Cannot play Radio Stations
eiaschwammal
Post Sat May 18, 2013 4:26 pm
I think I've tried everything and added a view internet radio stations as online ressources but none worked. Have also take some from this forum.
The station I want to add is Garbage Panda
http://lime.citrus3.com:8018/
What have i done:
- checked with ffmpeg -i:
Input #0, mp3, from 'http://lime.citrus3.com:8018/':
Duration: N/A, start: 0.000000, bitrate: 128 kb/s
Stream #0.0: Audio: mp3, 44100 Hz, stereo, s16, 128 kb/s
- checked it with vlc - worked!
- Entered date in Serviio - as "Live stream". Checked it in serviio with button "Check Stream URL" - worked!
- Added the entry
- is listed in my WD-Media-Player and on my Android with "MediaHous"-App
- Stations starts to load ... and load ... and never plays
Do you need any further information to help me?
Post Mon May 20, 2013 1:23 pm
Re: Cannot play Radio Stations
What profiles are you using?
eiaschwammal
Post Mon May 20, 2013 8:37 pm
Dont know, what exactly you mean by "profiles"
But i think it could be the settings of "Online ressources":
max number of feed items to retrieve: 20
Feed expiry interval: 24
Preferred online content quality: low
Post Wed May 22, 2013 9:38 am
eiaschwammal
Post Fri May 31, 2013 9:47 am
The device is a WDTV Live and uses the profile with the same name
Post Sun Jun 02, 2013 1:32 pm
can you enable detailed log and post the bit when you try to play the stream?
Users browsing this forum: Baidu [Spider] and 26 guests
