BEEG - AN ADULT STREAMS VIDEO WEB RESOURCE
totototo
Post Mon Jan 14, 2013 4:41 pm
Re: BEEG - AN ADULT STREAMS VIDEO WEB RESOURCE
Thanks jhb50: looking forward this update.
But, am I the only one with this issue? In current situation I can play just very few files?
Most of them are played with 007i.net URL and therefore fail: is it not failing in your case, or Servio never happen to play files with 007i.net ?
Post Mon Jan 14, 2013 5:11 pm
It may be related to geography.
Post Mon Jan 14, 2013 5:13 pm
Version 10 posted with new usegen=1 option to ignore new beeg urls at playback time
totototo
Post Mon Jan 14, 2013 11:37 pm
Thanks for this.
It indeed seems more videos are being played with usegen=1: none seem rejected at launch.
However, there are frequent buffering pauses.
Focusing on the videos that play with both usegen=0 and usegen=1, there are buffering pauses in the latter case, whereas there are no with usegen=0.
Strange, no?
bikergrove
Post Wed Feb 20, 2013 8:08 pm
There must be something wrong with this it shows new vids but they will not play on the tv or serviio media browser, It was spot on until I updated to v10
Post Thu Feb 21, 2013 4:25 am
Works fine for me but is slow to start.
totototo
Post Thu Feb 21, 2013 8:43 am
yes usegen=1 works really great.
Buffering issues I reported earlier were probably due to my tests process (changing parameters back&forth, and caching issues).
Now I stick with usegen=1, all works fine.
Sure start is a bit slow, but that's ok.
Mart360
Post Sat Mar 23, 2013 3:00 pm
Interesting update ...
Both my media players can see the channel, and generate thumbnails
howeber when trying to play / stream the file, i get the following errors
1) Communication lost with your PC check connections etc
2) on the second player, i just get a loading symbol, and nothing else.
Both are connected wirelessly to my network.... neither has any probs with any of the other stuff i stream
Mart
Post Sun Mar 24, 2013 9:17 pm
Works fine for me. Post a debug log.
totototo
Post Fri Mar 29, 2013 4:41 pm
Which version of Serviio are you using?
1.2.1 fixes some 1.2 networking issues...
gpsis
Post Fri Mar 29, 2013 8:37 pm
Mart360 wrote:Interesting update ...
Mart
I have been getting similar errors.
I get the thumbnails and the video description, once I click on it after a few seconds I get "video either corrupt or...", or I get "no playable file".
I haven't gotten it to play at all since v8; even then it was very sometimey...don't know why some are having more success than me and others like yourself are having issues.
"Works for me!" comments don't do anything to fix the issues, but i guess when you're the plugin creator you can take a piss poor posture, right?
Anyway I'm posting my log files in case someone wants to take a serious look at why it works for some and not for others.
FYI I am running Serviio 1.2.1
derby.log
(622 Bytes) Downloaded 21417 times
(15.11 KiB) Downloaded 21482 times
Regards!
Device: Sony Media Player SMP-N100
Win7 Dual Core 2.9GHz
3GBR
Malwarebytes Anti-Spyware
BitDefender Total Security
Serviio allowed in all security software
Post Sat Mar 30, 2013 4:12 am
And you expect me to help you? You can't even be bothered to follow the advice I did give you. And yes the raw streams that your ffmpeg won't play, play fine for me, so it has nothing to do with Serviio or the plugin. Try reading the wiki and test them yourself. You might even learn something. Don't bother to ask for more.
gpsis
Post Sat Mar 30, 2013 4:34 am
Exactly the piss poor attitude I expected...typical.
Which is exactly why I stopped posting questions before. Your "Holyer than thou" attitude stinks!
As the Joker said to Batman..."Why so serious?"
Regards!
3GBR
Post Sat Mar 30, 2013 11:33 am
Glad to see you go. Made my day.
patanpatan
Post Mon May 27, 2013 12:41 am
I think we need an update for this plugin. Could someone work on it? It would be great :D
Post Mon May 27, 2013 4:29 am
Its working fine for me. Post your console entries and a debug log of it refreshing.
Lincsguy
Post Mon May 27, 2013 8:56 am
I am seeing the index out of range thing again. I have updating Java to 7.21, reinstalled the pluging and restarted serviio. Here is a portion of the log.
java.io.IOException: Unexpected error while invoking plugin (Beeg): index is out of range -42..41 (index = 42)
at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:58)
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:171)
Caused by: java.lang.IndexOutOfBoundsException: index is out of range -42..41 (index = 42)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.getAt(DefaultGroovyMethods.java:6202)
at org.codehaus.groovy.runtime.dgm$310.invoke(Unknown Source)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite$PojoMetaMethodSiteNoUnwrapNoCoerce.invoke(PojoMetaMethodSite.java:271)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.call(PojoMetaMethodSite.java:53)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116)
at Beeg.extractItems(Beeg.groovy:156)
Post Mon May 27, 2013 11:51 am
Cannot reproduce this. How are you invoking it in console?
patanpatan
Post Tue May 28, 2013 1:36 am
I think i've got it, add
if(thumbMatch.size()>i)
at line 156
Post Tue May 28, 2013 2:57 am
Version 11 posted
Return to Available plugins
