Help With RSS Feeds
siriusblack
Post Wed May 29, 2013 9:27 am
Help With RSS Feeds
Hi
just wondering have any one came across this problem with rss feeds
Once you reset your computer the rss feeds don't come back, However
there are in your library
Can you please help Thanks
Beta Tester
siriusblack
Post Wed May 29, 2013 12:04 pm
Re: Help With RSS Feeds
Here is my debug log
RSS FEEDS.txt
(7.3 KiB) Downloaded 484 times
Hope this helps
THANKS
Beta Tester
Post Wed May 29, 2013 1:49 pm
It looks like you don't have the required plugins installed?
siriusblack
Post Wed May 29, 2013 1:54 pm
Hi Zip
I put all these plugins back in http://www.forum.serviio.org/download/file.php?id=3495
Beta Tester
Post Wed May 29, 2013 3:30 pm
It was complaining about missing DailyMotion plugin, and the LiveFeed plugin was having issues too.
siriusblack
Post Wed May 29, 2013 3:36 pm
Zip
should I do a full uninstall + reinstall it ?
Beta Tester
Post Wed May 29, 2013 4:17 pm
no. just enable detailed logging and restart the PC, then post the log
siriusblack
Post Wed May 29, 2013 4:49 pm
Zip
Here is the log which I restarted serviio through services.msc
serviio restart.txt
(147.04 KiB) Downloaded 467 times
I also send you the log from restarting the pc
serviio pc restarted.txt
(355.29 KiB) Downloaded 489 times
Thanks appreciate it
Beta Tester
Post Thu May 30, 2013 11:06 am
It looks like some coolsport items should be available. Some others - either the rss is down/wrong or the plugins are not working properly. Ask the plugin devs for support in the appropriate plugin topics.
