Windows Server 2012 Issues
b33tl3
Post Thu May 23, 2013 7:38 pm
I have been using Serviio for years on my Windows Home Server box and it has been great. I built a new Windows Server 2012 Essentials box and I can not get my drives to see the Serviio server. I have 2 LG DVD players, WDTV, and Visio CO-star. On the server I see the Visio devices listed in the gui and logs but the devices never sees the server or content. No of the other devices see the server and the server never sees them. I have reinstalled java, opened ports 8895 and 1900 and can;t figure out what is wrong. Any suggestions would be greatly appreciated.
Here are the debug logs.
2013-05-20 08:59:23,060 DEBUG [DiscoveryManager] UPNP device 845849ff-fb73-3682-9791-500c0f07784e (192.168.1.68) is unavailable
2013-05-20 08:59:23,060 DEBUG [WebServer] Socket closed
2013-05-20 08:59:23,060 INFO [WebServer] WebServer shutting down
2013-05-20 08:59:23,060 DEBUG [DiscoverySSDPMessageListener] Socket closed: socket closed
2013-05-20 08:59:23,060 INFO [EventDispatcher] Leaving EventDispatcher
2013-05-20 08:59:23,060 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2013-05-20 08:59:23,060 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2013-05-20 08:59:23,106 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP byebye using interface eth4 (Realtek PCIe GBE Family Controller) and address Home-Server.baileynet.local, timeout = 0
2013-05-20 08:59:23,106 INFO [DatabaseManager] Shutting down database
2013-05-20 08:59:23,106 DEBUG [DBConnectionPool] Closed connection for pool Serviio DB Pool
2013-05-20 08:59:23,403 DEBUG [DatabaseManager] DB shutdown returned: Derby system shutdown.
2013-05-20 08:59:23,403 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-05-20 09:00:00,063 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2013-05-20 09:00:00,063 INFO [MediaServer] ------------------------------------------------------------------------
2013-05-20 09:00:00,063 INFO [MediaServer] Serviio DLNA media streaming server v 1.2.1 (rev. a2aa56064460+)
2013-05-20 09:00:00,063 INFO [MediaServer] Petr Nejedly 2009-2013
2013-05-20 09:00:00,063 INFO [MediaServer] http://www.serviio.org
2013-05-20 09:00:00,063 INFO [MediaServer] Java 1.7.0_21-Oracle Corporation
2013-05-20 09:00:00,063 INFO [MediaServer] OS Windows Server 2012 amd64 6.2
2013-05-20 09:00:00,063 INFO [MediaServer] File encoding: windows-1252
2013-05-20 09:00:00,063 INFO [MediaServer] Headless mode enabled: true
2013-05-20 09:00:00,063 INFO [MediaServer] User: HOME-SERVER$
2013-05-20 09:00:00,063 INFO [MediaServer] User home dir: C:\
2013-05-20 09:00:00,063 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2013-05-20 09:00:00,157 INFO [WebServer] Socket buffer set to 65535 bytes
2013-05-20 09:00:00,172 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-05-20 09:00:00,188 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-05-20 09:00:00,188 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-05-20 09:00:00,204 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-05-20 09:00:00,219 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2013-05-20 09:00:00,438 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2013-05-20 09:00:00,781 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2013-05-20 09:00:00,781 DEBUG [LocalAddressResolverStrategy] Resolving host IP address automatically
2013-05-20 09:00:00,781 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2013-05-20 09:00:00,781 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2013-05-20 09:00:00,781 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2013-05-20 09:00:00,781 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2013-05-20 09:00:00,781 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2013-05-20 09:00:00,796 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2013-05-20 09:00:00,796 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2013-05-20 09:00:00,796 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2013-05-20 09:00:00,796 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2013-05-20 09:00:00,796 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2013-05-20 09:00:00,796 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2013-05-20 09:00:00,796 DEBUG [DBLogDAOImpl] Checking if script 'script-1.1.sql' has been run
2013-05-20 09:00:00,796 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.sql' has been run
2013-05-20 09:00:00,796 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.1.sql' has been run
2013-05-20 09:00:00,796 DEBUG [LicenseValidator] Validating license file (352 bytes)
2013-05-20 09:00:00,859 INFO [MediaServer] ------------------------------------------------------------------------
2013-05-20 09:00:00,859 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2013-05-20 09:00:00,999 INFO [Device] Created UPnP Device with UUID: 845849ff-fb73-3682-9791-500c0f07784e, bound address: 192.168.1.68
