HDTRAILERS VIDEO WEBRESOURCE
Xmantium
Post Wed Mar 13, 2013 11:45 pm
Re: HDTRAILERS VIDEO WEBRESOURCE
Hi jhb50, seems like the thumbnails not working on alot of trailers on this plugin
2013-03-13 12:12:15,328 WARN  [FeedUpdaterThread] An error occured while retrieving thumbnail, will remove it from the item and will continue
org.serviio.library.online.CannotRetrieveThumbnailException: Failed to download thumbnail http://static.hd-trailers.net/thumbnails2/cirquedusoleilworldsaway-poster-jpg_005819-resized.jpg.
   at org.serviio.library.online.OnlineLibraryManager.findThumbnail(OnlineLibraryManager.java:266)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:107)
Caused by: java.io.FileNotFoundException: http://static.hd-trailers.net/thumbnails2/cirquedusoleilworldsaway-poster-jpg_005819-resized.jpg
   at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1610)
   at org.serviio.util.HttpClient.retrieveBinaryFileFromURL(HttpClient.java:72)
   at org.serviio.library.online.OnlineLibraryManager.findThumbnail(OnlineLibraryManager.java:258)
   ... 1 more
2013-03-13 12:12:15,644 WARN  [FeedUpdaterThread] An error occured while retrieving thumbnail, will remove it from the item and will continue
org.serviio.library.online.CannotRetrieveThumbnailException: Failed to download thumbnail http://static.hd-trailers.net/thumbnails2/reality-119799-poster-xlarge-resized.jpg.
Caused by: java.io.FileNotFoundException: http://static.hd-trailers.net/thumbnails2/reality-119799-poster-xlarge-resized.jpg
   ... 1 more
The other thing ive noticed is ' appear as "&#039;"
Like "Return to Nim's Island" shows as "Return to Nim&#039;s Island"
or "Tyler Perry's Temptation" as "Tyler Perry&#039;s Temptation"
Post Thu Mar 14, 2013 5:02 am
Version 10 posted to fix that.
Xmantium
Post Mon May 20, 2013 8:00 am
Is there some changes to the site, getting lots of errors in logs
Post Wed May 29, 2013 4:19 am
Only problem I have is thumbnails missing. I think it is a site problem but it maybe the way zip is accessing them, because they load fine in my browser using the same link.
Post Wed May 29, 2013 3:08 pm
After more testing, I have confirmed that UserAgent must now be set to retrieve new thumbnails. Need fix to Serviio to correct this problem. See post and ticket @ viewtopic.php?f=22&t=10271
siriusblack
Post Thu May 30, 2013 2:47 pm
HI
Can't get any HD Trailers showing up on the serviio Media Browser
Can you please help
Here is my log
HD Trailers.txt
(13.19 KiB) Downloaded 1378 times
Thanks a lot
Beta Tester
Post Thu May 30, 2013 5:29 pm
HD-Trailers have added security . Posted V11 to fix it. Note that new thumbnails will not display. They require a fix in Serviio which will come in the next release.
siriusblack
Post Thu Jul 25, 2013 7:57 pm
HD CLIPS.txt
(6.58 KiB) Downloaded 1226 times
Still cant get it to load up
I have done a full uninstalled + reinstalled
please help
What does this mean ? [FeedItemUrlExtractor] HDTrailers: HDTrailer type not found or start value too high
Beta Tester
Post Thu Jul 25, 2013 8:40 pm
As I told you 2 weeks ago this is breaking/interfering with the plugin extraction.
2013-07-25 20:47:17,182 DEBUG [FeedItemUrlExtractor] Playlist extractor: - transmitted from WebResourceParser - playlistUrl: null
Its something In your system..I have no idea what. The plugin works fine for me.
siriusblack
Post Thu Jul 25, 2013 8:49 pm
No worries
Thanks I will do a full factory reset tomorrow on my laptop
Beta Tester
Post Thu Jul 25, 2013 9:33 pm
That won't fix it..Its just in your Serviio plugins per the log message.
