librtmp libass
Obeldobel
Post Sat Jun 01, 2013 3:44 pm
librtmp libass
Hi all,
Unfortunately, I seem to be too stupid.
my system: debian 6.0 64 bit, when I start the server, I get the following message:
2013-06-01 10:02:05,897 WARN [FFMPEGWrapper] FFmpeg is not compiled with librtmp support, RTMP streaming will not work.
2013-06-01 10:02:05,897 WARN [FFMPEGWrapper] FFmpeg is not compiled with libass support, rendering subtitles (hardsub) will not work.
how can I compile librtm and libass support?
when I run the web server, I just get a registration page with password query. but I would like to activate the license. or where I can copy the pc5dczc_xxxxxxx.lic , so I have the pro version?
http://176.28.31.62:23424/mediabrowser/
thx
Post Sun Jun 02, 2013 1:36 pm
Re: librtmp libass
if you're still running the 15 days evaluation version of Pro, just enter the password in the console (remote tab) and use it in the MediaBrowser.
Re FFmpeg, there is a wiki article on how to compile in on Linux.
Obeldobel
Post Sun Jun 02, 2013 2:59 pm
Re: librtmp libass
i have no remote tab. the software is running on a root-server without graphic surfaces, only command line
greetz
Post Sun Jun 02, 2013 3:11 pm
Re: librtmp libass
The MediaBrowser is just for viewing content remotely, you cannot setup the server using it.
You can upload the licence using the comand line viewtopic.php?f=17&t=5330&p=50586&hilit=curl+License#p50586
However, you will need the console to configure the server. So you can install the console on your PC and point it to the server http://www.serviio.org/component/conten ... e?id=21#q2 or use ServiiDroid (Android), or one of the WP apps, or you can install the PHP Web UI on your server and use that (http://wiki.serviio.org/doku.php?id=phpwebui, requires apache, and curl for apache, install by doing git clone git://github.com/mpemberton5/Web-UI-for-Serviio.git /var/www/serviioweb)
Obeldobel
Post Mon Jun 17, 2013 3:49 pm
Re: librtmp libass
fine.
since everything has worked and the server starts without errors.
thx a lot.
but now comes the next problem: I have a little chat (123flashchat) with webcam.
with "rtmp :/ / 1.2.3.4:1978 / oflaDemo" I connect to my red5 server.
Which command for a server Serviio?
greetz
Obeldobel
Post Tue Jul 16, 2013 5:55 am
Re: librtmp libass
no idea or to stupid this question ?
greetz
Post Tue Jul 16, 2013 12:49 pm
Re: librtmp libass
add it as a live stream
Obeldobel
Post Tue Jul 16, 2013 2:53 pm
Re: librtmp libass
thx for the tip, i will try it on weekend
greetz
Obeldobel
Post Sat Jul 20, 2013 6:01 am
Re: librtmp libass
I have tried: "book", then "online source", "source type = live stream" link to rtmp :/ / ipaddress: 1935 write and test. that does not work
greetz
Post Mon Jul 22, 2013 3:45 pm
Re: librtmp libass
post detaied log when adding the link and clicking Check button
Obeldobel
Post Mon Jul 22, 2013 4:34 pm
Re: librtmp libass
2013-07-22 18:28:24,633 INFO [WebServer] WebServer starting on port 8895
2013-07-22 18:28:24,634 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-07-22 18:28:24,635 INFO [EventDispatcher] Starting EventDispatcher
2013-07-22 18:28:24,635 INFO [RendererSearchSender] Searching for Renderer devices
2013-07-22 18:28:24,635 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-07-22 18:28:24,649 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface venet0 (venet0) and address 176.28.31.62, timeout = 0
2013-07-22 18:29:22,388 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2013-07-22 18:29:22,430 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2013-07-22 18:29:22,454 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://176.28.31.62:1935. It might not play.