2013-05-20 09:00:01,280 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2013-05-20 09:00:01,280 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2013-05-20 09:00:01,342 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2013-05-20 09:00:01,342 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2013-05-20 09:00:01,342 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2013-05-20 09:00:01,342 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2013-05-20 09:00:01,342 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2013-05-20 09:00:01,342 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2013-05-20 09:00:01,342 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2013-05-20 09:00:01,342 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2013-05-20 09:00:01,358 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2013-05-20 09:00:01,358 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2013-05-20 09:00:01,358 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2013-05-20 09:00:01,358 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2013-05-20 09:00:01,358 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2013-05-20 09:00:01,358 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2013-05-20 09:00:01,358 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2013-05-20 09:00:01,358 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012
2013-05-20 09:00:01,358 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2013-05-20 09:00:01,358 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2012
2013-05-20 09:00:01,358 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2013-05-20 09:00:01,358 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010
2013-05-20 09:00:01,358 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2013-05-20 09:00:01,358 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010us
2013-05-20 09:00:01,358 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2013-05-20 09:00:01,358 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2011
2013-05-20 09:00:01,358 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2013-05-20 09:00:01,358 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2013-05-20 09:00:01,358 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2013-05-20 09:00:01,358 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2013-05-20 09:00:01,358 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2013-05-20 09:00:01,358 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2013-05-20 09:00:01,358 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2013-05-20 09:00:01,358 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2013-05-20 09:00:01,358 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2013-05-20 09:00:01,358 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2013-05-20 09:00:01,358 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2013-05-20 09:00:01,358 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2013-05-20 09:00:01,358 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2013-05-20 09:00:01,358 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011
2013-05-20 09:00:01,358 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2013-05-20 09:00:01,358 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2010
2013-05-20 09:00:01,358 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2013-05-20 09:00:01,358 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile plps2010
2013-05-20 09:00:01,374 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2013-05-20 09:00:01,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2013-05-20 09:00:01,374 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2013-05-20 09:00:01,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2009
2013-05-20 09:00:01,374 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2013-05-20 09:00:01,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 22
2013-05-20 09:00:01,374 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2013-05-20 09:00:01,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011a
2013-05-20 09:00:01,374 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2013-05-20 09:00:01,374 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2013-05-20 09:00:01,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2010
2013-05-20 09:00:01,374 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2013-05-20 09:00:01,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012us
2013-05-20 09:00:01,374 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2013-05-20 09:00:01,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011us
2013-05-20 09:00:01,374 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2013-05-20 09:00:01,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonySTR
2013-05-20 09:00:01,374 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2013-05-20 09:00:01,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonyCMT
2013-05-20 09:00:01,374 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2013-05-20 09:00:01,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viziotv
2013-05-20 09:00:01,374 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2013-05-20 09:00:01,374 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile win8metro
2013-05-20 09:00:01,374 INFO [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2013-05-20 09:00:01,405 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2013-05-20 09:00:01,405 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile flv_player
2013-05-20 09:00:01,405 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2013-05-20 09:00:01,405 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo
