Modify Bat
siriusblack
Post Thu Jun 06, 2013 4:57 am
Modify Bat
Hi
can you please modify this Bat
StreamDesktop.bat
@echo off
:This bat is used to stream the desktop with VLC using HTTP
:A corresponding player must be started using HTTP
"C:\Programs\VLC TEST 1.1.10\vlc.exe" -vvv dshow:// --sout=#transcode{venc=ffmpeg,vcodec=mp2v,vb=10000,fps=24,scale=0.5,width=1280,acodec=mp3,ab=192,channels=2,samplerate=44100}:std{access=http,mux=ts,dst=:8081} --no-sout-rtp-sap --no-sout-standard-sap --ttl=1 --sout-keep :dshow-vdev=screen-capture-recorder :dshow-adev="Line 1 (Virtual Audio Cable)" :dshow-caching=2000
:Exit
My Vlc player is in C:\Program Files\vlc 1.1.10-win32\VLC
AUDIO - virtual audio cable
VIDEO - screen capture recorder
MY SCREEN RESOULITION - 1600 X 900
I have tried this
StreamDesktop.bat
@echo off
"C:\Program Files\vlc 1.1.10-win32\VLC.exe" -vvv dshow:// --sout=#transcode{venc=ffmpeg,vcodec=mp2v,vb=10000,fps=24,scale=0.5,width=1600,acodec=mp3,ab=192,channels=2,samplerate=44100}:std{access=http,mux=ts,dst=:8081} --no-sout-rtp-sap --no-sout-standard-sap --ttl=1 --sout-keep :dshow-vdev=screen-capture-recorder :dshow-adev="Line 1 (Virtual Audio Cable)" :dshow-caching=2000
:Exit
cant get it to work, when I click on the bat it flashes up with command screen + that's all
it does
Thanks really appreciate it
Beta Tester
jk50
Post Thu Jun 06, 2013 9:56 am
Re: Modify Bat
Is the 1280 command working for you ?
siriusblack
Post Thu Jun 06, 2013 10:01 am
Re: Modify Bat
SORRY
Whats the 1280 command please
nothing seems to be happening
Beta Tester
jk50
Post Thu Jun 06, 2013 10:02 am
Re: Modify Bat
Is the first command line working ? Why are you trying to modify it?
siriusblack
Post Thu Jun 06, 2013 10:04 am
Re: Modify Bat
Sorry
im new to batch files
how do I check that out ?
I thought you would have to modify it to fit your pc
Beta Tester
jk50
Post Thu Jun 06, 2013 10:18 am
Re: Modify Bat
Have you got desktop streaming working with the unmodified batch file?
siriusblack
Post Thu Jun 06, 2013 10:21 am
Re: Modify Bat
No
Beta Tester
jk50
Post Thu Jun 06, 2013 10:31 am
Re: Modify Bat
Your problem is not the batch file , leave that alone . Go back to the wiki, check your capture driver settings .
siriusblack
Post Thu Jun 06, 2013 10:34 am
Re: Modify Bat
ok thxs for your help
will have a look at screen capture settings
Beta Tester
Users browsing this forum: Google [Bot] and 41 guests
