Need Help: Arris Media Gateway (Moxi)
SPyKER
Post Sat Feb 25, 2012 11:44 pm
Re: Need Help: Arris Media Gateway (Moxi)
So, went with just yours as mine didn't do crap!
Variety of interesting things...
This one played great video put no sound:
Unique ID                                : 231453718476929982429615322468820126031 (0xAE205D5DFDDEF6678236D35015AB094F)
Complete name                            : F:\Movies\#### 2011 720p BluRay x264 REFiNED\refined-####-720p.mkv
File size                                : 4.37 GiB
Duration                                 : 1h 40mn
Overall bit rate                         : 6 253 Kbps
Encoded date                             : UTC 2012-01-04 20:37:38
Writing application                      : mkvmerge v4.9.1 ('Ich will') built on Jul 11 2011 23:53:15
Writing library                          : libebml v1.2.1 + libmatroska v1.1.1
Format settings, ReFrames                : 5 frames
Duration                                 : 1h 40mn
Bit rate                                 : 4 747 Kbps
Bits/(Pixel*Frame)                       : 0.215
Stream size                              : 3.23 GiB (74%)
Writing library                          : x264 core 120 r2120 0c7dab9
Encoding settings                        : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=9 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=4747 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Codec ID                                 : A_DTS
Duration                                 : 1h 40mn
Bit rate                                 : 1 510 Kbps
Bit depth                                : 24 bits
Stream size                              : 1.06 GiB (24%)
This one showed up really small in the upper right and the sound was garbled:
Complete name                            : F:\Movies\####.avi
Format                                   : AVI
Format/Info                              : Audio Video Interleave
File size                                : 700 MiB
Duration                                 : 1h 41mn
Overall bit rate                         : 961 Kbps
Writing application                      : Nandub v1.0rc2
Writing library                          : Nandub build 1852/release
Format                                   : MPEG-4 Visual
Format profile                           : Advanced Simple@L5
Format settings, BVOP                    : 2
Format settings, QPel                    : No
Format settings, GMC                     : No warppoints
Format settings, Matrix                  : Default (H.263)
Codec ID                                 : XVID
Codec ID/Hint                            : XviD
Duration                                 : 1h 41mn
Bit rate                                 : 819 Kbps
Width                                    : 640 pixels
Height                                   : 272 pixels
Display aspect ratio                     : 2.35:1
Bits/(Pixel*Frame)                       : 0.196
Stream size                              : 597 MiB (85%)
Writing library                          : XviD 1.2.1 (UTC 2008-12-04)
Format                                   : MPEG Audio
Format version                           : Version 1
Format profile                           : Layer 3
Mode                                     : Joint stereo
Mode extension                           : MS Stereo
Codec ID                                 : 55
Codec ID/Hint                            : MP3
Duration                                 : 1h 41mn
Bit rate                                 : 130 Kbps
Stream size                              : 94.2 MiB (13%)
Alignment                                : Aligned on interleaves
Interleave, duration                     : 24 ms (0.58 video frame)
Interleave, preload duration             : 136 ms
Writing library                          : LAME3.90.
Encoding settings                        : -m j -V 4 -q 2 -lowpass 17.6 --abr 130
This one played beautifully:
Complete name                            : F:\Movies\###.3.avi
Format                                   : AVI
Format profile                           : OpenDML
File size                                : 3.47 GiB
Duration                                 : 2h 34mn
Overall bit rate                         : 3 214 Kbps
Writing application                      : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library                          : VirtualDubMod build 2540/release
Codec ID                                 : XVID
Duration                                 : 2h 34mn
Bit rate                                 : 2 438 Kbps
Height                                   : 528 pixels
Display aspect ratio                     : 2.40:1
Bits/(Pixel*Frame)                       : 0.150
Stream size                              : 2.63 GiB (76%)
Codec ID                                 : 2000
Duration                                 : 2h 34mn
Bit rate                                 : 640 Kbps
Stream size                              : 707 MiB (20%)
Alignment                                : Split accross interleaves
But the other MKV from before still played fine.
Post Sun Feb 26, 2012 12:08 am
ok think i got this sorted here hopefully is our last profile for this device :)
Changes
+ added transcoding for high level H264 file ( same as all other devices )
+ Remux AVI and MKV file to mpegts if they have H264 video.
