Serviio update 1.1 to 1.2.1 problem
welter
Post Mon May 27, 2013 7:15 am
4 month ago i have set up my new Windows Home Server 2011 (with ServiioAddon). I tried to use Serviio 1.2 But my Samsung TV cant see Serviio.
I have read about this Problem right here and found a solution. I installed Serviio 1.1 and everything works fine.
I use 2 Samsung TV, 1 Apple TV with XBMC, and a Samsung Smartphone Galaxy SII (Serviigo)
I have Pro licence for Seviio and Serviigo.
Now I have updated my Serviigo App. And this only works with Serviio 1.2+
So I have updated my Serviio on the WHS from 1.1 to 1.2.1
On my Smartphone everything works fine now. But my Samsung TVs and Apple TV cant find Serviio in my network (same Problem as 4month ago)
What can i do, that my TVs will find Serviio?
If there is no Solution, is it possible to get back the old Serviigo App?
Sorry for my bad englisch. I hope you can understand me.
Markus
Post Mon May 27, 2013 7:37 am
Re: Serviio update 1.1 to 1.2.1 problem
Please could you post a detailed log showing your server start up?
The problem is probably related to a change in the code that picks the network interface to listen too that happened in 1.2. The WHS Serviio Addon is not compatiable with 1.2, could you install the official console on your server, that way you will be able to use the bound address drop down box to select the correct interface.
If we cannot get it working (shouldn't happen), then please send me your email address via PM/email the address on the Google Play listing for ServiiGo and I will send you an older version of ServiiGo.
welter
Post Tue May 28, 2013 5:59 am
embarrassingly :roll:
you are right. It was the network interface. the bound adress in the drop down box was empthy. I just changed it to the right IP adress - stop and restart the serviio service. And everything works fine.
Thank you very much for your help. Now I have got the newest Version running.
By the way: The serviio WHS addon still works with serviio 1.2.1
I think this is just a frontend that looks at the official console.
Post Tue May 28, 2013 11:36 am
welter wrote:By the way: The serviio WHS addon still works with serviio 1.2.1
No. You might lose some configuration data / corrupt the configuration if you keep using it with 1.2
misterbkh
Post Sun Jun 02, 2013 2:06 am
i just noticed a problem after updating here also
my audio files show the folders but no files to play
do i need to delete the database files or something to get things working again
