15 14:53:45,435 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2013-05-15 14:53:45,435 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2013-05-15 14:53:45,436 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2013-05-15 14:53:45,436 DEBUG [DBLogDAOImpl] Checking if script 'script-1.1.sql' has been run
2013-05-15 14:53:45,436 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.sql' has been run
2013-05-15 14:53:45,437 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.1.sql' has been run
2013-05-15 14:53:45,497 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2013-05-15 14:53:45,505 DEBUG [LicenseValidator] Validating license file (352 bytes)
2013-05-15 14:53:46,798 INFO [MediaServer] ------------------------------------------------------------------------
2013-05-15 14:53:46,799 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2013-05-15 14:53:46,799 INFO [MediaServer] ------------------------------------------------------------------------
2013-05-15 14:53:46,823 DEBUG [LocalAddressResolverStrategy] Resolving host IP address automatically
2013-05-15 14:53:47,318 INFO [Device] Created UPnP Device with UUID: c5db91ac-54f5-3daa-b7ba-6fea634c26b1, bound address: 192.168.0.3
2013-05-15 14:53:48,947 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2013-05-15 14:53:48,948 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2013-05-15 14:53:49,119 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2013-05-15 14:53:49,119 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2013-05-15 14:53:49,184 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2013-05-15 14:53:49,184 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2013-05-15 14:53:49,187 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2013-05-15 14:53:49,187 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2013-05-15 14:53:49,187 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2013-05-15 14:53:49,187 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2013-05-15 14:53:49,188 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2013-05-15 14:53:49,188 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2013-05-15 14:53:49,236 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2013-05-15 14:53:49,237 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2013-05-15 14:53:49,251 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2013-05-15 14:53:49,251 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2013-05-15 14:53:49,251 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2013-05-15 14:53:49,251 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012
2013-05-15 14:53:49,253 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2013-05-15 14:53:49,253 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2012
2013-05-15 14:53:49,253 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2013-05-15 14:53:49,253 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010
2013-05-15 14:53:49,254 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2013-05-15 14:53:49,254 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010us
2013-05-15 14:53:49,255 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2013-05-15 14:53:49,255 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2011
2013-05-15 14:53:49,255 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2013-05-15 14:53:49,255 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2013-05-15 14:53:49,255 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2013-05-15 14:53:49,255 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2013-05-15 14:53:49,256 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2013-05-15 14:53:49,256 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2013-05-15 14:53:49,256 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2013-05-15 14:53:49,256 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2013-05-15 14:53:49,256 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2013-05-15 14:53:49,256 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2013-05-15 14:53:49,256 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2013-05-15 14:53:49,257 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2013-05-15 14:53:49,257 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2013-05-15 14:53:49,257 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011
2013-05-15 14:53:49,257 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2013-05-15 14:53:49,257 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2010
2013-05-15 14:53:49,257 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2013-05-15 14:53:49,257 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile plps2010
2013-05-15 14:53:49,257 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2013-05-15 14:53:49,258 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2013-05-15 14:53:49,258 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2013-05-15 14:53:49,258 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2009
2013-05-15 14:53:49,258 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2013-05-15 14:53:49,258 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 22
2013-05-15 14:53:49,258 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2013-05-15 14:53:49,258 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011a
2013-05-15 14:53:49,259 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2013-05-15 14:53:49,259 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011
2013-05-15 14:53:49,259 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2013-05-15 14:53:49,259 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2010
2013-05-15 14:53:49,259 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2013-05-15 14:53:49,259 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012us
2013-05-15 14:53:49,259 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2013-05-15 14:53:49,259 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011us
2013-05-15 14:53:49,259 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2013-05-15 14:53:49,259 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonySTR
2013-05-15 14:53:49,260 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2013-05-15 14:53:49,260 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonyCMT
2013-05-15 14:53:49,260 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2013-05-15 14:53:49,260 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viziotv
2013-05-15 14:53:49,260 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2013-05-15 14:53:49,260 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile win8metro
2013-05-15 14:53:49,261 INFO [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2013-05-15 14:53:49,291 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2013-05-15 14:53:49,291 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile flv_player
2013-05-15 14:53:49,292 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2013-05-15 14:53:49,292 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo
2013-05-15 14:53:49,292 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2013-05-15 14:53:49,292 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile wp8
2013-05-15 14:53:49,292 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2013-05-15 14:53:49,462 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\plugins
2013-05-15 14:53:49,463 INFO [PluginCompilerThread] Started looking for plugins
2013-05-15 14:53:49,464 INFO [UpdateChecker] Checking if a new version is available
2013-05-15 14:53:49,540 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\lib/ffmpeg.exe
2013-05-15 14:53:49,556 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\lib/ffmpeg.exe
2013-05-15 14:53:50,783 DEBUG [DCRawWrapper] Invoking DCRAW to check if it exists of path C:\Program Files\Serviio\lib/dcraw.exe
2013-05-15 14:53:50,783 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\lib/dcraw.exe
2013-05-15 14:53:51,175 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-05-15 14:53:51,289 INFO [WebServer] WebServer starting on port 8895
2013-05-15 14:53:51,323 DEBUG [DiscoveryManager] UPNP device c5db91ac-54f5-3daa-b7ba-6fea634c26b1 (192.168.0.3) is available
2013-05-15 14:53:51,324 INFO [EventDispatcher] Starting EventDispatcher
2013-05-15 14:53:51,324 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-05-15 14:53:51,324 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-05-15 14:53:51,331 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2013-05-15 14:53:51,452 INFO [RendererSearchSender] Searching for Renderer devices
2013-05-15 14:53:51,467 DEBUG [RendererSearchSender$RendererSearchWorker] Multicasting SSDP M-SEARCH using interface eth5 (NVIDIA nForce Networking Controller #2) and address 192.168.0.3, timeout = 0
2013-05-15 14:53:51,467 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth5 (NVIDIA nForce Networking Controller #2) and address 192.168.0.3, timeout = 0
2013-05-15 14:53:51,486 DEBUG [RendererSearchSender$RendererSearchWorker] Sending 1 'm-search' messages
2013-05-15 14:53:51,490 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth5 (NVIDIA nForce Networking Controller #2) and address 192.168.0.3, timeout = 0
2013-05-15 14:53:51,490 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device c5db91ac-54f5-3daa-b7ba-6fea634c26b1
2013-05-15 14:53:51,503 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.0.3:58575s
2013-05-15 14:53:51,505 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.0.3:58575s
2013-05-15 14:53:53,185 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:WdNAS:1 from address /192.168.0.3:53949s
2013-05-15 14:53:53,322 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:08 (advertisement duration is 1800 sec.)
2013-05-15 14:53:57,193 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:WdNAS:1 from address /192.168.0.3:53949s
2013-05-15 14:53:57,499 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2013-05-15 14:54:00,197 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:WdNAS:1 from address /192.168.0.3:53949s
2013-05-15 14:54:01,486 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth5 (NVIDIA nForce Networking Controller #2) and address 192.168.0.3, timeout = 0
2013-05-15 14:54:01,486 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device c5db91ac-54f5-3daa-b7ba-6fea634c26b1
2013-05-15 14:54:03,202 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:WdNAS:1 from address /192.168.0.3:53949s
2013-05-15 14:54:03,316 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:08 (advertisement duration is 1800 sec.)
2013-05-15 14:54:07,192 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:WdNAS:1 from address /192.168.0.3:53949s
2013-05-15 14:54:08,403 DEBUG [ServiioConsole] Initializing Serviio Console
2013-05-15 14:54:08,422 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2013-05-15 14:54:08,423 INFO [ServiioConsole] Starting Serviio Console
2013-05-15 14:54:08,719 DEBUG [SwingHelper] Choosing java look and feel: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
2013-05-15 14:54:08,874 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2013-05-15 14:54:09,751 DEBUG [ServiioConsole] Retrieving console settings
2013-05-15 14:54:09,845 DEBUG [ServiioConsole] Setting console locale to be: en
2013-05-15 14:54:09,867 INFO [Messages] Loaded console message bundle for locale: en
2013-05-15 14:54:10,197 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:WdNAS:1 from address /192.168.0.3:53949s
2013-05-15 14:54:10,416 DEBUG [ServiioFrameView] Initializing main frame
2013-05-15 14:54:10,503 DEBUG [ServiioFrameView] System tray is supported
2013-05-15 14:54:10,736 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups
2013-05-15 14:54:11,467 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-05-15 14:54:11,478 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-05-15 14:54:11,480 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth5 (NVIDIA nForce Networking Controller #2) and address 192.168.0.3, timeout = 0
2013-05-15 14:54:11,481 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device c5db91ac-54f5-3daa-b7ba-6fea634c26b1
2013-05-15 14:54:12,250 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2013-05-15 14:54:12,445 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups
2013-05-15 14:54:13,204 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:WdNAS:1 from address /192.168.0.3:53949s
2013-05-15 14:54:13,314 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:04:08 (advertisement duration is 1800 sec.)
