Error 554 password reset
aragorn234
Post Wed May 22, 2013 11:04 am
Running Serviio on my Synology DS413 NAS.
Finally got it to connect to the Xbox 360 and working how I wanted.
IN a moment of insanity I upgraded the WEb UI to 1.4Beta.
Now Xbox no longer sees Serviio and I cant access the Media browser.
I try to reset the password and I get Error 554.
is there a way to downgrade or fix this issue.
Any help appreciated.
Post Wed May 22, 2013 6:27 pm
Re: Error 554 password reset
That is the error code for invalid edition which suggestest your free 15day evaluation of Serviio Pro has expired. However, that should only effect MediaBrowser, and should effect your Xbox so try restarting the server and also post a detailed log so we can see if anything is going wrong.
aragorn234
Post Thu May 23, 2013 12:39 am
Oh OK, I did not realise that the Media Browser was only part of the PRO edition.
I was thinking that because Media Browser was not working, that was why the Xbox could not connect. (obviously not the case).
The Xbox shows up in the Serviio Managment window with a little Green Light. So should be pretty straight foward to connect.
I will do the clean up, restart the Serviio Service and post the Log files later when I get home.
aragorn234
Post Thu May 23, 2013 11:46 am
Serviio Running.tiff
Serviio Running.tiff (315.79 KiB) Viewed 5847 times
As you can see in the screen shot serviio is running and the XBOX 360 is seen by Serviio. However it does not show up on the XBOX360.
The Samsung TV can see the serviio service without an issue.
I am running Serviio from a Synology NAS.
The Log files are as follows
Serviio Console Logs
Please browse to http://yourhostname/serviioweb/index.php to finish installation.
I get the following Screen presented, when I go to that path
Serviio Web Console.tiff
Serviio Web Console.tiff (354.49 KiB) Viewed 5847 times
I would like to note that the Start Server button does not function, even though it looks like it should be active. I know the green light shows server is running
Serviio
serviio Log.tiff
serviio Log.tiff (321.13 KiB) Viewed 5847 times
Hope this provides the information required
aragorn234
Post Sun May 26, 2013 10:01 pm
Can anyone offer any advise please?
Post Tue May 28, 2013 11:30 am
your images are not visible (possibly password protected?)
