Serviio won't work when VMWare Workstation is installed
sampath.mamilapo
Post Fri May 17, 2013 12:23 am
I am running Serviio on Linux without problems for a while. For my work I had to install VMWare (and I cannot remove it).
Whenever there is a new kernel for Linux (Ubuntu 12.04) that sometimes comes with a daily update, VMWare needs to compile some stuff in the kernel and do a lot of other network stuff at startup. After that Serviio won't be visible to any device anymore (Samsung TV, Android Mobile, etc.). Due to VMWare there are two additional IP-Adresses under 'Bound IP Adress'. I can set any available address or put it on automatically - it won't work anymore.
MiniDLNA will still work. All devices can see it even if VMWare is installed.
When a new kernel is installed by the Linux update, Serviio will be visible again to all devices. Everything works flawlessly. Still I need VMWare for my work and eventually I need to start it up, let it make changes to the kernel and stuff which will kill Serviio :(
Any idea how I can fix this? As I mentioned, manually setting the IP in 'Bound IP Address' doesn't work!
Post Fri May 17, 2013 9:51 am
Re: Serviio won't work when VMWare Workstation is installed
post detailed log of when you set the proper IP in the console and it still doesn't work
sampath.mamilapo
Post Fri May 17, 2013 5:17 pm
zip wrote:post detailed log of when you set the proper IP in the console and it still doesn't work
Ok...I will. I just installed a new kernel and reactivated Serviio for the weekend. Will run VMWare sometime next week ;)
Return to User experiences