2013-05-15 14:54:13,665 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2013-05-15 14:54:13,677 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2013-05-15 14:54:14,503 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2013-05-15 14:54:14,507 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=0, titleKey=pc5dczc_media_library, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = null
2013-05-15 14:54:14,528 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A, titleKey=audio, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-05-15 14:54:14,534 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_A, titleKey=artists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-05-15 14:54:14,542 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,546 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,552 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,557 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,562 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=AL_A, titleKey=album_artists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-05-15 14:54:14,567 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListAlbumArtistInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,573 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListAlbumArtistsForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,578 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForAlbumArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,583 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,587 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-05-15 14:54:14,591 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=MUSIC_TRACK, idPrefix=FOL, recursive=true, cacheRegion=local_default
2013-05-15 14:54:14,597 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-05-15 14:54:14,602 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioGenresByNameCommand, containerClass=MUSIC_GENRE, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,607 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForGenreCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,612 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_C, titleKey=composers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-05-15 14:54:14,618 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListComposerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,623 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListComposersForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=COM, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,627 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForComposerCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,633 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForComposerAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,638 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-05-15 14:54:14,643 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,647 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForInitialCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,653 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_R, titleKey=random, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-05-15 14:54:14,657 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListRandomSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=no_cache
2013-05-15 14:54:14,662 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-05-15 14:54:14,667 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioPlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,671 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForPlaylistCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,676 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-05-15 14:54:14,680 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=MUSIC_TRACK, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2013-05-15 14:54:14,686 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_S, titleKey=All songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2013-05-15 14:54:14,691 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,696 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_AS, titleKey=Artist Songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2013-05-15 14:54:14,701 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsByNameCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART_S, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,707 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,711 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_ALB, titleKey=All albums, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2013-05-15 14:54:14,716 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllAlbumsCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,721 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,725 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I, titleKey=image, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-05-15 14:54:14,731 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_A, titleKey=albums, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-05-15 14:54:14,735 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListFlatImageFoldersByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,741 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForFolderCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,745 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-05-15 14:54:14,751 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true, cacheRegion=local_default
2013-05-15 14:54:14,755 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_Y, titleKey=year, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-05-15 14:54:14,761 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,766 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,771 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_T, titleKey=month, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-05-15 14:54:14,776 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,781 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationMonthsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=MON, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,787 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationMonthAndYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,792 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-05-15 14:54:14,796 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagePlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,801 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForPlaylistCommand, containerClass=null, itemClass=PHOTO, idPrefix=S, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,806 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-05-15 14:54:14,811 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2013-05-15 14:54:14,816 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_AI, titleKey=All images, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2013-05-15 14:54:14,821 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListAllImagesCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,826 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V, titleKey=video, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-05-15 14:54:14,831 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-05-15 14:54:14,835 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,840 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForInitialCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,845 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_M, titleKey=movies, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-05-15 14:54:14,851 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListMovieVideosByNameCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,855 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_S, titleKey=series, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-05-15 14:54:14,861 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeriesByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SER, recursive=false, cacheRegion=local_resetafterplay