2013-05-20 09:00:01,405 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2013-05-20 09:00:01,405 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile wp8
2013-05-20 09:00:01,405 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2013-05-20 09:00:01,420 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2013-05-20 09:00:01,420 INFO [PluginCompilerThread] Started looking for plugins
2013-05-20 09:00:01,420 INFO [UpdateChecker] Checking if a new version is available
2013-05-20 09:00:01,436 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2013-05-20 09:00:01,436 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2013-05-20 09:00:01,545 DEBUG [DCRawWrapper] Invoking DCRAW to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/dcraw.exe
2013-05-20 09:00:01,545 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/dcraw.exe
2013-05-20 09:00:01,576 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-05-20 09:00:01,639 INFO [WebServer] WebServer starting on port 8895
2013-05-20 09:00:01,654 DEBUG [DiscoveryManager] UPNP device 845849ff-fb73-3682-9791-500c0f07784e (192.168.1.68) is available
2013-05-20 09:00:01,654 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-05-20 09:00:01,654 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-05-20 09:00:01,654 INFO [EventDispatcher] Starting EventDispatcher
2013-05-20 09:00:01,654 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2013-05-20 09:00:01,717 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth4 (Realtek PCIe GBE Family Controller) and address 192.168.1.68, timeout = 0
2013-05-20 09:00:01,717 INFO [RendererSearchSender] Searching for Renderer devices
2013-05-20 09:00:01,717 DEBUG [RendererSearchSender$RendererSearchWorker] Multicasting SSDP M-SEARCH using interface eth4 (Realtek PCIe GBE Family Controller) and address 192.168.1.68, timeout = 0
2013-05-20 09:00:01,717 DEBUG [RendererSearchSender$RendererSearchWorker] Sending 1 'm-search' messages
2013-05-20 09:00:01,732 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.68:63672s
2013-05-20 09:00:01,732 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth4 (Realtek PCIe GBE Family Controller) and address 192.168.1.68, timeout = 0
2013-05-20 09:00:01,732 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 845849ff-fb73-3682-9791-500c0f07784e
2013-05-20 09:00:38,408 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:alive) message from Renderer 56076f6e-6b79-4d65-6421-424242424242 from address /192.168.1.101:1900
2013-05-20 09:00:38,424 DEBUG [RendererManager] Adding renderer Renderer [uuid=56076f6e-6b79-4d65-6421-424242424242, ipAddress=192.168.1.101, name=Local Player, profileId=1, manuallyAdded=false, forcedProfile=false, enabled=true, accessGroupId=1] to list of active renderers
2013-05-20 09:00:41,950 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.101:1031s
2013-05-20 09:00:41,996 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.101:1031s
2013-05-20 09:00:41,996 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.101:1031
2013-05-20 09:00:42,058 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.101:1031s
2013-05-20 09:00:42,109 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:WebdavServer:1 from address /192.168.1.101:1031s
2013-05-20 09:00:42,159 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:ProxyServer:1 from address /192.168.1.101:1031s
2013-05-20 09:00:42,209 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.101:1031s
2013-05-20 09:00:42,260 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.101:1031s
2013-05-20 09:00:42,260 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.101:1031
2013-05-20 09:00:42,310 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.101:1031s
2013-05-20 09:00:42,360 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:WebdavServer:1 from address /192.168.1.101:1031s
2013-05-20 09:00:42,410 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:ProxyServer:1 from address /192.168.1.101:1031s
2013-05-20 09:00:45,461 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.101:1031s
2013-05-20 09:00:45,508 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.101:1031s
2013-05-20 09:00:45,508 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.101:1031
2013-05-20 09:00:45,564 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.101:1031s
2013-05-20 09:00:45,613 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:WebdavServer:1 from address /192.168.1.101:1031s
2013-05-20 09:00:45,664 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:ProxyServer:1 from address /192.168.1.101:1031s
2013-05-20 09:00:45,714 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.101:1031s
2013-05-20 09:00:45,764 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.101:1031s
2013-05-20 09:00:45,765 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.101:1031
2013-05-20 09:00:45,815 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.101:1031s
2013-05-20 09:00:45,865 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:WebdavServer:1 from address /192.168.1.101:1031s
2013-05-20 09:00:45,915 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:ProxyServer:1 from address /192.168.1.101:1031s
2013-05-20 09:00:48,965 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.101:1031s
2013-05-20 09:00:49,012 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.101:1031s
