Cannot stream online sources
ameneses54
Post Sun May 26, 2013 12:16 pm
Dear Users,
I'm new with Serviio and I'm having problems streaming online resources to my Samsung Smart TV.
Basically what happens is that after setting the URL etc for the content, the "online" folder on the TV is empty.
I'd appreciate your advise.
Post Sun May 26, 2013 5:38 pm
Re: Cannot stream online sources
What URL are you using?
ameneses54
Post Sun May 26, 2013 8:15 pm
zip wrote:What URL are you using?
Thanks for your reply.
I'm trying this URL:
http://www.southparkstudios.com/full-episodes
Post Sun May 26, 2013 8:18 pm
You can't just enter any URL and expect it'll magically work :-) For this you'll need a plugin. Not sure if there is one yet, check out the Online Plugins section here.
More info on how it works: http://www.serviio.org/component/content/article?id=42
ameneses54
Post Sun May 26, 2013 10:36 pm
zip wrote:You can't just enter any URL and expect it'll magically work :-) For this you'll need a plugin. Not sure if there is one yet, check out the Online Plugins section here.
Ok, thanks.
I'll try to be more informed on the matter.
Return to General discussion