siriusblack
Post Thu Jul 25, 2013 9:40 pm
Thanks jhb50
I just found this
viewtopic.php?f=22&t=8071
Hopefully this will help me + others who is having
This problem
Beta Tester
Xmantium
Post Fri Jul 26, 2013 10:32 pm
@jhb50, http://www.hd-trailers.net/coming-soon is working fine, all thumbnails working using Serviio 1.3
but with http://www.hd-trailers.net i get errors
2013-07-26 23:26:11,598 WARN  [FeedUpdaterThread] An error occured while parsing the online resource http://www.hd-trailers.net, will try again soon: Unexpected error while invoking plugin (HDTrailers): No signature of method: HDTrailers.openUrl() is applicable for argument types: (java.net.URL, java.lang.String) values: [http://www.hd-trailers.net/page/2, Mozilla/5.0 (Windows NT 6.1) AppleWebKit/537.1 (KHTML, like Gecko) Chrome/21.0.1180.83 Safari/537.1]
2013-07-26 23:27:13,103 WARN  [FeedUpdaterThread] An error occured while parsing the online resource http://www.hd-trailers.net, will try again soon: Unexpected error while invoking plugin (HDTrailers): No signature of method: HDTrailers.openUrl() is applicable for argument types: (java.net.URL, java.lang.String) values: [http://www.hd-trailers.net/page/2, Mozilla/5.0 (Windows NT 6.1) AppleWebKit/537.1 (KHTML, like Gecko) Chrome/21.0.1180.83 Safari/537.1]
2013-07-26 23:28:14,511 WARN  [FeedUpdaterThread] An error occured while parsing the online resource http://www.hd-trailers.net, will try again soon: Unexpected error while invoking plugin (HDTrailers): No signature of method: HDTrailers.openUrl() is applicable for argument types: (java.net.URL, java.lang.String) values: [http://www.hd-trailers.net/page/2, Mozilla/5.0 (Windows NT 6.1) AppleWebKit/537.1 (KHTML, like Gecko) Chrome/21.0.1180.83 Safari/537.1]
2013-07-26 23:29:16,135 WARN  [FeedUpdaterThread] An error occured while parsing the online resource http://www.hd-trailers.net, waiting for expiry time to try again: Unexpected error while invoking plugin (HDTrailers): No signature of method: HDTrailers.openUrl() is applicable for argument types: (java.net.URL, java.lang.String) values: [http://www.hd-trailers.net/page/2, Mozilla/5.0 (Windows NT 6.1) AppleWebKit/537.1 (KHTML, like Gecko) Chrome/21.0.1180.83 Safari/537.1]
Post Sat Jul 27, 2013 12:44 am
I don't want to publish an update until 1.3 is out but changing line 190 to the following should fix it.
html = OpenProtURL(rootUrl + "/page/" + Page,"")
Xmantium
Post Tue Oct 22, 2013 5:31 pm
Hi jhb50,
Im unsuccessful to get this plugin working, tried you new fix
Using Serviio 1.3.1
nnjlarry
Post Wed Nov 27, 2013 12:00 am
Hello all... I'm brandy new to Serviio (how didn't I find/know about this sooner??)...
Spent a few hours today getting all working... really, on OSX 10.8 it worked quite easily... all without any issue, but I did have a a bit of learning especially until I found how to access the logs to 'confirm' files (images, music, video) was loading...
Just started looking into online material and have loaded this plug-in (the current version as noted on page 1 of thread). Also, I've installed the current (as of today) release for OSX.
I've added a online link as 'web resource' link pointing to:
http://www.hd-trailers.net?res=720
Error from log:
2013-11-26 18:51:03,949 WARN [FeedUpdaterThread] An error occured while parsing the online resource http://www.hd-trailers.net?res=720, will try again soon: Unexpected error while invoking plugin (HDTrailers): Server returned HTTP response code: 403 for URL: http://www.hd-trailers.net/page/1
Thoughts/ideas?
bubbaganoush
Post Fri Dec 06, 2013 10:14 pm
I am getting a number of errors with this plugin
1. The trailer website is returning 403 forbidden response. I am getting the same log message as nnjlarry posted. It looks like a referrer is also required to download the html on line 128. It is currently:
It is resolved if I use rootUrl as a referrer.
html = OpenProtURL(rootUrl + "/page/" + Page, rootUrl)
Edit: I am wrong about this. It is returning 403 most of the time but once in a while it starts working. I can't figure out what is actually causing it to do this.
2. I had to update videoMatcher in the extractUrl method to be:
def videoMatcher = videohtml =~ '(?s)<tr.*?itemtype="http://schema.org/VideoObject".*?itemprop="trailer".*?>(.*?)<.*?bottomTableResolution.*?href="(.*?)".*?</td>(.*?)TableIcon">.*?'
3. Next there are some problems if the url is a yahoo source. The plugin is throwing errors on line 370. Here's the output running the plugin testing directly with groovy.
ContentURLContainer [fileType=VIDEO, contentUrl=http://videos.hd-trailers.net/IL
D_REVIEW_SUBURBS_2min-480p-HDTN.mp4, thumbnailUrl=http://static.hd-trailers.net/
images/inside-llewyn-davis-97513-poster-xlarge-resized.jpg, expiresImmediately=t
rue, cacheKey=http://www.hd-trailers.net/movie/inside-llewyn-davis/_480, live=fa
lse, userAgent=]
Dec 06, 2013 5:01:41 PM org.restlet.engine.http.connector.HttpClientHelper start
INFO: Starting the default HTTP client
Caught: java.lang.IndexOutOfBoundsException: index is out of range 0..-1 (index
= 0)
java.lang.IndexOutOfBoundsException: index is out of range 0..-1 (index = 0)
        at HDTrailers.extractUrl(HDTrailers.groovy:370)
        at HDTrailers$extractUrl$1.call(Unknown Source)
        at HDTrailers$_main_closure1.doCall(HDTrailers.groovy:406)
        at HDTrailers.main(HDTrailers.groovy:405)
It looks to me like this data source might have changed. I have been trying for hours to update the plugin but my programming and regex skill is not good enough.
