Need help with metadata
I just want to make sure my stuff is identified correctly.
All help is greatly appreciated. Thanks!!
iheartninjas wrote:in your error message about not being able to parse the nfo file which file did it include with that error. In your console what was the metadata source that you originally had chosen. you could also try changing the extension of the xml file to nfo. one other thing you could try if you haven't is to make sure that the xml/nfo's are named [video_file_name].nfo. if i can think of anything else i'll be sure to post. let me know if you succeed. good luck
Omega
Will Serviio pick up the NFO file even if online metadata is selected? That would be the ideal setup.
Users browsing this forum: Google [Bot] and 27 guests
