Problem when fast forward movie when connecte to samsung TV
sam831214
Post Wed May 29, 2013 5:50 am
Is the software support fast forward and backward function?
Post Wed May 29, 2013 6:18 am
Re: Problem when fast forward movie when connecte to samsung
Yes, but often depends on whether the file is being transcoded or not, and the capabilities of your TV.
sam831214
Post Wed May 29, 2013 11:23 am
DenyAll wrote:Yes, but often depends on whether the file is being transcoded or not, and the capabilities of your TV.
Thanks for your reply.
My samsung tv can fast forward and backward with samsung all share buti it always make my pc hang.
Can you teach me how to setup this function with serviio?
Thanks again.
Post Wed May 29, 2013 11:29 am
Not sure there is anything to teach, it should just work for native files. Which profile are you using (Samsung A, B or C/D/E profile)?
sam831214
Post Wed May 29, 2013 1:38 pm
DenyAll wrote:Not sure there is anything to teach, it should just work for native files. Which profile are you using (Samsung A, B or C/D/E profile)?
my SAMSUNG TV MODEL IS UA46ES7000JXZK
Post Thu May 30, 2013 1:04 am
Its an E-Series so you should set Serviio to use the Samsung TV / player (C/D/E-series) profile. Set this profile and try your files...
then, in Serviio console, turn Transcoding off (and press Save) and for any files that fail to fast/forward rewind, try them again. Let us know the outcome. Make sure you put transcoding back on after.
sam831214
Post Sat Jun 01, 2013 12:12 pm
DenyAll wrote:Its an E-Series so you should set Serviio to use the Samsung TV / player (C/D/E-series) profile. Set this profile and try your files...
my previous setting is this profile already. I follow your instruction to turn the transcording off. After that, i cannot play this movie.
Thanks for your help.
Users browsing this forum: Baidu [Spider] and 5 guests