2013-05-15 14:54:14,865 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeasonsForSeriesCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SSN, recursive=false, cacheRegion=local_resetafterplay
2013-05-15 14:54:14,871 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListEpisodesForSeriesSeasonCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2013-05-15 14:54:14,876 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-05-15 14:54:14,881 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=local_default
2013-05-15 14:54:14,885 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LV, titleKey=last_viewed, class=CONTAINER, cacheRegion=local_resetafterplay, browsable = null, editable = true
2013-05-15 14:54:14,890 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastViewedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2013-05-15 14:54:14,895 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LA, titleKey=last_added, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-05-15 14:54:14,900 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastAddedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,905 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-05-15 14:54:14,910 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoGenresByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,917 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForGenreCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,921 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_A, titleKey=actors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-05-15 14:54:14,927 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,932 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,938 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForActorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,943 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_D, titleKey=directors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-05-15 14:54:14,949 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,954 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,959 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForDirectorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,964 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_P, titleKey=producers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-05-15 14:54:14,970 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,975 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducersForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,981 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForProducerCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,987 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-05-15 14:54:14,992 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoPlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
2013-05-15 14:54:14,998 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForPlaylistCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=S, recursive=false, cacheRegion=local_default
2013-05-15 14:54:15,003 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-05-15 14:54:15,008 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2013-05-15 14:54:15,011 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2013-05-15 14:54:15,865 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-05-15 14:54:15,865 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-05-15 14:54:15,873 DEBUG [ServiioConsole] Reading application data
2013-05-15 14:54:15,873 DEBUG [RepositoryView$LibraryStatusCheckerThread] Starting library status checking thread
2013-05-15 14:54:17,192 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:WdNAS:1 from address /192.168.0.3:53949s
2013-05-15 14:54:17,502 INFO [FeedUpdaterThread] Started looking for information about online resources
2013-05-15 14:54:17,502 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-05-15 14:54:17,502 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-05-15 14:54:17,515 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-05-15 14:54:17,515 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-05-15 14:54:17,516 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-05-15 14:54:17,516 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-05-15 14:54:17,516 INFO [PlaylistMaintainerThread] Started looking playlist changes
2013-05-15 14:54:17,526 DEBUG [PlaylistDAOImpl] Reading all Playlists
2013-05-15 14:54:20,197 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:WdNAS:1 from address /192.168.0.3:53949s
2013-05-15 14:54:23,201 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:WdNAS:1 from address /192.168.0.3:53949s
2013-05-15 14:54:27,190 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:WdNAS:1 from address /192.168.0.3:53949s
2013-05-15 14:54:30,194 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:WdNAS:1 from address /192.168.0.3:53949s
2013-05-15 14:54:33,199 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:WdNAS:1 from address /192.168.0.3:53949s
2013-05-15 14:54:37,192 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:WdNAS:1 from address /192.168.0.3:53949s
2013-05-15 14:54:40,198 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:WdNAS:1 from address /192.168.0.3:53949s
2013-05-15 14:54:43,204 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:WdNAS:1 from address /192.168.0.3:53949s
2013-05-15 14:54:47,191 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:WdNAS:1 from address /192.168.0.3:53949s
2013-05-15 14:54:50,196 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:WdNAS:1 from address /192.168.0.3:53949s
2013-05-15 14:54:51,042 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2013-05-15 14:54:53,199 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:WdNAS:1 from address /192.168.0.3:53949s
2013-05-15 14:54:57,190 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:WdNAS:1 from address /192.168.0.3:53949s
2013-05-15 14:55:00,196 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:WdNAS:1 from address /192.168.0.3:53949s
Post Thu May 16, 2013 11:09 pm
I assume 192.168.0.3 is your IP address..?
There are no incoming connections from your devices, so it is most likely a firewall/spyware issue
Lindhorst
Post Sat May 25, 2013 7:26 am
zip wrote:I assume 192.168.0.3 is your IP address..?
Do you have any suggestions about what I should try? I'm not too familiar with firewalls. I know there's Windows Firewall, and I tried shutting that down, but it did no good. The only other security program I'm running is MalwareBytes Anti-Malware. I'm scanning right now for any SpyWare, but I'm at a loss.
Post Sun May 26, 2013 5:52 pm
Check your router for Multicasting settings and/or UPnP settings and try to play with those.
Users browsing this forum: No registered users and 52 guests
