Samsung TV only playing part of TS file not the full file
pdmartin
Post Sun May 26, 2013 5:22 am
I have an issue in that my Samsung TVs are not playing the full duration of TS files. I have a PVR that is networked and the recorded files available via the Serviio server to the TVs. All three tvs have the same issue. The sample file below only plays for approx 5 mins, also display as only having 5 minutes of content. It plays fine on other DLNA devices e.g. iPad with DLNA player installed.
Samsung TV: UA55D6600, UA46D6200, UA32D5000
Serviio 1.2.1 running on windows home server 2003 Service pack 2
Device Profile: Samsung TV/player (C/D/E-series)
C:\Program Files\Serviio\lib>ffmpeg.exe -i "h:\recordings\itm fishing show.ts"
ffmpeg version 1.1.1 Copyright (c) 2000-2013 the FFmpeg developers
built on Feb 5 2013 21:59:54 with gcc 4.7.2 (GCC)
p --enable-fontconfig --enable-libfreetype --enable-zlib --extra-libs='-lrtmp -l
polarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-
runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-
mingw32- --pkg-config=pkg-config
libavutil 52. 13.100 / 52. 13.100
libavcodec 54. 86.100 / 54. 86.100
libavformat 54. 59.106 / 54. 59.106
libavdevice 54. 3.102 / 54. 3.102
libavfilter 3. 32.100 / 3. 32.100
libswscale 2. 1.103 / 2. 1.103
[mp1 @ 003DFB80] Header missing
Last message repeated 130 times
[mpeg2video @ 01E35B20] 0x0 is invalid
Last message repeated 1 times
Last message repeated 69 times
[mpegts @ 003DED00] max_analyze_duration 5000000 reached at 5016000
[mpegts @ 003DED00] decoding for stream 0 failed
[mpegts @ 003DED00] Could not find codec parameters for stream 0 (Audio: mp1, 0
channels, s16p): unspecified frame size
Consider increasing the value for the 'analyzeduration' and 'probesize' options
[mpegts @ 003DED00] PES packet size mismatch
Input #0, mpegts, from 'h:\recordings\itm fishing show.ts':
Duration: 27:00:44.37, start: 81246.339078, bitrate: 49 kb/s
Stream #0:0[0x2c8]: Audio: mp1, 0 channels, s16p
Stream #0:1[0x206]: Video: mpeg2video (Main), yuv420p, 720x576 [SAR 64:45 DA
R 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc
Stream #0:2[0x290]: Audio: mp2, 48000 Hz, stereo, s16p, 192 kb/s
Post Sun May 26, 2013 6:06 pm
Re: Samsung TV only playing part of TS file not the full fil
How long it the file? FFmpeg reports 27 hours
Can you try ffmpeg -i with the latest FFmpeg if it's fixed?
Users browsing this forum: Baidu [Spider] and 13 guests