2013-05-20 09:00:49,012 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.101:1031
2013-05-20 09:00:49,068 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.101:1031s
2013-05-20 09:00:49,119 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:WebdavServer:1 from address /192.168.1.101:1031s
2013-05-20 09:00:49,169 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:ProxyServer:1 from address /192.168.1.101:1031s
2013-05-20 09:00:49,219 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.101:1031s
2013-05-20 09:00:49,270 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.101:1031s
2013-05-20 09:00:49,270 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.101:1031
2013-05-20 09:00:49,320 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.101:1031s
2013-05-20 09:00:49,370 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:WebdavServer:1 from address /192.168.1.101:1031s
2013-05-20 09:00:49,421 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:ProxyServer:1 from address /192.168.1.101:1031s
2013-05-20 09:01:38,483 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:alive) message from Renderer 56076f6e-6b79-4d65-6421-424242424242 from address /192.168.1.101:1900
2013-05-20 09:01:41,978 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.101:1031s
2013-05-20 09:01:42,024 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.101:1031s
2013-05-20 09:01:42,024 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.101:1031
2013-05-20 09:01:42,084 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.101:1031s
2013-05-20 09:01:42,134 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:WebdavServer:1 from address /192.168.1.101:1031s
2013-05-20 09:01:42,185 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:ProxyServer:1 from address /192.168.1.101:1031s
2013-05-20 09:01:42,235 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.101:1031s
2013-05-20 09:01:42,285 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.101:1031s
2013-05-20 09:01:42,286 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.101:1031
2013-05-20 09:01:42,336 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.101:1031s
2013-05-20 09:01:42,387 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:WebdavServer:1 from address /192.168.1.101:1031s
2013-05-20 09:01:42,437 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:ProxyServer:1 from address /192.168.1.101:1031s
2013-05-20 09:01:45,486 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.101:1031s
2013-05-20 09:01:45,532 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.101:1031s
2013-05-20 09:01:45,532 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.101:1031
2013-05-20 09:01:45,591 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.101:1031s
2013-05-20 09:01:45,641 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:WebdavServer:1 from address /192.168.1.101:1031s
2013-05-20 09:01:45,691 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:ProxyServer:1 from address /192.168.1.101:1031s
2013-05-20 09:01:45,742 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.101:1031s
2013-05-20 09:01:45,792 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.101:1031s
2013-05-20 09:01:45,792 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.101:1031
2013-05-20 09:01:45,842 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.101:1031s
2013-05-20 09:01:45,893 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:WebdavServer:1 from address /192.168.1.101:1031s
2013-05-20 09:01:45,943 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:ProxyServer:1 from address /192.168.1.101:1031s
2013-05-20 09:01:46,911 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.76:32854s
2013-05-20 09:01:46,911 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.76:32854
2013-05-20 09:01:47,410 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.76:32854s
2013-05-20 09:01:47,410 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.76:32854
2013-05-20 09:01:49,001 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.101:1031s
2013-05-20 09:01:49,046 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.101:1031s
2013-05-20 09:01:49,047 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.101:1031
2013-05-20 09:01:49,097 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.101:1031s
2013-05-20 09:01:49,147 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:WebdavServer:1 from address /192.168.1.101:1031s
2013-05-20 09:01:49,205 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:ProxyServer:1 from address /192.168.1.101:1031s
2013-05-20 09:01:49,249 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.101:1031s
2013-05-20 09:01:49,299 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.101:1031s
2013-05-20 09:01:49,300 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.101:1031
2013-05-20 09:01:49,350 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.101:1031s
2013-05-20 09:01:49,400 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:WebdavServer:1 from address /192.168.1.101:1031s
2013-05-20 09:01:49,451 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:ProxyServer:1 from address /192.168.1.101:1031s
2013-05-20 09:02:38,847 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:alive) message from Renderer 56076f6e-6b79-4d65-6421-424242424242 from address /192.168.1.101:1900
