When did 1.21 come out?
stratotak
Post Mon May 27, 2013 12:17 am
I just had to reinstall OS. I was usung Serviio that I downloaded a couple months ago.Around 2 months ago or so. It worked fine with avi,mkv,mp4.I just downloaded latest and now movies that worked before dont work.They transcode when in previous version they just streamed.
Post Mon May 27, 2013 1:36 am
Re: When did 1.21 come out?
viewtopic.php?f=1&t=9715
In your previous version you may have turned transcoding off, or used the generic profile. Both methods will result in the files being streamed natively. What device have you got and what profile are you now using?
Return to General discussion