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:292)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:209)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:102)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:453)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:94)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:132)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:269)
... 2 more
2013-07-22 18:29:22,490 INFO [PlaylistMaintainerThread] Finished looking for playlist changes
2013-07-22 18:29:22,593 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-07-22 18:29:22,594 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-07-22 18:29:22,599 INFO [PlaylistMaintainerThread] Started looking playlist changes
2013-07-22 18:29:57,328 INFO [WebServer] WebServer shutting down
Post Mon Jul 22, 2013 4:38 pm
Re: librtmp libass
what if you execute
ffmpeg -i rtmp://176.28.31.62:1935
Obeldobel
Post Mon Jul 22, 2013 4:47 pm
Re: librtmp libass
root@vps10166:/home/red5# ffmpeg -i rtmp://176.28.31.62:1935
ffmpeg version git-2013-06-03-c8faa47 Copyright (c) 2000-2013 the FFmpeg developers
built on Jun 3 2013 19:30:54 with gcc 4.4.5 (Debian 4.4.5-8)
configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-librtmp --enable-libxvid --enable-libass
libavutil 52. 34.100 / 52. 34.100
libavcodec 55. 15.100 / 55. 15.100
libavformat 55. 8.102 / 55. 8.102
libavfilter 3. 74.101 / 3. 74.101
Speicherzugriffsfehler
Post Mon Jul 22, 2013 9:09 pm
Re: librtmp libass
There is a problem, either with the URL or the FFmpeg. Does the URL work in VLC?
Obeldobel
Post Tue Jul 23, 2013 3:07 am
Re: librtmp libass
i will test it on the weekend
greetz
Obeldobel
Post Tue Jul 23, 2013 3:25 am
Re: librtmp libass
no, it does not work
red5@vps10166:~$ vlc rtmp://176.28.31.62:1935
VLC media player 2.0.1 Twoflower (revision 2.0.1-0-gf432547)
[0x1fed4dd8] inhibit interface error: Failed to connect to the D-Bus session daemon: /usr/bin/dbus-launch terminated abnormally with the following error: Autolaunch error: X11 initialization failed.
[0x1fed4dd8] main interface error: no suitable interface module
[0x1fed5888] main interface error: no suitable interface module
[0x1fea7108] main libvlc error: interface "globalhotkeys,none" initialization failed
[0x1fea7108] main libvlc: VLC wird mit dem Standard-Interface ausgeführt. Benutzen Sie 'cvlc', um VLC ohne Interface zu verwenden.
[0x1fed6658] qt4 interface error: Could not connect to X server
[0x1fed6658] skins2 interface error: cannot initialize OSFactory
[0x1fed6658] [cli] lua interface: Listening on host "*console".
Command Line Interface initialized. Type `help' for help.
> No application or playpath in URL!
RTMP_Connect0, failed to connect socket. 111 (Verbindungsaufbau abgelehnt)
[0x1fef8cb8] access_avio access error: Failed to open rtmp://176.28.31.62:1935: Operation not permitted
[0x200ba198] main input error: open of `rtmp://176.28.31.62:1935' failed
[0x200ba198] main input error: Ihre Eingabe konnte nicht geöffnet werden
[0x200ba198] main input error: VLC kann die MRL 'rtmp://176.28.31.62:1935' nicht öffnen.
but after the installation of vlc comes following message
red5@vps10166:~$ ffmpeg -i rtmp://176.28.31.62:1935
RTMP_Connect0, failed to connect socket. 111 (Connection refused)
rtmp://176.28.31.62:1935: Unknown error occurred
Post Tue Jul 23, 2013 10:30 am
Re: librtmp libass
I think it's related to this message:
Normally, RTMP URLs have other parameters in the path, not just IP and port. Are you sure it's RTMP and not RTP/RTSP ?
Obeldobel
Post Wed Jul 24, 2013 4:59 pm
Re: librtmp libass
this is the call in the chat for red5 server. and I am very sure, because every time I take this call for the red5 server
Users browsing this forum: Baidu [Spider] and 21 guests