2013-05-20 09:02:41,998 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.101:1031s
2013-05-20 09:02:42,045 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.101:1031s
2013-05-20 09:02:42,045 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.101:1031
2013-05-20 09:02:42,107 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.101:1031s
2013-05-20 09:02:42,157 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:WebdavServer:1 from address /192.168.1.101:1031s
2013-05-20 09:02:42,208 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:ProxyServer:1 from address /192.168.1.101:1031s
2013-05-20 09:02:42,258 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.101:1031s
2013-05-20 09:02:42,317 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.101:1031s
2013-05-20 09:02:42,318 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.101:1031
2013-05-20 09:02:42,360 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.101:1031s
2013-05-20 09:02:42,410 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:WebdavServer:1 from address /192.168.1.101:1031s
2013-05-20 09:02:42,460 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:ProxyServer:1 from address /192.168.1.101:1031s
2013-05-20 09:02:45,514 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.101:1031s
2013-05-20 09:02:46,418 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.101:1031s
2013-05-20 09:02:46,418 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.101:1031s
2013-05-20 09:02:46,418 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:WebdavServer:1 from address /192.168.1.101:1031s
2013-05-20 09:02:46,418 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.101:1031
2013-05-20 09:02:46,418 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:ProxyServer:1 from address /192.168.1.101:1031s
2013-05-20 09:02:46,418 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.101:1031s
2013-05-20 09:02:47,967 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2013-05-20 09:02:49,007 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.101:1031s
2013-05-20 09:02:49,054 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.101:1031s
2013-05-20 09:02:49,069 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.101:1031
2013-05-20 09:02:49,116 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.101:1031s
2013-05-20 09:02:49,163 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:WebdavServer:1 from address /192.168.1.101:1031s
2013-05-20 09:02:49,210 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:ProxyServer:1 from address /192.168.1.101:1031s
2013-05-20 09:02:49,256 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.101:1031s
2013-05-20 09:02:49,319 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.101:1031s
2013-05-20 09:02:49,319 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.101:1031
2013-05-20 09:02:49,378 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.101:1031s
2013-05-20 09:02:49,420 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:WebdavServer:1 from address /192.168.1.101:1031s
2013-05-20 09:02:49,471 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:pv-com:device:ProxyServer:1 from address /192.168.1.101:1031s
2013-05-20 09:02:51,801 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2013-05-20 09:03:01,289 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2013-05-20 09:03:01,289 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 23:57:10 (advertisement duration is 1800 sec.)
2013-05-20 09:03:01,320 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth4 (Realtek PCIe GBE Family Controller) and address 192.168.1.68, timeout = 0
2013-05-20 09:03:01,320 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 845849ff-fb73-3682-9791-500c0f07784e
2013-05-20 09:03:21,304 INFO [FeedUpdaterThread] Started looking for information about online resources
2013-05-20 09:03:21,304 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-05-20 09:03:21,304 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-05-20 09:03:21,304 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-05-20 09:03:21,304 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-05-20 09:03:21,304 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-05-20 09:03:21,304 INFO [PlaylistMaintainerThread] Started looking playlist changes
2013-05-20 09:03:21,304 DEBUG [PlaylistDAOImpl] Reading all Playlists
2013-05-20 09:03:21,335 DEBUG [LibraryUpdatesCheckerThread] Looking for removed playlist files in repository: E:\ServerFolders\Movies
2013-05-20 09:03:21,335 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: E:\ServerFolders\Movies
2013-05-20 09:03:21,335 DEBUG [PlaylistDAOImpl] Reading Playlists for Repository (id = 1)
2013-05-20 09:03:21,335 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: E:\ServerFolders\Movies\101 Dalmatians
2013-05-20 09:03:21,335 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: E:\ServerFolders\Movies\2011 Bulldogs Chearleading
2013-05-20 09:03:21,335 DEBUG [LibraryAdditionsCheckerThread] Found file 'VID_20110714_193255.3gp', checking if it's already in the Library
Post Thu May 23, 2013 9:07 pm
Re: Windows Server 2012 Issues
Looks like firewall issue, there are no incoming requests
