UE40D8000YS won`t play mkv now
Legat
Post Sun Jun 02, 2013 7:47 am
Hello!
After something TV see but won`t play any mkv files (week earlier all works fine), now TV say - "file format does`t supported"
one of earlier worked mkv:
DiskStation> /volume1/@appstore/Serviio/bin/ffmpeg -i Men.In.Black.3.2012.1080p.
BluRay.Rus.Ukr.Eng-NTb.mkv
ffmpeg version 1.1.1-compiled_by_patters_for_Serviio Copyright (c) 2000-2013 the
 FFmpeg developers
  built on Mar 29 2013 14:44:25 with gcc 4.3.2 (GCC)
  configuration: --arch=ppc --cpu=e500v2 --enable-cross-compile --cross-prefix=/
usr/local/powerpc-none-linux-gnuspe/bin/powerpc-none-linux-gnuspe- --target-os=l
inux --prefix=/usr/local/powerpc-none-linux-gnuspe --enable-shared --disable-sta
tic --enable-pic --disable-ffplay --disable-ffserver --disable-debug --enable-pt
hreads --enable-libmp3lame --enable-librtmp --enable-libass --pkg-config=pkg-con
fig --extra-version=compiled_by_patters_for_Serviio
  libavutil      52. 13.100 / 52. 13.100
  libavcodec     54. 86.100 / 54. 86.100
  libavformat    54. 59.106 / 54. 59.106
  libavdevice    54.  3.102 / 54.  3.102
  libavfilter     3. 32.100 /  3. 32.100
  libswscale      2.  1.103 /  2.  1.103
Input #0, matroska,webm, from 'Men.In.Black.3.2012.1080p.BluRay.Rus.Ukr.Eng-NTb.
mkv':
    title           : Men in Black 3 (2012) - Release for RuTracker
    creation_time   : 2012-09-10 06:27:14
  Duration: 01:45:50.40, start: 0.000000, bitrate: 21785 kb/s
    Chapter #0.0: start 0.000000, end 369.578000
      title           : 00:00:00.000
    Chapter #0.1: start 369.578000, end 687.478000
      title           : 00:06:09.578
    Chapter #0.2: start 687.478000, end 1018.809000
      title           : 00:11:27.478
    Chapter #0.3: start 1018.809000, end 1356.230000
      title           : 00:16:58.809
    Chapter #0.4: start 1356.230000, end 1884.633000
      title           : 00:22:36.230
    Chapter #0.5: start 1884.633000, end 2256.421000
      title           : 00:31:24.633
    Chapter #0.6: start 2256.421000, end 2563.019000
      title           : 00:37:36.421
    Chapter #0.7: start 2563.019000, end 2935.850000
      title           : 00:42:43.019
    Chapter #0.8: start 2935.850000, end 3238.235000
      title           : 00:48:55.850
    Chapter #0.9: start 3238.235000, end 3567.773000
      title           : 00:53:58.235
    Chapter #0.10: start 3567.773000, end 3952.782000
      title           : 00:59:27.773
    Chapter #0.11: start 3952.782000, end 4316.312000
      title           : 01:05:52.782
    Chapter #0.12: start 4316.312000, end 4790.619000
      title           : 01:11:56.312
    Chapter #0.13: start 4790.619000, end 5277.063000
      title           : 01:19:50.619
    Chapter #0.14: start 5277.063000, end 5730.683000
      title           : 01:27:57.063
    Chapter #0.15: start 5730.683000, end 6350.400000
      title           : 01:35:30.683
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x1040 [SAR 1:1 DAR 24:13]
, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
      title           : Release for RuTracker
    Stream #0:1(rus): Audio: ac3, 48000 Hz, 5.1(side), fltp, 640 kb/s (default)
      title           : AC3 5.1 @ 640 kbps -            А              , Blu-ray
 CEE
    Stream #0:2(ukr): Audio: ac3, 48000 Hz, 5.1(side), fltp, 640 kb/s
 CEE
    Stream #0:3(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), fltp, 1536 kb/s
      title           : DTS 5.1 @ 1536 kbps
    Stream #0:4(rus): Subtitle: subrip
    Stream #0:5(eng): Subtitle: subrip
    Stream #0:6(eng): Subtitle: subrip
    Stream #0:7: Attachment: mjpeg
      filename        : cover.jpg
      mimetype        : image/jpeg
Serviio works on synology ds413.. Could anybody help?
Post Sun Jun 02, 2013 1:53 pm
Re: UE40D8000YS won`t play mkv now
make sure you are using the Samsung C/D/E profile.
