support serie F (2013)
samcro49
Post Thu May 16, 2013 10:24 am
when will there be an update for the 2013 series (Series F)?
thanks
Peiloy
Post Thu May 16, 2013 12:51 pm
Re: support serie F (2013)
I was also wondering the same thing. I was also wondering what profile to use until there is an update.
Post Thu May 16, 2013 11:10 pm
I don't have the TV. So you guys will have to provide some supported formats. I presume the C/D/E profile should work.
Peiloy
Post Thu May 16, 2013 11:55 pm
zip wrote:I don't have the TV. So you guys will have to provide some supported formats. I presume the C/D/E profile should work.
I just sent the supported formats to you. Let me know if it what you are looking for.
I am specifically having problems playing mkv's with external subs when using the C/D/E profile
Post Fri May 17, 2013 12:32 pm
Peiloy wrote:I am specifically having problems playing mkv's with external subs when using the C/D/E profile
What problems? Post detailed log of playing the file.
Peiloy
Post Fri May 17, 2013 1:27 pm
I will get the log when I go home today. The problem that I am having specifically is that under subtitles when only enable subtitles is checked, subtitles will not play both sub and srt. When I check Enable burned in subs the tv says the file is not playable and it also shows the file size on the tv 0.00GB.
samcro49
Post Tue May 21, 2013 10:28 am
I have especially problems with plugin's
Post Wed May 22, 2013 1:26 pm
It's hard to base this on plugins, as there is no confidence if the online source is up and working as expected.
Do you have issues with local content?
shpak_evgen
Post Sun Jun 02, 2013 3:21 pm
i have F-series TV, and i can see the folders only, but can't see (browse) any content of that folders. for example my another TV is E-series TV, and there is no problems at all.
...Hope you can (and wish) fix it.
Post Mon Jun 03, 2013 4:28 pm
did you try some other profiles?
shpak_evgen
Post Mon Jun 03, 2013 9:27 pm
yes I did. and anyone is not working properly with f-series tv.
p.s. by the way, unfortunately, there is only 3 profiles exist for samsung.
Post Thu Jun 06, 2013 3:54 pm
Can you play the same files with Samsung AllShare server?
TEX4Q
Post Thu Jun 06, 2013 10:27 pm
Hello, I have a weird problem.
When I purchased my Samsung F6400 on may, all videos played using Serviio showed its miniature perfectly on TV. Since a few days ago, these have missing without explanation.
I have tried a lot of changes and nothing happens.
All remaining functions work fine and I am happy with them, although it is very frustrating to see the file without its mini-picture.
What is the solution?
Congratulations, Serviio is superb.
Best regards.
Brammers
Post Tue Jun 11, 2013 11:11 pm
Working fine here on an UE46F6670 with latest firmware.
Using generic profile. Can watch and seek MP3 audio, MP4 video and MKV video.
J
Post Wed Jun 12, 2013 4:01 pm
Brammers wrote:Working fine here on an UE46F6670 with latest firmware.
J
Hi, can you test with the latest beta? Are there any files that you cannot play with the C/D/E profile or that play better with generic?
Brammers
Post Thu Jun 13, 2013 11:06 pm
I made a mistake - most MKVs won't seek :/
I'll have a go with 1.2.1 on both profiles, make some notes and then try the beta this weekend (both profiles).
What does the E profile do to MKVs?
J
Post Sat Jun 15, 2013 12:14 am
Brammers wrote:What does the E profile do to MKVs?
J
Streams natively, most of the time. Unless the H264 level is too high. You can try disabling transcoding if it helps with seeking.
shpak_evgen
Post Sat Jun 15, 2013 1:11 pm
zip wrote:Can you play the same files with Samsung AllShare server?
yes, i can play all my films with Samsung AllShare server....
Brammers
Post Sat Jun 15, 2013 10:54 pm
J
Been watching a few MKVs using the E profile on 1.2.1 today - no seeking, but seems OK. The F series seems to have a minor lip sync issue which recent firmware has improved but not totally fixed - only happens on hi res streams though.
Going to try the beta tomorrow.
J
Brammers
Post Sun Jun 16, 2013 8:55 pm
Tried 1.3 beta1 ... didn't notice anything different really.
Is there something specific I should be looking out for?
J
