No File Found in folder shared
emiliolo
Post Sat May 18, 2013 3:46 pm
First of all thank you to evryone.
I isntall serviio 1.1 on my d-link dns 320.
I had some problem for do this but some different topic help me.
Servvio console is istalled on my pc (windows xp) and running right.
Sony bravia discover serviio, discover shared folder but the folder is empty.
FFmpeg, java and serviio running right (i hope).
login as: root
root@192.168.0.107's password:
Last login: Sat May 18 14:49:11 2013 from 192.168.0.101
root@MyNAS:~# ffmpeg -version
ffmpeg version 0.10.2
built on Apr 2 2012 13:27:15 with gcc 4.5.4 20111110 (prerelease)
configuration: --prefix=/ffp --disable-static --enable-shared --enable-gpl --enable-nonfree --enable-small --disable-encoder=aac --disable-decoder=aac --disable-armv6 --disable-armv6t2 --disable-armvfp
libavutil 51. 35.100 / 51. 35.100
libavcodec 53. 61.100 / 53. 61.100
libavformat 53. 32.100 / 53. 32.100
libavdevice 53. 4.100 / 53. 4.100
libavfilter 2. 61.100 / 2. 61.100
libswresample 0. 6.100 / 0. 6.100
root@MyNAS:~# java -version
java version "1.7.0_21"
Java(TM) SE Embedded Runtime Environment (build 1.7.0_21-b11, headless)
Java HotSpot(TM) Embedded Client VM (build 23.21-b01, mixed mode)
root@MyNAS:~# ps -ef | grep serviio
root 4079 1 0 14:07 ? 00:00:00 /bin/sh /ffp/opt/serviio/bin/serviio.sh
root 4084 4079 4 14:07 ? 00:04:07 /ffp/opt/java/jre/bin/java -Xmx384M -Xms20M -XX:+UseParNewGC -XX:MinHeapFreeRatio=10 -XX:MaxHeapFreeRatio=20 -Djava.net.preferIPv4Stack=true -Djava.awt.headless=true -Dderby.system.home=/ffp/opt/serviio/library -Dserviio.fixedPointEncoders -Dserviio.defaultTranscodeFolder=/ffp/tmp -Dserviio.home=/ffp/opt/serviio -Dserviio.remoteHost=192.168.0.107 -classpath /ffp/opt/serviio/lib/*:/ffp/opt/serviio/config org.serviio.MediaServer
root 6096 6068 0 15:33 pts/0 00:00:00 grep serviio
root@MyNAS:~#
This is the log file created last time that i running console.
2013-05-18 17:36:35,140 INFO [ServiioConsole] Starting Serviio Console
2013-05-18 17:36:35,265 INFO [ServiioConsole] Connecting to Serviio REST on 192.168.0.107:23423
2013-05-18 17:36:36,218 INFO [Messages] Loaded console message bundle for locale: en
I use the "add path" button to add the shared folder.
in windows the path is Z:\All Media
which is the right path to write in console
there is something that i dont undestand :evil: , probably is a stupid thing but .....
emiliolo
Post Sat May 18, 2013 9:11 pm
Re: No File Found in folder shared
I a very stupid man :lol: :lol: the right path path is the linux path
/mnt/HD/HD_a2/AllMedia
now i can see the file shared.....
I hope the cpu is enough for the mkv trascoding !!! :o :o
