v1.2 bound IP address functionality?
gorca
Post Sun Mar 03, 2013 3:37 am
In v1.1 Bound IP functionality worked just fine. In v1.2 not so much.
I have two NICs: local LAN and Hamachi VPN. Bound IP address is set to local LAN IP (not automatic even). However Serviio doesn't remembers the setting and after a while it somehow ends up bound to Hamachi VPN IP. I've even disallowed Hamachi VPN device under above "render profile", but this doesn't help.
Latest Serviio version, WiFi connection between PC and Samsung UE46ES8000 (Serviio profile E/F series) established via router.
Post Sun Mar 03, 2013 11:35 am
Re: v1.2 bound IP address functionality?
Can you post detailed log?
gorca
Post Tue Mar 05, 2013 11:25 pm
Here is the log. Serviio loses the Bound IP Address setting after every restart. Defaults to 25.x.x.x instead of 192.168.x.x which I choose. Am running a very fresh install of Win 7 x64. Serviio installed for the first time.
serviio.rar
(8.57 KiB) Downloaded 356 times
Post Tue Mar 05, 2013 11:49 pm
Thanks. What is the output of this URL after you restart?
http://localhost:23423/rest/status
and then the same URL output after you save the bound IP.
gorca
Post Wed Mar 06, 2013 9:45 pm
No problem. Followed your instructions to the letter, except that I have to restart Serviio in order to make it bind to different IP address. Results are attached.
status-after bound.xml
after changing binding IP address and Serviio restart
(1.62 KiB) Downloaded 756 times
status.xml
after OS restart
(1.63 KiB) Downloaded 601 times
davmrls
Post Sat May 25, 2013 2:00 am
I am having the same issue. Whenever I set my bound ip to Automatic Detect, it always falls back to my Ethernet ip. How do I make it keep my settings?
Post Sun May 26, 2013 5:51 pm
Automatic means it'll try to guess the best match (not always 100% accurate though). So when you save this setting, it'll pick the address and bind to it. It'll then show in the console as the preferred NIC from then on.
