Help URL Samsung Smart TV
pepito01
Post Wed May 29, 2013 2:44 pm
This url: rtsp :/ / 72.13.93.186/campcartoon not work on my Samsung smart TV,
but the console if recognized as valid.
Could you help me?
Thank you very much.
Post Wed May 29, 2013 4:42 pm
Re: Help URL Samsung Smart TV
what do you have in the detailed log when playing this file?
Post Wed May 29, 2013 6:45 pm
Very flaky link. Sometimes ffmpeg works and sometimes it hangs on stream errors. Always hangs on ffplay.
C:\Users\John>ffmpeg -i rtsp://72.13.93.186/campcartoon
ffmpeg version 1.1.1 Copyright (c) 2000-2013 the FFmpeg developers
  built on Feb  5 2013 21:59:54 with gcc 4.7.2 (GCC)
  configuration: --enable-static --disable-shared --disable-ffplay --disable-ff
erver --enable-memalign-hack --enable-libmp3lame --enable-libass --enable-librt
p --enable-fontconfig --enable-libfreetype --enable-zlib --extra-libs='-lrtmp -
polarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable
runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64
mingw32- --pkg-config=pkg-config
  libavutil      52. 13.100 / 52. 13.100
  libavcodec     54. 86.100 / 54. 86.100
  libavformat    54. 59.106 / 54. 59.106
  libavdevice    54.  3.102 / 54.  3.102
  libavfilter     3. 32.100 /  3. 32.100
  libswscale      2.  1.103 /  2.  1.103
[rtsp @ 032D5AE0] max_analyze_duration 5000000 reached at 5120000
Guessed Channel Layout for  Input Stream #0.0 : mono
Input #0, rtsp, from 'rtsp://72.13.93.186/campcartoon':
    title           : TubTub.com Over 100 live TV channels
    WMFSDKVersion   : 11.0.5721.5251
    WMFSDKNeeded    : 0.0.0.0000
    IsVBR           : 0
  Duration: 00:09:27.26, start: 425.464000, bitrate: N/A
    Stream #0:0: Audio: wmav2 (a[1][0][0] / 0x0161), 16000 Hz, mono, fltp, 12 k
/s
    Stream #0:1: Video: vc1 (Advanced) (WVC1 / 0x31435657), yuv420p, 400x300 [S
R 1:1 DAR 4:3], 233 kb/s, 8 tbr, 1k tbn, 16 tbc
[wmav2 @ 03282320] RTP: missed 1 packets
[asf @ 0150F700] ignoring invalid packet_obj_size (6628 987 3939 8038)
[asf @ 0150F700] freeing incomplete packet size 8038, new 3939
[asf @ 0150F700] freeing incomplete packet size 3939, new 4839
[wmav2 @ 03282320] RTP: missed 2 packets
[asf @ 0150F700] ignoring invalid packet_obj_size (1668 1316 1500 3078)
[asf @ 0150F700] freeing incomplete packet size 3078, new 1500
[asf @ 0150F700] freeing incomplete packet size 1500, new 3552
[asf @ 0150F700] freeing incomplete packet size 1499, new 6188
[asf @ 0150F700] ignoring invalid packet_obj_size (4936 185 2199 6188)
[asf @ 0150F700] freeing incomplete packet size 6188, new 2199
[asf @ 0150F700] freeing incomplete packet size 2199, new 4951
pepito01
Post Wed May 29, 2013 6:50 pm
zip wrote:what do you have in the detailed log when playing this file?
Change rtsp :/ / 72.13.93.186/campcartoon for mms :/ / 72.13.93.186/campcartoon and work good.
But mms://classictoonsnetwork.tubtub.com/ don't work?