+ Transcoding H264 with DTS audio to mpegts with mpeg2video and ac3
+ Transcoding for unsupported formats to mpeg2video and ac3 ( ie all none H264 files )
+ Transcoding for ogg and 3gp, not many users have these but worth having for completeness
<Profile id="22" name="Arris Media Player Final" extendsProfileId="1">
  <HttpHeaders>
       <User-Agent>.*MOXI.*</User-Agent>
  </HttpHeaders>
  <UPnPSearch>
       <FriendlyName>^MOXI.*$</FriendlyName>
  </UPnPSearch>
    <!-- Transcode H264 videos with profile level > 4.1 to MPEGTS with AC3 audio -->
    <Video targetContainer="mpegts" targetACodec="ac3" >
       <Matches container="avi" vCodec="h264" profile="high" levelGreaterThan="4.2" />
       <Matches container="avi" vCodec="h264" profile="main" levelGreaterThan="4.2" />
       <Matches container="matroska" vCodec="h264" profile="high" levelGreaterThan="4.2" />
       <Matches container="matroska" vCodec="h264" profile="main" levelGreaterThan="4.2" />
    <!-- Transcode H264 files with DTS audio to MPEG-TS with AC3 audio -->
    <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" >
       <Matches container="avi" vCodec="h264" aCodec="dca" />
       <Matches container="mp4" vCodec="h264" aCodec="dca" />
       <Matches container="matroska" vCodec="h264" aCodec="dca" />
    <!-- Remux H264 files to MPEG-TS with no transcoding -->
    <!-- Remux WTV/FLV files to MPEG-PS with no transcoding -->
       <Matches container="wtv" />
       <Matches container="flv" />
    <!--  Transcode unsupported codecs into MPEGTS, mpeg2video and AC3 audio -->
       <Matches container="avi" />
       <Matches container="ogg" />
       <Matches container="3gp" />
    <!-- Transcoded unsupported audio into LPCM audio -->
       <Matches container="mp3" />
       <Matches container="flac" />
       <Matches container="adts" />
    </Audio>
Post Sun Feb 26, 2012 12:15 am
Format                                   : AVI
File size                                : 700 MiB
Duration                                 : 1h 41mn
Codec ID                                 : XVID
Duration                                 : 1h 41mn
Bit rate                                 : 819 Kbps
Width                                    : 640 pixels
Height                                   : 272 pixels
Format                                   : MPEG Audio
Mode                                     : Joint stereo
Codec ID                                 : 55
Codec ID/Hint                            : MP3
Duration                                 : 1h 41mn
Bit rate                                 : 130 Kbps
broken avi file, nandub is shit try and repair the file with this tool http://wiki.serviio.org/doku.php?id=avirepair
SPyKER
Post Sun Feb 26, 2012 6:07 am
Wouldn't start. Found the typo: missing >
Gonna go try now.
SPyKER
Post Sun Feb 26, 2012 7:51 am
So far so good! Ran about twwo dozen files without any issues to note.
I added one fix, the detections section is back.
Thanks! Now, how to me get this final profile into the public's hands?
            <Detection>
              <HttpHeaders>
              </HttpHeaders>
      <UPnPSearch>
              </UPnPSearch>
         </Detection>
             </Audio>
Post Sun Feb 26, 2012 1:51 pm
Thats fine got late last night and started making mistakes, so went to bed. i have corrected them in my profile above, also yours has a slight difference to mine, try this profile. (dca is now only remuxed to ac3 without affecting video)
<Profile id="22" name="Arris Media Player Final Fixed" extendsProfileId="1">
  <Detection>
     <HttpHeaders>
     </HttpHeaders>
    <UPnPSearch>
    </UPnPSearch>
  </Detection>
    </Audio>
SPyKER wrote:Thanks! Now, how to me get this final profile into the public's hands?
how do you mean? you can hand out that profile to anyone to try and i will request it to be added to next release of serviio, if this last test works as i espect it will.
SPyKER
Post Mon Feb 27, 2012 12:22 am
Not quite there.
I again can't get Serviio to start. I tried to go back to the previous code, but you've updated it, so I'm trying to debug it.
Update: added the detection back and it loads.
Post Mon Feb 27, 2012 11:07 am
SPyKER wrote:Not quite there.
rofl yer maybad, ok so with that final one we have everything working once i remember to add the detection flags :oops: so h264 with dts now work just audio transcoded and not video ???
SPyKER
Post Mon Feb 27, 2012 1:02 pm
Yes. The one which was showing video and no audio now has both. I have yet to find a format which is not working now.
Post Mon Feb 27, 2012 1:37 pm
awesome, other than my lack of sleep slowing us down that went very smoothly, i will pass the profile on to ZIP for inclution into the next servio release. :)
MODS: can we close this down now please. :)
Post Mon Feb 27, 2012 5:18 pm
you have flv transcoding to mpegps, which won't work.
lesmikesell
Post Sat Jun 01, 2013 6:59 pm
Is this device the same as the 'media player' box that comes with WOW cable's whole-home DVR (ultra tv)?
Also, what would be the best format to rip dvd/blu-rays for it so they would play without transcoding and thus permit fast-forward and rewind?
PhantomNomad
Post Sat Dec 03, 2016 4:12 am
I've tried following this thread but I just can't seem to get my Eastlink Arris to work with .mkv files. The debug logs shows that Serviio knows its a MKV file. It also shows that it knows I'm running a Moxi client. But when I try to play the mkv file it doesn't even try to transcode it. The Arris front end just shows a "!" over the movie poster. I'm using the last profile shown on Page 2 of this thread. Other then turning on debug I haven't made any other changes. I checked in the console for serviio and it does show that transcoding is allowed. Does any one have some hints?
Previous
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