Post Sat Dec 07, 2013 11:24 pm
Your efforts should be rewarded. I've posted V12 which should work.
bubbaganoush
Post Sun Dec 08, 2013 9:44 pm
Xmantium
Post Tue Dec 10, 2013 8:42 pm
Hi jhb50, thanks for keeping this plugin upto date, i add the following using this link and cant get the video files to play on TV, i then tried ServiiGo as it plays anything i throw at it but nothing
Running on Linux, getting weird Windows errors?
Works fine when i add pref=apple parameter but not all trailers are from Apple
2013-12-10 20:29:19,982 WARN  [ProcessExecutor] Process /root/.serviio/opt/bin/ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
creation_time   : 2013-12-05 17:23:45
handler_name    : Apple Sound Media Handler
[NULL @ 0x1375a50] Unable to find a suitable output format for '(Windows'
(Windows: Invalid argument
2013-12-10 20:29:43,683 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file '/root/.serviio/tmp/Serviio/transcoding-temp-1000000250001446-sony2010-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file '/root/.serviio/tmp/Serviio/transcoding-temp-1000000250001446-sony2010-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
   at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:47)
   at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:134)
   at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:110)
   at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:153)
   at org.serviio.delivery.GETMethodProcessor.retrieveResource(GETMethodProcessor.java:121)
   at org.serviio.delivery.GETMethodProcessor.buildDeliveryContainer(GETMethodProcessor.java:48)
   at org.serviio.delivery.AbstractMethodProcessor.handleRequest(AbstractMethodProcessor.java:100)
   at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:81)
   at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:86)
   at org.serviio.upnp.webserver.ServiioHttpService.doService(ServiioHttpService.java:77)
2013-12-10 20:30:18,972 WARN  [ProcessExecutor] Process /root/.serviio/opt/bin/ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
Stream #0:1(eng): Audio: ac3 (ac-3 / 0x332D6361), 48000 Hz, 5.1(side), fltp, 640 kb/s (default)
handler_name    : SoundHandler
[NULL @ 0x1377410] Unable to find a suitable output format for '(Windows'
2013-12-10 20:30:42,702 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file '/root/.serviio/tmp/Serviio/transcoding-temp-1000000250012282-sony2010-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file '/root/.serviio/tmp/Serviio/transcoding-temp-1000000250012282-sony2010-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
2013-12-10 20:31:04,256 WARN  [ProcessExecutor] Process /root/.serviio/opt/bin/ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
2013-12-10 20:31:28,052 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file '/root/.serviio/tmp/Serviio/transcoding-temp-1000000250012282-sony2010-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
2013-12-10 20:32:17,181 WARN  [ProcessExecutor] Process /root/.serviio/opt/bin/ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
creation_time   : 2013-12-04 20:56:18
handler_name    : GPAC ISO Audio Handler
[NULL @ 0x1373120] Unable to find a suitable output format for '(Windows'
2013-12-10 20:32:42,092 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file '/root/.serviio/tmp/Serviio/transcoding-temp-1000000250002510-sony2010-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file '/root/.serviio/tmp/Serviio/transcoding-temp-1000000250002510-sony2010-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
2013-12-10 20:33:42,722 WARN  [ProcessExecutor] Process /root/.serviio/opt/bin/ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
[NULL @ 0x1375a60] Unable to find a suitable output format for '(Windows'
2013-12-10 20:34:05,994 WARN  [ServiioStatusService] IOException occured. Returning error code 500 to the REST layer. Message: Transcoded file '/root/.serviio/tmp/Serviio/transcoding-temp-1000000250001446-serviigo_standard-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
2013-12-10 20:34:07,676 WARN  [ProcessExecutor] Process /root/.serviio/opt/bin/ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
2013-12-10 20:34:31,502 WARN  [ServiioStatusService] IOException occured. Returning error code 500 to the REST layer. Message: Transcoded file '/root/.serviio/tmp/Serviio/transcoding-temp-1000000250001446-serviigo_standard-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
2013-12-10 20:34:32,066 WARN  [ProcessExecutor] Process /root/.serviio/opt/bin/ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
creation_time   : 2013-12-09 20:37:43
[NULL @ 0x1373040] Unable to find a suitable output format for '(Windows'
2013-12-10 20:34:57,022 WARN  [ServiioStatusService] IOException occured. Returning error code 500 to the REST layer. Message: Transcoded file '/root/.serviio/tmp/Serviio/transcoding-temp-1000000250003399-serviigo_standard-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
2013-12-10 20:34:57,576 WARN  [ProcessExecutor] Process /root/.serviio/opt/bin/ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
2013-12-10 20:35:22,532 WARN  [ServiioStatusService] IOException occured. Returning error code 500 to the REST layer. Message: Transcoded file '/root/.serviio/tmp/Serviio/transcoding-temp-1000000250003399-serviigo_standard-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
Return to Available plugins
Users browsing this forum: No registered users and 82 guests
